Xp Pro Problem (resolution?)
Discussion in 'General Software' started by Trill, Sep 4, 2007.
  1. Trill New Member
    Sep 4, 2007
    2 (0.00/day)
    0
    Hi, It will be kinda hard for me to explain this. But i just switched over to xp pro from xp home.
    I never had a problem running 1440x900 (my native resolution) with xp home. But now that i have xp pro, with 1440x900 my desktop doesnt fit on my screen, but i can slide back and forth to see the portion that is hidden. It is verry annoying and i want to keep my native res. I used to run all my games in 1440x900 but now part of the screen on the right is cut off. If this is a feature of xp pro I havnt been able to find the option to turn it off. If anyone could give me a hand figuring this out I would be grateful.
    asus p5nd2-sli
    intel pent. D 3.4
    geforce 7950 GTOC
    4 gig pc-5200 ddr2 ram (only reads 3 lol)
    samsung syncmaster 19 inch widescreen lcd
    Windows xp pro up to date.
    Thanks
    TRilL
  2. v-zero Guest
    My advice is that you reinstall nvidia drivers - possibly try an earlier set.
  3. Conti027
    Conti027
    Jan 31, 2007
    1,395 (0.48/day)
    99
    Edmonds, Washington
    yea try reinstalling drivers or messing with the buttons on your monitor
    Trill says thanks.
  4. Trill New Member
    Sep 4, 2007
    2 (0.00/day)
    0
    Thanks guys, i used the driver that comes on the battlefield 2 disc and its all back to normal.
    Thanks again
    Trill
Share This Page
