2 EPS connectors on X570 motherboard and how to power them
35 (0.02/day)
Helsinki
Processor Ryzen 7 3800x
Motherboard MSI MEG X570 UNIFY
Cooling Noctua NH-U12S (two fans)
Memory G.Skill Ripjaws V 2x16GB DDR4 3200MHz
Video Card(s) Asus ROG Strix RTX 2070 Super OC, GPU Boost Clock +70MHz
Storage Samsung 970 Evo Plus 1TB system drive, Samsung 960 Evo 500GB, WD Black 2TB
Display(s) Asus MG279Q
Case Phanteks Eclipse P600S
Power Supply Corsair RM650i 650W
Mouse Corsair Nightsword RGB
Keyboard Corsair K65 Lux RGB
Software Windows 10 Home
My motherboard has (8+8)-pin EPS connectors. According to this video at 04:21 (
), the second one feeds PCI-E slots. If it is, I was wondering if it will have any effect on my single GPU and whether it’s necessary to plug that second connector at all. However, MSI’s support asserts that both connectors are for CPU.
I own CableMod C-Series ModMesh Cable Kit for Corsair RMi / RMx / RM (https://cablemod.com/product/cablemod-c-series-rmi-rmx-modmesh-cable-kit-carbon/) that has two (4+4)-pin EPS cables because the kit is meant for PSU of any wattage from RMi/RMx line. This cable kit is a direct replacement for stock cables and all appropriate cables have capacitors on them.
My Corsair RM650i multi-rail PSU has 3 connectors on modular panel designated as 6+2 PCI-E & 4+4 CPU. Can any of them be used for connecting to EPS on motherboard or PCI-E on graphics card interchangeably? If yes, I was wondering if I can run just one CableMod ((6+2)+(6+2))-pin PCI-E cable to my graphics card and two CableMod (4+4)-pin EPS cables to (8+8)-pin EPS connectors on the motherboard? Will my graphics card have adequate power especially when overclocking from one PCI-E connector on modular panel and one cable? Will PSU be able to give adequate power to two 8-pin EPS connectors on the motherboard from two connectors on modular panel using two EPS cables? In this suggested configuration, should I keep PSU working in multi-rail mode or switch to a single-rail?
Thank you in advance!
4,638 (0.84/day)
Formosa
System Name Overlord Mk MXVI
Processor AMD Ryzen 7 3800X
Cooling Corsair H115i Pro
Memory 32GB Viper Steel 3600 DDR4 @ 3800MHz 16-19-16-19-36
Video Card(s) Gigabyte RTX 2080 Gaming OC 8G
Storage 1TB WD Black NVMe (2018), 2TB Viper VPN100, 1TB WD Blue 3D NAND
Display(s) Asus PG27AQ
Case Corsair Carbide 275Q
Power Supply Corsair RM750
Mouse Logitech G500s
Keyboard Wooting Two
Benchmark Scores https://valid.x86.fr/ztiub6
You only need to use one, simply don't worry about the second one.
28,336 (6.24/day)
Get your motherboard manual out and read it
579 (1.27/day)
California
System Name His & Hers
Processor i9 9900k @5ghz/ R9 3900X Stock
Motherboard Asus Maximus XI Code/ X570 Aorus Master
Cooling Corsair h150i Pro Push/Pull. 5x Corsair ML120 + 4x Corsair LL120/ Corsair h115i Platinum
Memory 32 GB 4x8GB 3600mhz Corsair RGB Pro/ 32 GB 3200 CL14 @3800 CL16
Video Card(s) Asus ROG Strix 2080 ti/ Titan XP
Storage lots of SSD.
Display(s) Asus ROG PG278QR / MSI 27 inch VA panel.
Case Corsair 500D SE RGB/ Phanteks Evolv X
Audio Device(s) Arctis Pro + gaming Dac/ Corsair sp 2500/ Logitech Z 625
Power Supply Seasonic Ultra Prime Titanium 850w x2
Mouse Logitech G903 Lightspeed/ Logitech G Pro Hero.
Keyboard Corsair K95 RGB Platinum/ Logitech G Pro
He corrected his assumption about the second eps connector in a latter video. Also as @TheLostSwede has said you only need to use 1.
Low quality post by TheLostSwede
4,638 (0.84/day)
Formosa
:eek::eek::eek::eek::eek:
The god of motherboard power regulation was wrong about something, never...
Low quality post by oxrufiioxo
579 (1.27/day)
California
