1080 Ti Performance Limited by Power Consumption (please help!)
6 (0.15/day)
System Name Desktop
Processor AMD Ryzen 7 1700x
Motherboard ASUS Crosshair VI Hero
Cooling Custom loop
Memory 2x 8gb DDR4 Micron
Video Card(s) NVIDIA 1080 Ti
Storage 500gb Samsung 850 SSD / 1TB HHD
Case corsair crystal 570x
My card has recently had its core clock extremely throttled and I haven't been able to find a way to fix it. Some days it'll fix itself over the course of the day if the PC is on but the core clock is almost always stuck in the 500 MHz area on boot. I've reinstalled drivers and set my preferred power management to max performance in the control panel but this hasn't helped. I logged GPU-Z stats and found that when the clock randomly fixed itself during the day, the PerfCap reason switched from 1 (Power) to 16 (Utilization, I think), and clock speeds ran normally after that despite wattage consumption not changing materially. I'm stuck - anyone have any ideas?
1,036 (0.68/day)
System Name BOX
Processor Xeon E5-1680 v2 @ 4,3GHz
Motherboard Sabertooth X79 (BIOS 4801 + NVMe mod + uCode update)
Cooling Thermalright Venomous-X (w/LGA 2011 kit) + 2x Delta PWM Push-Pull
Memory 8x A-Data Xtreme 2000X 2GB (1868MHz CL8.9.8.24 CR2T @ 1,65V)
Video Card(s) ASUS GTX 1080 (FE)
Storage Samsung SM961 256GB NVMe, RAID0 2x WD10EZEX (1TB), HGST HUS726060ALE610 (6TB)
Display(s) Samsung T240
Case NZXT Tempest (Nanoflux/PWM fans only, some w/LEDs)
Audio Device(s) ASUS Essence ST Deluxe 7.1
Mouse Roccat Savu
Keyboard Logitech UltraXPremium
Benchmark Scores https://www.passmark.com/baselines/V9/display.php?id=108080818886
Pretty sure shunt resistor is broken/damaged/not working like it should...
Can you post latest GPU-z (2.32.0) sensor tab screen ?
6 (0.15/day)
System Name Desktop
Cooling Custom loop
The screenshot above is the sensor screen from right before I posted.
1,036 (0.68/day)
System Name BOX
Mouse Roccat Savu
It's missing stuff though ?
Pin power readout should show you which shunt is damaged.
I guess it's PCI-e one though.
6 (0.15/day)
System Name Desktop
Cooling Custom loop
Yeah I'm dumb - here's the lastest version
1,036 (0.68/day)
System Name BOX
Mouse Roccat Savu
Yeah... probably shunt mod go wrong (now it's making card think it's drawing power from PCI-e when actually it isn't - maybe).
To check if I'm right, you would have to disassemble the cooling from card and check how shunt resistors are doing (with multimeter).
I'm guessing this is Idle/On desktop ?
6 (0.15/day)
System Name Desktop
Cooling Custom loop
Yeah its on idle. Would using the other PCI slot help? I've got a water loop set up and its a bitch and a half to disassemble...
Also - haven't modded the card beyond attaching the waterblock
1,036 (0.68/day)
System Name BOX
Mouse Roccat Savu
No. Shunt failure is a hardware failure.
Changing slots/PSUs/Platforms/Monitors/etc. won't help anything (you can try if you want of course).
Regardless if your card had/has shunt mod applied or not, at this moment card is working in "safe mode" metioned frequently in Buildzoid's videos about Pascal shunt modding.
Driver basicly forces card into it, if somethings not right with parameters it receives from multiple sensors in power/voltage/current monitoring circuitry (like failed shunt mod, or failed shunt resistor), and your card is taking 4x more power it should in Idle state.
PS. Replacing shunt resistor isn't very hard, and should be relatively cheap to repair.
6 (0.15/day)
System Name Desktop
Cooling Custom loop
Is there a solution or is it bricked? I also don't really understand why it would be able to move out of safe mode mid day and run with normal speed.
Thx for the PS. Any tutorials on how to test?
1,036 (0.68/day)
System Name BOX
Mouse Roccat Savu
Card is 100% NOT bricked.
Depending on type of it's failure, shunt resistor can for example make bad contact, but if temps are right it makes better contact making card functional again.
Usually visual inspection is enough to know in most cases (if you don't have multimeter).
If it's falling off from one side, or contacts look bad - it's a good sign what's going on.
I recommend a visit to good electronics repair shop, if you don't want to (or can't) do it yourself.
As fixing this may require soldering work to be done.
6 (0.15/day)
System Name Desktop
Cooling Custom loop
Thanks for the help!
Left it on for awhile and we're back to normal clocks
