Zalman AB3CL CPU Cooler with 12Cm Fan or Arctic Cooling Freezer 64 Pro
Discussion in 'Overclocking & Cooling' started by Greek, Dec 19, 2006.
  1. Greek
    Greek New Member
    Oct 23, 2006
    572 (0.14/day)
    3
    Leicester, UK
    which one is best, i mean the price diff is like £20 i have the zalman one, but ive seen ppl with the Arctic Cooling Freezer 64 Pro and they get like idle 24 on desktop, lowest i can go is 33-35? time for a swap?
    let me no what u think
    10 Year Member at TPU
  2. stevorob
    stevorob
    Feb 27, 2006
    1,055 (0.25/day)
    450
    Charlotte NC
    Ambient temps, case airflow, thermal compound, it all makes a difference.
    I chose the Artic cooler because it was much cheaper than anything else, and the performance of it was outstanding compared to other coolers in it's price range, and even topped some of the more expensive coolers.
    I'm idling at 27C right now @ 2.75, ambient temps is approx 74F (23.3C). I'm in my parents hot ass house. At my house, ambient temps are approx 70F (21.1C), and I idle around 23-24 at the same clocks.
    10 Year Member at TPU Crunching for Team TPU
  3. Greek
    Greek New Member
    Oct 23, 2006
    572 (0.14/day)
    3
    Leicester, UK
    if u check out ma system on ma sig thats it right there, it has two 12cm fans at the front dunno if u can see them when the front panel of the case is open, , and have applied as5 on but not kickeed in fully yet.
  4. stevorob
    stevorob
    Feb 27, 2006
    1,055 (0.25/day)
    450
    Charlotte NC
    OH I see, the zalman doesn't have a directional fan pointed at the back the arctic cooler does... it just throws that air around the case.
    How's you're ambient temps?
    And the AS5 needs 200 hours (?) to cure properly. See what temps you have in about a week.
  5. Greek
    Greek New Member
    Oct 23, 2006
    572 (0.14/day)
    3
    Leicester, UK
    i dunno ma ambient temp :p, not that hot or cold.
  6. WarEagleAU
    WarEagleAU Bird of Prey
    Jul 9, 2006
    10,809 (2.62/day)
    548
    Gurley, AL
    The new Zalman CNPS9700 or whatever can be placed where it blows air out the back. Zalman makes damn good coolers,so does AC and even TT. the TT Typhoon (BIG) I have is awesome and cools best IVe seen.
    -The Eagle
  7. Greek
    Greek New Member
    Oct 23, 2006
    572 (0.14/day)
    3
    Leicester, UK
    ah i c, well ill see if as5 makes a diff, if nt then maybe a new cooler upgrade.
  8. Ketxxx
    Ketxxx Heedless Psychic
    Mar 4, 2006
    11,507 (2.71/day)
    570
    Kingdom of gods
    AC freezer is great, ull need to pick up a thermalright AM2 bracket available off quietpc tho. unless u want the same catastroph as what happened to me :p its also WELL worth lapping the base of the AC freezer to a smooth shiny finish, improves temps a lot ;) at stock settings i was idling at something crazy like 19c :eek: and thats with a room temp of 24c
  9. Greek
    Greek New Member
    Oct 23, 2006
    572 (0.14/day)
    3
    Leicester, UK
    rite i see, well i'll need a 939 bracket, but i think they same anywayz. aint they?
