- Jun 18, 2005
- 639 (0.09/day)
- London, UK
System Name | this_is_so_leet_it_needs_no_name |
Processor | Intel I5 2500k @ 4.5Ghz |
Motherboard | Asus P8 P67-M Pro |
Cooling | MUX-120 with Dual Fan |
Memory | Samsung Memory DDR3 2133 Overclocked (non LP) |
Video Card(s) | XFX ATI/AMD 5870 1gb @ [tbc] |
Storage | 2*2tb Samsung Raid 0 + 64gb Kingston SSD |
Display(s) | BenQ G2420HDBL LED monitor |
Case | Lian Li PC-60 old skool alu case |
Audio Device(s) | Asus Xonar DX/XD PCI-Express (great) |
Power Supply | Corsair 650 TX |
Software | Win 7 64bit |
Hi there
I just today got a PWM fan splitter cable off ebay. I have looked at it closely and it seems to split all 4 cables of the PWM spec and wire them all up in parallel to it's two sockets.
When I was researching these cables I was lead to believe that the tach signal wire should only be connected to one fan. Unfortunately this cable seems to connect both fans to the mobo cpu fan socket signal pin. Will this still work? Is it dangerous?
I will give this a go when my CPU arrives for my build but it would be great to get some feedback before I wire it all up. If it comes down to it I can just cut the signal wire to one of the extension sockets to 'fix' the wire. The wire is not home made, it comes in a sealed packet so that leads me to believe it is correct... please advise.
edit: found a review of the cable saying it was 'garbage' cause it sends the rpm signals for both fans to the motherboard. Looks like I will be modding it afterall. What a stupid mistake to make in a clearly retail product...
