XFX 7850 Double Dissipation Cooler
newtekie1
Semi-Retired Folder
28,472 (4.23/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
I don't believe that black part is supposed to cool the memory. There isn't anything cooling the memory along the side of the GPU, so why cool the memory along the back? Also, most HD7800 cards I've seen don't have any cooling on the memory, and GDDR5 doesn't really need cooling either.
Even the higher end cards don't have cooling on the memory. GDDR5 just doesn't get that hot.
6,880 (1.02/day)
USA
Cooling Noctua NH-D15S, 2xThermalRight TY-143, 4xNoctua NF-A12x25,3xNF-A12x15, 2xAquacomputer Splitty9Active
Video Card(s) EVGA Geforce 3060 XC Black Gaming 12GB
Storage 1x Samsung 970 Pro 512GB NVMe (OS), 2x Samsung 970 Evo Plus 2TB (data 1 and 2), ASUS BW-16D1HT
Case Lian Li O11 Air Mini
Power Supply Super Flower Leadex Platinum SE 1000W 80+ Platinum White
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
I was thinking about it and maybe the artifacting had more to do with 3d to 2d transition.
I am observing artifacts when I am playing a game in a window (league of legends) and moving firefox around on the secondary monitor. Maybe its down clocking during that time and this is causing the artifacting around the windows aero bars.
6,880 (1.02/day)
USA
Mouse Zowie EC3-C
So after running it for awhile, I did get a good reduction in temperatures. No idea if it fixed the artifact issue but I doubt it.
Room: 20*C
Idle: 27*C
Game: 55*C
Fur test: 75*C
4,815 (0.78/day)
Wangas, New Zealand
System Name Darth Obsidious
Processor Intel i5 2500K
Motherboard ASUS P8Z68-V/Gen3
Cooling Cooler Master Hyper 212+ in Push Pull
Memory 2X4GB Corsair Vengeance DDR3 1600
Video Card(s) ASUS R9 270x TOP
Storage 128GB Samsung 830 SSD, 1TB WD Black, 2TB WD Green
Display(s) LG IPS234V-PN
Case Corsair Obsidian 650D
Audio Device(s) Infrasonic Quartet
Power Supply Corsair HX650w
Software Windows 7 64bit and Windows XP Home
Benchmark Scores 2cm mark on bench with a razor blade.
Even at 75degC the core will be fine.
The issue is most probably somewhere else.
My 7870 can get up to 80degC in Unigine Valley benchmark with the 13.2 beta 6 drivers.
AsRock
TPU addict
18,875 (3.07/day)
UK\USA
Cooling D15
Audio Device(s) Yamaha RX-V677 \ Yamaha CX-830+Yamaha MX-630 Infinity RS4000\Paradigm P Studio 20, Blue Yeti
If he took the cooler off then the warranty is gone. XFX puts a sticker on the screws holding the heatsink on newer cards such as my 6950.
http://img.techpowerup.org/130220/Capture112.jpg
That depends on were he's from if he lives in the US and contacts XFX heatsink removal is allowed as long as you ask them 1st.
By reading some of the thread it surly sounds that some thermal pads have been removed or maybe even not put on in the 1st place.
6,880 (1.02/day)
USA
Mouse Zowie EC3-C
Just ran the Unigine Valley benchmark on extreme HD, only got to 69*C. I think my average fps was around 23.
4,815 (0.78/day)
Wangas, New Zealand
Valley results are about what I would expect from the 7850.
Temperatures are actually quite good.
Have you tried running the desktop with aero off?
1,556 (0.31/day)
Kolkata, India
System Name Coffee | Maximus
Processor Intel Core i7 9700K @ 5.2 GHz with AVX, 4.8 GHz cache clock | i7 9700KF @ 5.0 GHz/4.7 GHz cache
Motherboard ASUS Maximus X Formula | ASUS Maximus VIII Ranger (modded BIOS for Coffee Lake)+TPM2.0 module
Cooling Cooler Master ML240 Illusion | Cooler Master ML120L RGB
Memory 2*16 GB (32 GB) Kingston Fury Beast @3600 MHz CL17 | 4*8 GB (32 GB) HyperX Fury @3200 MHz CL14
Video Card(s) Zotac RTX 3070 8 GB Twin Edge | Galax RTX 2060 Super 8 GB
Storage Samsung PM981a 1TB NVMe+480GB SATA SSD+2 TB HDD | Crucial P5 1TB, Crucial P1 500GB+2.5TB HDDs
Display(s) LG OLED 55 G3, 4K 120 Hz, VRR, ALLM, GSync, FreeSync | Samsung 43AU9070 4K TV, VRR, ALLM
Case Corsair Crystal 460X RGB | Lianli Lancool 215
Audio Device(s) Creative Sound Blaster Z SE | Realtek ALC1150 (Supreme FX)
Power Supply ASUS ROG Strix 750G (80+ Gold) | Cooler Master MWE 650 V2 (80+ Bronze)
Mouse Cooler Master MM731 19000 DPI gaming mouse
Keyboard Cooler Master CK721 65% mechanical gaming keyboard (tactile)
Software Windows 11 Pro x64 |Windows 11 Pro x64
Benchmark Scores Cinebench R20 MT 4200,ST 547 CPU-Z MT 4871, ST 620 | R20 MT - 4158, ST - 534, CPU-Z MT 4798, ST 603
5,975 (1.32/day)
Hi! I'm from the Internet
System Name Selene / Yoda
Processor Fx 8350 @ 4.4 / Phenom II x6 1090t @ 3.6
Motherboard Gigabyte 990FXA-UD3 r4.0 / Gigabyte 890XA-UD3
Cooling H100i / Xig Dark Knight
Memory 4x 8gb G.Skill Snipers / 4x 4gb G.Skill Ares
Video Card(s) Gigabyte R9 290x / XfX DD & VisionTek HD6850's C'fired
Storage 256gb ssd, 2x 2tb Wd Blacks & 1x 1tb Wd black / 1x 1tb
Display(s) Dell Ultra Sharp 2408 WFp / Hp w2207
Case Raidmax Vampire / Chieftec Alum. Dragon Blue
Audio Device(s) Onboard Hd Audio / Onboard Hd Audio
Power Supply Corsair TX 850 watt / Corsair TX 750 watt
Mouse Logitech G500s
Keyboard Corsair Strafe
Software Win 10 pro / Win Vista Home prem. 64 bit
Benchmark Scores What are benchmarks anyway?
That card didn't have thermal pads or paste on the memory to begin with. The memory does not need it as it doesn't get hot enough. My 7850 doesn't have and cooling for it's memory either.
6,880 (1.02/day)
USA
Mouse Zowie EC3-C
Running no aero now.. I haven't seen any artifacts but its sort of a time will tell thing.
With the new thermal paste, I have been able to overclock this card like a mofo. 1100mhz core stock 1200mhz memory, 20% board power limit 1.150 volt vddc.
Temps are 72*C in Valley with custom fan profile with a score of 1248, ~30 FPS.
Here is my 3dmark11 http://www.3dmark.com/3dm11/6004779. P7182!!!!
I am using Sapphire Trixx 4.30 (4.6 wouldn't change volts). Fan Profile: 0*C@20% 40*C@40%, 80*C@100%
I don't feel like overclocking my memory, I'll just stick to core since its temperature is easy to monitor.
3,842 (0.93/day)
System Name Zotan
Processor i9-10850K
Motherboard Gigabyte Z490 Gaming X AX
Cooling H100
Memory 32GB Viper 3200
Video Card(s) Zotac RTX3080
Case Airflow 275R
Power Supply RMX850
Benchmark Scores d1nky@hwbot.org
that's pretty decent I get just above 7000 mark with 7950....but I am using the fx4100.
