- Dec 16, 2018
- 19 (0.01/day)
System Name | Computor! |
Processor | Phenom II 1100t black edition |
Motherboard | GA-970A-D3 |
Cooling | Defualt Case Air; PCI fan blower, some HDD fans. |
Memory | (2x4GB) DDR3 PC3-16000 9-11-9-27 Blackline (996991); Black Mamba (2 x 4GB) 1600MHz (PV38G160C9K) |
Video Card(s) | PNY 1060 3gb xlr8 |
Storage | 250gb ssd, 750gb easy raid 10 |
Display(s) | Asus VK278Q Black 27" 1920x1080 2ms Full? HD HDMI LED BackLight LCD 300 cd/m2 10,000,000 :1 (ASCR) |
Case | Aspire/Apevia? X-Superalien case(blue) |
Power Supply | Corsair TX650W |
Mouse | Logitech G402 |
Keyboard | Emachines generic keyboard |
Software | Fedora 28 |
Benchmark Scores | Unigine: heaven: 1300ish(custom), 1611(Extreme); Valley: 1864(ExtremeHD) |
I found a pic with the config. I think it's the exact match.
That may even be the exact same fan(minus the xlr8 sticker I would imagine.). The only thing I'm confused on is where the LED is located. I can't find them on the real fan when it was in front of me. I can see it on in my case, but i couldn't locate it. And I saw nothing to that looked like an LED on the fan or shroud or in that area.... I obviously missed it but boy is it well hidden.
Wait, I'm starting to assume it's just really bright and hidden in the actual fan casing. As in within the part that is spinning.
NOO ENGRISHHHH!! NO ENGRISSHSH.... 8\
I get this feeling these aren't available for sale outside of asia for some reason. I think that is japanese.(nvm, chinese) Can google translate a picture between languages?
https://item.taobao.com/item.htm?spm=a21wu.10013406.0.0.5e3d7a554YtdpZ&id=555854148135
I wonder if the fan curvature and things are the same. I'm assuming these are hard to find. I probably just need to get the lube ready. 8(
Google Translate:
GALAXY GTX660 Hall of Fame gtx770 680 graphics card fan shadow gtx760 GK80 Pangu version
Brand new original GALAXY graphics card fan, suitable for different brands of the same size graphics card, four-wire temperature control dual fan, generally not recommended for a single purchase. The single fan short-line socket is very small, much smaller than the port on the graphics card.
Look at the model of the old fan before the shoot, this fan is fixed by three screw holes, there are two models PLD09210S12HH and T129215SU, the thickness of the front model is 1 cm, the thickness of the model is 1.5 cm.
The graphics card fan can not just look at the model, the same size can be used, do not understand the old fan can be used to determine the map.
1. Model: PLD09210S12HH
Fan diameter 8.5 cm thickness 1 cm
Voltage: 12V
Current: 0.4A
2. Model: T129215SU
Fan diameter 8.5 cm thickness 1.5 cm
Voltage: 12V
Current: 0.5A
The screw holes of the three fixed fans are irregularly shaped, and the adjacent distance is 4.9*4.6*1.7 cm.
Reference model: GALAXY GeForce GTX 970 Black / 950 Ashes / GTX 970 European / GTX 760 Black General / GTX 770 Black / GTX 660 Black / GTX660Ti Four Star Black / GTX670 Four Star Black / GeForce GTX660 Hall of Fame equivalent size graphics card replacement fan
Below is the physical picture of the 9210 fan
They may not be the exact fans..
Google Translate:
Voltage: 12V
Current: 0.4A
2. Model: T129215SU
Voltage: 12V
Current: 0.5A
