XFX Radeon R9 290 Double Dissipation too loud!
6,880 (1.02/day)
USA
Cooling Noctua NH-D15S, 2xThermalRight TY-143, 4xNoctua NF-A12x25,3xNF-A12x15, 2xAquacomputer Splitty9Active
Video Card(s) EVGA Geforce 3060 XC Black Gaming 12GB
Storage 1x Samsung 970 Pro 512GB NVMe (OS), 2x Samsung 970 Evo Plus 2TB (data 1 and 2), ASUS BW-16D1HT
Case Lian Li O11 Air Mini
Power Supply Super Flower Leadex Platinum SE 1000W 80+ Platinum White
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
XFX Coolers suck, the one on my 7950 DD runs too hot
I repasted my 7850 and temperatures were reduced 10-15*C across the board. Try this, it helps a lot. You can do it without voiding warranty by contacting their tech support first. I said "I'd like to redo the thermal paste to reduce my temperatures. Is this okay? I don't want to void warranty".
fullinfusion
Vanguard Beta Tester
9,909 (1.67/day)
Which card is that and what were the room temps? Also, at 53% fan speed, was it audible?
20-21c and its in my system spec. Note thats using one card at testing and audible, hardly at all.
751 (0.17/day)
System Name My PC
Processor i7 4790k @4.4ghz
Motherboard Gigabyte z97m-d3h
Cooling Corsair H105
Memory 4x4GB Corsair Dominator Platinum 2133-9-11-11-31-1T
Video Card(s) GTX970 Stric oc
Storage Samsung 840Pro 512GB
Display(s) Asus ROG SWIFT
Case Lian Li 359
Audio Device(s) Denon DA-300USB / Denon AH-D5000
Power Supply Corsair AX860
Mouse Roccat Kone Pure Optical
Keyboard Corsair K70
Software Win10 64-bit home
I had the 7970 XFX DD from the first week the 7970 released, was always relatively silent (up to 50% fan) and cool (core below 60c and VRM's being below 75c in worst stress tests) but there were many reviews saying the card was running hot and loud (some French site was saying VRM's were above 100c). So I guess they have issues with sitting the cooler properly on all their cards. Personally I even removed the cooler and place IC Diamond paste on the core an new pads on the ram modules and vrm's and the temps were about same but fan speed was then 45% max after that TIM change (even lower than before). OFC 50% and 45% is nowhere near inaudible, but its perfectly "silent" for a full power test with OC'ed card at 1100mhz+).
But yeah, issues with XFX DD cooler are pretty frequent it seems, but I'm sure if you resit the cooler and replace TIM on the chip it will get much much much better (just make sure you don't break the thermal pads so u can reuse them.)
EDIT: my flatmate uses my card now, its still silent.
9,795 (1.90/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
beside that have you checked your fans? the blades or the axis
repaste is good idea, just re check the contact area, you may have poor heatsink contact area so the heat cant be transfered perfectly and raising your card temperature
922 (0.17/day)
London, UK
Processor AMD FX 8350 Black Edition @ 4.2Ghz
Motherboard Gigabyte 990FXA-UD3 Rev 4.0
Cooling Corsair H100i
Memory Samsung Green 16GB 30nm 1600Mhz DDR3
Video Card(s) XFX HD 7950 DD 3GB @ 850/5000Mhz
Storage 240GB Intel 520 SSD + 2TB Seagate Barracuda
Display(s) ASUS PB278Q 27" QHD
Case Fractal Design R5 Black
Power Supply Seasonic Platinum 760W
Mouse Corsair Raptor M40
Keyboard Corsair Raptor K50
Yeah i did the same thing but my MX4 paste is quite old now it might not be working as effectively. ill be ordering more soon and re-applying the paste
currently i get around 90c in games with a very mild overclock
AsRock
TPU addict
18,875 (3.07/day)
UK\USA
Cooling D15
Audio Device(s) Yamaha RX-V677 \ Yamaha CX-830+Yamaha MX-630 Infinity RS4000\Paradigm P Studio 20, Blue Yeti
Well after some more testing the vrm 1 is in it's normal area near were the PCI-E connect i tried i with a 120x mm fan running one or the other ends of the card between the cpu cooler and the car. All so noticed a 7c drop in VRM temps as well when using a fan..
And this was with a max speed 1500rpm fan and just had to make sure the fan was pushing air at the card for safety reasons as you don't want to take of any thing off on the back of the v card :p.
