Zalman ZM850-HP power supply Help ?
Discussion in 'General Hardware' started by heavyunit, Jul 10, 2012.
  1. heavyunit New Member
    Jul 10, 2012
    1 (0.00/day)
    0
    Hello Tech Power Up Forum, I just upgraded my graphics card to EVGA 025-P3-1579-AR GeForce GTX 570 HD , So my question is what is the best way to supply power using both rails on what cables so that I get the most amperage flowing to the graphics card ? I dont know how the six pin power cables are wired to the rails of the power supply so that I dont stress one rail. I would like to make it even draw using both rails , I only have one graphics card. The power supply is Zalman ZM850-HP, Thank You very much for your help.
  2. Law-II
    Law-II
    May 9, 2011
    1,762 (1.29/day)
    781
    Mainland Britain
    Hi
    EVGA recommend this - Requirements
    Minimum of a 550 power supply.
    (Minimum recommended power supply with +12 Volt current rating of 38 Amps.)
    Source - http://www.evga.com/products/moreInfo.asp?pn=025-P3-1579-AR&family=GeForce 500 Series Family&sw
    Zalman ZM850-HP supplies 18Amps on six 12V rails
    Source - http://www.techpowerup.com/reviews/Zalman/ZM850-HP/5.html
    Use the two 6+2 pin connectors that are attached to the PSU "[TPU] two PCI-E video card connectors and a few peripheral cables are fixed to the PSU which means there won't be any losses in power quality"
    Edit: mentioned by Kenshai - Update VGA card draws up to 75w of power from the PCIe slot x16 Slot that is rated at 3.3 volt [25Amps] math - 75w/3.3v = 22.73A
    Edit: General PSU Info http://www.techpowerup.com/forums/showthread.php?t=39758
    atb (all the best)
    Law-II
  3. Kenshai
    Mar 2, 2008
    1,646 (0.65/day)
    218
    Raleigh, North Carolina
    I'm willing to bet that most if not all of the PCI-E connectors will be on separate rails . So in reality it shouldn't matter which one you plug them into.
    Law - Something you're not taking into account is also that the socket provides power and that the card perhaps may have access to more than two rails of power.
    Law-II says thanks.
Share This Page
