4x4 CPU power won't fit PSU
hat
Enthusiast
20,795 (4.33/day)
Ohio
Processor i7 2600k 4.4GHz :: Athlon II x4 630 3.5GHz
Motherboard ASUS P8P67 Pro :: GIgabyte GA-770T-USB3
Cooling Corsair H70 :: Thermaltake Big Typhoon
Memory 2x4GB DDR3 1866 :: 2x1GB DDR3 1333
Video Card(s) 2x PNY GTX1070 :: none
Storage Plextor M5s 128GB, WDC Black 500GB :: Mushkin Enhanced 60GB SSD, WD RE3 1TB
Display(s) Acer P216HL HDMI :: None
Audio Device(s) Creative X-Fi Titanium Fatal1ty Pro - iLive IT153B Soundbar (optical) :: None
Power Supply FSP Hydro GE 550w :: something
Benchmark Scores >9000
I think it'd be pretty hard to catch this one. I'd suspect those connectors are probably molded many parts in a single shot. Even a fairly small mold (in a small machine, of course) could probably make 12 of them every 30 seconds or so. Unless you have someone literally sitting there all day inspecting every single one, good luck catching the odd defect here and there... that's even if that supposed person sitting there catches it.
2,707 (1.49/day)
On The Highway To Hell \m/
In post 11, that cable is an 8 pin PCI-e connector on one end and an EPS12 (CPU) on the other! Messed up!
Actually, it's a non-standard(proprietary)standard 8 pin EPS-12V connector on the PSU end and a non-standard(but fully functional) 4+4 CPU(EPS-12V) connector on the motherboard end. The non-standard(proprietary) standard 8 pin EPS-12V connector on the PSU end would(should) be the same for both 6+2 PCI-E and 4+4 CPU(EPS-12V) cables for this PSU(since they both plug into identical connectors on the PSU). Connectors on both ends of a modular PSU cable do not need to, and often do not, match. And they can also be wired differently than other(similar) modular cables for other PSUs. Which is why you sometimes can't, and in general shouldn't, use modular cables designed for a specific PSU on a different PSU.
Anyway, the following illustration will show that what I've said about the connectors on the cable in question is true. A standard 8 pin EPS-12V(not 6+2 PCI-E) on the PSU end, and the non-standard 4+4 pin CPU connector(also not a 6+2 PCI-E) on the motherboard end will still work because the square plugs with the corners missing will plug into square holes without issue(and are in a sense "universal").
EDIT: I almost had that right. Corrected.
9,203 (3.47/day)
Massachusetts
Processor i5 8600k
Motherboard Asrock Z370 Extreme 4
Cooling Corsair H-110i GTX
Memory 2x 4Gb Crucial Sport LT
Video Card(s) MSI GTX 980 Gaming
Storage Samsung 850 evo 250Gb
Display(s) Dell Ultra Sharp Widescreen 24" 1200P
Case Fractal Design Meshify-C
Power Supply Seasonic Focus+ 750 Gold
Mouse Logitech G502 spectrum
Well all is working except plugging in a drive trips everything.
So as soon as you plug something into the sata power cable it causes a problem? i must have a bunch of spare sata power cables....if you need any let me know. im not sure if they are brand specific or not tho.
Have more than i realized.
Toothless
Tech, Games, and TPU!
6,030 (2.84/day)
Washington, USA
System Name Volt // Dualie
Processor i7-4790k // E5-2680v2 x2
Motherboard MSI Z97 MPower // S2600IP4
Cooling NZXT Kraken X60 // Hyper 212 x2
Memory G.Skill Ripjaws 4x8GB // 16x4GB ECC
Video Card(s) MSI GTX1080 Ti Gaming X // GTX 750TI
Storage 250GB NVME boot + 250GB SSD + 5 HDDs // 240GB SSD + 300GB HDD
Display(s) LG 34UB88-P + 2x AOC 2425W + Dell 2007FP // Dell 2007FP
Case Nanoxia Deep Silence 6 // Gutted case
Audio Device(s) LucidSound LS30 // None
Power Supply Rosewill Fortress 750w // EVGA NEX650G
Mouse Logitech G602 // IBM J85845R
Keyboard G.Skill KM780 RGB (Brown switches) // Logitech M100
Software Windows 10 Professional // Windows 10 Professional
Benchmark Scores Technical term is PEBCAK issue, which stands for Problem Exists Between Chair And Keyboard
Confirmed one drive dead and the other dead now (was working when shipped)
Wrong cable used, it happens. They were mixed up.
Mussels
Moderprator
47,512 (8.51/day)
Australalalalalaia.
System Name Big Fella
Processor Ryzen R7 2700X (stock/XFR OC)
Motherboard Asus B450-i ITX
Cooling Corsair H110 W/ Corsair ML RGB fans
Memory 16GB DDR4 3200 Corsair Vengeance RGB Pro
Video Card(s) MSI GTX 1080 Gaming X (BIOS mod to Gaming Z) w/ Corsair H55 AIO
Storage 1TB Sasmsung 970 Pro NVME + 1TB Intel 6000 Pro NVME
Display(s) Phillips 328m6fjrmb (32" 1440p 144hz curved) + Sony KD-55X8500F (55" 4K HDR)
Case Fractal Design Nano S
Audio Device(s) Razer Leviathan + Corsair Void pro RGB, Blue Yeti mic
Power Supply Corsair HX 750i (Platinum, fan off til 300W)
Mouse Logitech G903 + PowerPlay mousepad
Keyboard Corsair K65 Rapidfire
Software Windows 10 pro x64 (all systems)
Benchmark Scores Laptops: i7-4510U + 840M 2GB (touchscreen) 275GB SSD + 16GB i7-2630QM + GT 540M + 8GB
Turns out we didnt need the hit squad to wipe your drives, you did it yourself
Toothless
6,030 (2.84/day)
Washington, USA
I got a replacement from who I got the PSU from, so the build is complete now. It's a supercute little lunchbox build.
12,300 (2.71/day)
System Name Pioneer
Processor Intel i9 9900k
Motherboard ASRock Z390 Taichi
Memory G.SKILL TridentZ Series 32GB (4 x 8GB) DDR4-3200 @ 13-13-13-33-2T
Video Card(s) AMD RX 5700 XT (XFX THICC Ultra III) OC'd to 2100Mhz/1800Mhz
Storage Mushkin Pilot-E 2TB NVMe SSD w/ EKWB M.2 Heatsink
Display(s) 50" Panasonic Plasma model TC-P50S2, based on a 2010 Panasonic NeoPDP panel
Case Thermaltake Core X31
Audio Device(s) VGA HDMI->Panasonic SC-HTB20 Soundbar/Schiit Modi MB/Asgard 2 DAC/Amp to AKG Pro K7712 Headphones
Power Supply SeaSonic Prime 750W 80Plus Titanium
Mouse ROCCAT Kone EMP
Keyboard WASD CODE 104-Key w/ Cherry MX Green Keyswitches, Doubleshot Vortex PBT White Transluscent Keycaps
Software Windows 10 x64 Enterprise... yes, it's legit.
Benchmark Scores 3dmFS 24401: https://www.3dmark.com/fs/21546141 3dmTS 10409: https://www.3dmark.com/spy/10196074
lol.
Don't you love it when problems take care of themselves?
