5800x (and other Zen 3 chips) PBO settings/Temperature fix
856 (0.53/day)
Uttar Pradesh, India
Processor AMD R7 1700X @ 4100Mhz
Motherboard MSI B450M MORTAR MAX (MS-7B89)
Cooling Phanteks PH-TC14PE
Memory Crucial Technology 16GB DR (DDR4-3600) - C9BLM:045M:E BL16G36C16U4W.M16FE1 X2 @ CL14
Video Card(s) XFX RX480 GTR 8GB @ 1408Mhz (AMD Auto OC)
Storage Samsung SSD 850 EVO 250GB
Display(s) Acer KG271 1080p @ 81Hz
Power Supply SuperFlower Leadex II 750W 80+ Gold
Keyboard Redragon Devarajas RGB
Software Microsoft Windows 10 (10.0) Professional 64-bit
Benchmark Scores https://valid.x86.fr/mvvj3a
My 5700x with Chrome and some app in the background (dont think it makes too much difference anyway)
Yeah weird stuff same PBO settings almost same score but showing 87W.
  • Like
Reactions: izy
izy
536 (2.04/day)
How is that possible? I see your 5800x is using 0.02v more your effective clock is lower and you probably have better cooling than me but the scores are the same.
Edit: Maybe the AutoOC / curve does something , i dont know.
Nice RAM OC , love to see it:)
856 (0.53/day)
Running a dual tower aircooler. Its performing ok at the moment because of the cold temps here. What cooling are you using?
Not one of my best bins have to run RCDRD 16 on this. but not much difference in performance if it was at 15.
  • Like
Reactions: izy
izy
536 (2.04/day)
I am using ID-Cooling SE-224-XT, it does the job.
1,441 (0.35/day)
Springfield, Vermont
System Name KHR-1
Processor Ryzen 7 5800X
Motherboard ASRock B550 PG Velocita
Memory 32 GB G.Skill Trident Z Neo F4-3600C18D-32GTZN
Video Card(s) Sapphire Nitro+ Radeon RX 6750 XT
Display(s) Samsung Odyssey G40B 27-inch
Case Corsair 275R
Mouse Logitech G Pro (Hero)
Software Windows 11 Pro x64 22H2
Rearranged the front case fans and got this on 11 22H2: (82C max, according to Ryzen Master, at the defaults) I noticed that when the temp gets higher, it seems to be boosting more. Windows build 22621, is indeed 11.
1,441 (0.35/day)
System Name KHR-1
Case Corsair 275R
I am on win10 , what are your PBO settings / curve ? I will add some top exhaust on mine too not that i need it but why not :)
I haven't changed anything yet, except when I tried some different power limits.
856 (0.53/day)
So I dropped EDC to 95A now I am getting 15.9K @ 85W
Dropped EDC to 90A and got even better score. :confused:
So if you wondering what happens at 85A you guess it score goes up again!
Anywhoo midnight here need to hit the bed. Hope this was all not just some weird dream. :roll:
  • Like
Reactions: izy
157 (0.29/day)
Portugal
Processor Ryzen 7 5800x
Motherboard Msi b450 tomahawk max II
Cooling Artic liquid freezer II 240mm
Memory 2x8Gb B-die @3800 cl14/ 53ns on aida
Video Card(s) Evga 3060 ti ftw3
Storage M.2 Samsung 970 Evo Plus 250gb + 1tb ssd
Case Corsair 275r airflow
Audio Device(s) Hyperx
Power Supply Seasonic core gc 650w 80 plus gold
Mouse Zowie ec2-a
Keyboard Trust
Benchmark Scores Cinebench r20: 631/6232 Cinebench r23: 1628/15901 CPU-Z: 672/6960 SotTR:221FPS
Later I post my results I'm on agesa 1.2.0.7 + 3800cl14
783 (0.28/day)
System Name The Banshee
Processor Ryzen 5 5600 @ 4.65GHz 1.20V
Cooling CPU + GPU Custom loop
Memory 32GB 4x8 G.Skill Trident Z 3600 CL16 1.35V
Video Card(s) AMD Radeon Instinct MI25 16GB (Flashed to WX 9100) + GTX 1050 2GB For CUDA
Storage 1TB Kingston NV2 & 1TB Mass Storage HDD
Display(s) LG 25UM57-P
Case Fractal Design Arc XL
Audio Device(s) ATH-M20x
Mouse Evga Torq X3
Keyboard Thermaltake challenger
Software Win 10 Pro 64-Bit
Run with Realtime priority and you'll get a more reliable and higher result, this goes for all CB versions.
On normal priority with my 5600 @ 4.65GHz I get around 11700-11900 but on Realtime I get around 12050-12100.
Dropping the EDC from 160A to 90A (stock) yielded a higher score on normal priority but with Realtime it didn't change.
856 (0.53/day)
Thanks for the tip but I always do all my runs in real-time only. Every CB run is only done in RT.
In Benchmate is set permanently to real time.
Refer to this post.
Your 5600 score is about right I get around 12108 with mines so good score. Only noobs do their run in normal priority mode. j/K :laugh:
Mussels
Freshwater Moderator
56,646 (8.40/day)
Oystralia
Motherboard Asus x570-F
Memory 2x32GB DDR4 3600 Corsair Vengeance RGB @3866 C18-22-22-22-42 TRFC704 (1.4V Hynix MJR - SoC 1.175V)
Video Card(s) Galax RTX 3090 SG 24GB: Underclocked to 1700Mhz 0.737v (375W down to 250W))
Display(s) Kogan 32" 4K 70Hz | Gigabyte G32QC (1440p 165Hz) | Phillips 328m6fjrmb (1440p 144Hz)
Case Fractal Design R6
Keyboard Razer Huntsman TE (custom white and steel keycaps)
You need a nice Thermalright cooler to fix you up. People say X3D is a hot chip.. nah not at all :)
x3D is freaking amazingly cold for what it is, it only warms up for AVX workloads
Isnt that EDC bug still around where once you pass a certain value, you can get a performance loss?
Effective clock is super important from HWinfo to tell if you're clock stretching, i can drop my voltage/temps a lot more on this CPU but it comes at the cost of effective clocks and therefore performance
856 (0.53/day)
@Mussels I need some help here please.
Leave it to me to buy a 5800X the week before ZEN 4 launches. :slap:
So the issue I am having is that this CPU wont do PB0 +50 without bluescreening. Both my 5600 and 5600X can do PB0 +200 and -CO on top of that.
Stock perofmance seems slighly lower than the TPU review. So far I am not that happy with this CPU but it could be because it behaves differently from my 5600 and 5600X.
Here are the core ratings in HYDRA. With PBO disabled. So is it normal for a 5800X to not be able to do PB0 +50? I have tried +25 it can boot into windows but +50/+75 etc mostly unstable crashed before windows loads or after I log in. I am considering requesting a return and exchange on Amazon but before I do that I wanted to check with someone who has more experience with this CPU.
View attachment 262780View attachment 262781
Finally sorted out the PBO +200Mhz boost override issues I had on my B450. :rockout:
tabascosauz
5,808 (2.05/day)
Western Canada
Processor 5800X3D | 5700G
Motherboard ROG Impact | B550I Aorus AX
Cooling FC140 x T30 | Big Shuriken 3
Memory 32GB 3733CL14 | 16GB 4333CL16
Video Card(s) RTX 4070 Ti Eagle | Vega 8
Storage 8TB of SSDs | SN550
Case Caselabs S3 | Lone Industries L5
Power Supply Corsair HX1000 | HDPlex 200W
Software 11 Pro | 11
Hey guys so I was doing some testing with EDC today and I found some really weird results need
to verify with other 5800X users if this data is correct. Multiple runs I'm getting around +/-84W with 15K R23?
EDC 110A = 84w 15k
EDC 120A = 87w 15k
EDC 125A = 85w 15k
EDC 130A =84W 15K
I think you just found a new bug in AGESA :laugh:
Safe to say 87W would not get you to 80C, and none of the effective clock is correct for 15k (4.0, 4.2, 4.6). Did you ever figure out what setting broke everything at once
856 (0.53/day)
Not sure what is was. But did do a run with ECO mode 65W and 95W. These power figures should be more accurate than those. Temps are also lower here.
Mussels
56,646 (8.40/day)
Oystralia
Huh go figure, my x3D is only a tiny bit behind your 5800x
as you can see with the eco mode, the effective clock dropped a fair bit - secret is to slowly raise PPT until that stops raising and you've got your max limit, and see if the temps are good there
2,046 (1.36/day)
Chicago Land
Processor 13600KF
Motherboard Asus B660-G (BCLK enabled!!)
Cooling Stock Air
Memory Patriot C36 series 5200mhz
Video Card(s) Gigabyte RTX 2060
Storage Samsung 980 pro m2
Display(s) 21" - 55"
Case None
Power Supply Antec CP series 850w
Mouse Razar Mamba Tournament Edition
Keyboard Logitech G910
Yeah, mine too. But it's not an AMD rig unfortunately. I suppose this is an ill comparison. :/
Mussels
56,646 (8.40/day)
Oystralia
2,046 (1.36/day)
Chicago Land
Processor 13600KF
Cooling Stock Air
Case None
definitely the weirdest zen CPU i've seen so far
Humps along pretty good though. When looking, it was either that or a 5600X. Which still want to do, but for my sons rig. To replace a 2700x. Just not sure if he needs 16 threads or if 12 will do ok.
20 (0.05/day)
UK - Sheffield
System Name Maddogg Custom Build
Processor Ryzen 7 5800X PBO 4.85Ghz
Motherboard MSI MPG x570 Gaming Edge WiFi
Cooling EK 280 DRGB AIO
Memory 32GB G.SKILL Trident Z Neo 3600mhz (b-die)
Video Card(s) MSI RTX 3080 Gaming X (running Gaming Z bios)
Storage Samsung 950 Pro NVME
Display(s) Gigabyte G32QC 31.5" 165hz 1440p
Case Corsair 4000D Airflow (White)
Audio Device(s) Corsair Virtuoso 7.1 Headset
Power Supply Corsair AX860i
Mouse Corsair Nightsword Gaming Mouse
Keyboard Corsair K70 RGB
Software Windows 11 Pro (Ghost Spectre)
Benchmark Scores 3DMark Timespy - 17697 https://www.3dmark.com/spy/33886373
1usmus Hydra is pretty awesome now for finding PBO Custom Curve as well as other things like OCing Radeon GPU's, Memory DRAM Calc etc.
You do have to subscribe to patreon to download it (until final release which will eventually be free but this could be a while yet) but its worth $9.50 as it works flawlessly for PBO in my findings. gained an extra 5%-10% performance over my manual PBO curve and it stress tests too. You can set the level of stress as well depending on your type of PC usage. Give it a try if you havent already its certainly worth a go for sure in my opinion. Hope it helps you all in more ways than one :)
Diceair
2 (0.02/day)
So I played around with my limits and curve optimizer, Found the following to work for me
ppt =142
TDC = 95
EDC = 110
max boost override 100mhz
curve on -10 best cores and -26 rest
I'm on the following specs
5800x
fractal design s36 360mm
3600mhz ram g.skill overclocked to 3733 cl16-16-16-19
asrock b550 steel legend
Palit RTX 3080 ti gamerock (undervolted)
Windows 11 with latest updates
My phanteks enthoo pro case I modified so I can add 1 more fan in front so layout is as follows
2x cougar vortex pwm 70cfm fans front, 1x arctic p12 pst front
fractal cooler top as exhaust
rear 120mm arctic p12
I took the stock rear and installed it at the bottom as intake
I also removed my pci slot covers that helped with gpu temps a bit.
Now I did a test last night with everything as it is at 100% fan speed I can get about 15850-15910 4620mhz on Cinebench R23 now I have 3 extra arctic p12 fans lef over from the 5 pack so decided to literally put them on top of my case with side panel closed as exhaust and have the cable coming out the pci slot covers. I then started with 1 then 2 then 3 fans and every time I add a fan my scores increased a little bit with 2-3 fans I got consistently over 16000 points with 3 fans or over 16050 +-4700mhz with same settings. I think if I can get them flush with the radiator it will be even better for my clock speeds.
Now I'm thinking how can I improve my temps maybe I should try push/pull on the radiator but don't know if it's a good idea to have different fans on top than on the bottom of the rad so bottom of rad stock fractal fans and top 3x arctic p12. Scared that might not be a good idea. The other thing is have to quickly look if I even did get enough screws to install another 3 fans on top.
TLDR: cooler = fractal s36, stock fans all fans in case and cooler 100% cbr23 = 15850-15910 4650mhz, Added 3x arctic p12 literally top of case full speed cinebench r23 = 16000-16050 +-4700mhz
Mussels
56,646 (8.40/day)
Oystralia
That's a pretty good setup overall
push pull is perfectly fine with mismatched fans, that's not an issue at all other than setting them to different fan speeds (So they cant all be on the one controller, obviously)
824 (0.42/day)
Ft. Washington, MD
System Name Main
Processor R7 5800x
Cooling D5, (all Arctic fans) two F14 + three F12 for intake, two P14 + two F14 (Rad) + two F14 exhaust
Memory 2x8 GB Corsair Vengeance LPX 3600CL14@CL16
Storage 5 pcie gen 4 m.2
Display(s) Sony 50X90J
Case Tt Level 20 HT
Power Supply Corsair RMx 750w
Mouse Logitech G903
Keyboard GSKILL Ripjaws
VR HMD NA
Software win 10 x64
@Diceair
iinm the fractal are flow, and the arctic are pressure fans, so swap that the arctic are the intake pushing onto the rad,
and the fractal pull behind it.
according to arctic, the P fans are supposed to pull when used alone,
but are better in pushing air, when used in combo (with other fans pulling).
so far seems to be working better, as my temps are same/tick lower, while running less max fan rpm), after switching the P14 to push (280 copper rad, two F14 pulling.
Diceair
2 (0.02/day)
@Diceair
yes seems like I don't have enough screws to install 6 fans on radiator
824 (0.42/day)
Ft. Washington, MD
System Name Main
Processor R7 5800x
Case Tt Level 20 HT
Mouse Logitech G903
VR HMD NA
Software win 10 x64
at least for the arctic, you might be able to use shorter screws between fan and rad,
and use the existing longer set to mount the exhaust fans from outside the case (rad/case/fans).
as long as they have the finer tread and fit the rad mount, even shorter ones should work,
mounting fans straight to the rad (no case metal between), sometimes drive/motherboard screws will fit.
