Yup! "repurposed" some old LGA 775 chips for the task lol. Never thought I'd be using some spare E7500s to shim the graphics card. Main reason for the shim is to keep distance between fans and bottom of case. I have about 1/2" at the moment....
And the primary PCI-e slot is dead, that's why the GPU is so low.
This is the nerve center
(just messing around with filters)
I especially like the offset from each tube
75Hz gaming monitors 1080p. Desktop and all my systems are as close to the wall as possible for usable wifi
Full house
I like the third monitor because I can put youtube or anything else going on that I will come back to later
This is the space for the 80mm cooler from Alphacool. It's going to be tight but I think I can make it work
The 5700 XT is a beast, it's huge. But it's also one of the most quiet GPUs and it's a spectacular performer when gaming.
Remember guys. This mad max thing is only temporary (although I do think it looks good if you apply creative license to your computer builds). It's going to look really good with the metal "cage" welded over to the side panel that will cover both front fans. Remember, case is getting a new paintjob on the entire chassis.
Can you tell I'm a fan of MSI?
Of course! You got to represent.
Warning: *Heads will explode*
We have a stable 5.0GHz ladies and gentlemen...
I was having some problems with the motherboard earlier which were preventing me from getting a decent overclock dialed in. Happy to report those issues have been resolved. We can now get down to the important quest of overclocking. And I'm only getting started.
This was actually straight forward enough once I tuned my fans and pump via PWM. There are a total of four 120 mm Noctua fans in this machine. It's rock solid stable at 5.0 GHz, which was my predicted outcome since day one... (and make no mistake, I will make another effort to push it harder from here and go for 5.1 or 5.2)
Next thing to do is test some intensive games and see how that goes. The rig is exceptionally quiet for most everything until you really push it hard. I'm literally two feet away from it and its still difficult to pick up on the standard noise of a rotating fan. Because they (the fans) are all spinning around 500 rpm at idle and ramp up from there. This is by far the most quiet machine I've ever built and ironically the highest clocked machine at that! And I've built a number of PCs using sound dampening material. I have to thank Noctua their absolute genius in consistently crafting the best fans money can buy. I will never buy anything other than Noctua going forward.
Now keep in mind, this 1 hour test run was done with the case sealed. Meaning all side panels in place. Believe it or not, putting the side cover on actually reduced motherboard temps by about 2*F
Getting closer! Just give me a little more time and I think I'll be able to get you that 5.25 result
I didn't give up and was rewarded for my efforts... I made some progress on the motherboard after all. There was definitely a gremlin there.. But I think we have successfully exercised the demons
and worked out all the kinks.
Now, I am going to post CPUz screenshots progressively, since the initial goal of a 5.0GHz stable overclock has been achieved, I can basically just have some fun from here on out and see how far we can get... So these runs do not have reliability in mind, they are strictly for kicks.
