So with an RM850x (CP-9020180) I'll lose nothing in terms of "electrical" and protection quality comparing to let's say an RM850i, SSR-850FX or Straight Power 11 850W?
Now let's compare the new RM850x and the old RM850i:
- Adjustable Single/Multi 12V Rail --- No (RMx), Yes (RMi)
- Fan bearing technology --- Rifle Bearing (RMx), Fluid Dynamic Bearing (RMi)
- iCUE Compatibility --- No (RMx), Yes (RMi)
- Cable Type --- Low-Profile (RMx), Sleeved and Flat (Tom's Hardware specifies "In-cable capacitors" as what's negative about new RMx)
Please comment on all of this - what do I lose not having each of what an RMi has?
Can one turn off that passive mode when the PSU doesn't use it's active air cooling at all? I mean, it heats and I don't want that, the heat kills hardware.
And rifle bearing fan lives noticeably less than fluid dynamic bearing fan. What, should I buy whatever cheap PSU and wait till Corsair updates RMi?..
Adjustable Single/Multi 12V Rail --- No (RMx), Yes (RMi) -- single is better than multi, ability to switch as multi could be better in some types of workloads, devices you will use, usually server/device oriented
Fan bearing technology --- Rifle Bearing (RMx), Fluid Dynamic Bearing (RMi) -- that is kind personal, Fluid Dynamic Bearing is better but it depends of the ambient temperature, also pay attention that corsair has been putting Fluid Dynamic Bearing in the rmx series.
https://computerwolf.co.uk/products...ully-modular-80-gold-1?variant=25996778242112
- iCUE Compatibility --- No (RMx), Yes (RMi) - that is reserved only for the rmi series cause the "i" implies digital link, so this will never be on the rmx series. Software controlled psu features. This is cool cause you can see efficiency and other things, no real meaning other than that, digital terminology.
- Cable Type --- Low-Profile (RMx), Sleeved and Flat (Tom's Hardware specifies "In-cable capacitors" as what's negative about new RMx) - some people prefer with, some without, it comes down to filter ripple, I myself prefer with it but nothing wrong without it as some units have already inside filters for ripple good enough.
I would go for the rmx, is cheaper and efficiency is only less than 0.1% than the rmi. For reference below, Corsair rm1000x 91.037% x rm1000i = 91.192%.
I hope it helped you.
