Zalman ZM-MFC2 4 Fan Speed Controller annoying beeping at system startup
Discussion in 'General Hardware' started by P4-630, Jun 11, 2008.
  1. P4-630
    P4-630
    Jan 5, 2006
    1,670 (0.49/day)
    303
    Los Santos
    I have a Zalman ZM-MFC2 4 Fan Speed Controller installed some time ago, the annoying issue is that it ALWAYS beeps 2 times when I start up my pc.
    I have 4 fans connected, 1pwm(gpu), 1cpufan (reads speed only) ,one 80mm NB fan and 1 small fan on the ram, they all spin and they all have a yellow wire to read the rpm but yet still the zalman beeps always 2 times:wtf: when I start up my system, this is annoying me and I like to have a quiet start up. There is no need for alarm since all fans spin.
    Does anyone happen to have this same fan speed controller with a same problem and maybe solved it?
  2. P4-630
    P4-630
    Jan 5, 2006
    1,670 (0.49/day)
    303
    Los Santos
    I guess no one else has this fan controller...
    :ohwell:
  3. intel igent
    intel igent New Member
    Jun 5, 2005
    4,641 (1.27/day)
    434
    Toronto, Canada
    IIRC that fan controller must be used with PWM fan's for proper operation, that's prolly why your'e getting the beeps
  4. P4-630
    P4-630
    Jan 5, 2006
    1,670 (0.49/day)
    303
    Los Santos
    There can be only one 4pin PWM fan connected which I have, the other 3pin connectors are for 3wire fans.
    I disconnected the cpu wire which was speed controlled by the motherboard and it showed the RPM readings (black and yellow wire connector) on the display.
    In the manual I found "RPM can be set from 1000 to 5940RPM"
    When my system starts up the cpu fan spins 900's rpm, I thought that may be the double beep when a fan spins belows 1000rpm, but that was not the problem... It was still beeping 2x when I started my system.
Share This Page
