About Radiator Temps
[DGK]
93 (0.02/day)
Phillippines
System Name ILLUMINATTI
Processor CPU Intel Core i7 920 i7 OVERCLOCKED MHz: 3820 Multiplier: 19 Voltage: 1.3625 Stepping: C0/C
Motherboard Motherboard EVGA X58 Classified Motherboard (141-BL-E759-A1)
Cooling CooliT Freezone
Memory G.Skill F3-12800CL9T-6GBNQ 6GB DDR3 6X2GB OVERCLOCKED MHz: 1600 Voltage: 1.550 Timings: 9
Video Card(s) EVGA GTX 295 (quad SLI)) GTX 295+ OVERCLOCKED GPU MHz: Default RAM MHz: Default
Case Silverstone Raven RV 01
Power Supply Corsair CMPSU-HX1000W Modular
Software Windows Vista 64-but Ult.
Benchmark Scores 3D Mark Vantage Score: 32,478 3DMark06 Score: 20,546
The Top Half of the Rad is cold and the bottom is Hot.
is there something wrong? is it bad?is it supposed to be like this?
or should i release the air inside of it by unscrewing this and putting it back on again to release air?
im new to LC-ing.Need help on this thanks.
sneekypeet
Retired Super Moderator
29,203 (4.86/day)
System Name EVA-01
Processor Intel i7 12700K
Cooling be quiet! PURE LOOP 360
Memory Sabrent ROCKET DDR5 2x32GB @ 4800MHz @C32
Display(s) Samsung 55" 4K 60hz
Case be quiet! SILENT BASE 802
Audio Device(s) Realtek on board > Sony Receiver > Cerwin Vega's
Mouse Always Changing
Keyboard Always Changing
If you haven't bled the loop, it is a good idea. You dont have to remove the screw either, just loosen it a turn or two and wait for water to come out, then tighten it;) I would suggest keeping a towel handy.
43,375 (7.33/day)
Processor AMD Ryzen 5900x
Motherboard MSI x570s Carbon Max WiFi
Cooling Corsair AIO 360. Phantek T30 fans.
Memory 32GB G.Skill 3600Mhz CL14
Video Card(s) Zotac RTX 3070 Ti Trinity OC Watercooled
Storage SSD's
Display(s) MSI MAG322CQR
Case Lian Li PC 011 Dynamic
Audio Device(s) Schiit Modius DAC, SMSL SP200 amp. HiFiMan HE400i Headphones PreSonus Eris 4.5" monitors.
Power Supply Corsair H1000i
Mouse Razer Viper V2 Pro
Keyboard Fantech Maxfit 67
Make sure you're using a strong enough pump too.
[DGK]
93 (0.02/day)
Phillippines
the pump is MCP 655-B (no speed cont.)
10,242 (1.65/day)
Granite Bay, CA
System Name Big Devil
Processor Intel Core i5-2500K
Motherboard ECS P67H2-A2
Cooling XSPC Rasa | Black Ice GT Stealth 240 | XSPC X2O 750 | 2x ACF12PWM | PrimoChill White 7/16"
Memory 2x4GB Corsair Vengeance LP Arctic White 1600MHz CL9
Video Card(s) EVGA GTX 780 ACX SC
Storage Intel 520 Series 180GB + WD 1TB Blue
Display(s) HP ZR30W 30" 2650x1600 IPS
Case Corsair 600T SE
Audio Device(s) Xonar Essence STX | Sennheisser PC350 "Hero" Modded | Corsair SP2500
Power Supply ABS SL 1050W (Enermax Revolution Rebadge)
Software Windows 8.1 x64 Pro w/ Media Center
Benchmark Scores Ducky Year of the Snake w/ Cherry MX Browns & Year of the Tiger PBT Keycaps | Razer Deathadder Black
That's an awful lot of blocks to run that pump through. With all your high end hardware, I'd look into an Iwaki RD-30. You also should bleed the loop.
5,147 (0.85/day)
AZ
System Name Thought I'd be done with this by now
Processor i7 11700k 8/16
Motherboard MSI Z590 Pro Wifi
Cooling Be Quiet Dark Rock Pro 4, 9x aigo AR12
Memory 32GB GSkill TridentZ Neo DDR4-4000 CL18-22-22-42
Video Card(s) MSI Ventus 2x Geforce RTX 3070
Storage 1TB MX300 M.2 OS + Games, + cloud mostly
Display(s) Samsung 40" 4k (TV)
Case Lian Li PC-011 Dynamic EVO Black
Audio Device(s) onboard HD -> Yamaha 5.1
Power Supply EVGA 850 GQ
Mouse Logitech wireless
Keyboard same
VR HMD nah
Benchmark Scores no one cares anymore lols
not to mention the extra beefy radiatior.
[DGK]
93 (0.02/day)
Phillippines
Problem solved thanks boys, appreciate the help.
719 (0.13/day)
Processor i9 9900k @ 4.8 Ghz
Motherboard Asrock Z370 Taichi
Cooling Xspc raystorm direct die, 2x 480 swiftech rads + 2x 120 block ice rads D5, Monsoon Dualbay Res
Memory 32gb G.Skill DDR4 3200mhz CL14
Video Card(s) Gigabyte Aorus 3080 Ti Waterforce WB
Storage Samsung Evo 860 500gb, Samsung Evo 860 1Tb x2, WD White 12tb x2
Display(s) Acer xb270hu 144hz 2560x1440
Case Enthoo Primo
Audio Device(s) Schiit Modi Multibit/Magni3 - M1060 (fuzzor+LQi cable+Eikon suede)/ATH-W1000X (Purrin's mod+suede)
Power Supply EVGA SuperNova 1300w
Mouse Razer Orochi
Keyboard Tesoro
Software TeamOS W10 Pro/W7 Pro
Please post the solution you used to help others!
+ I'm kinda curious..
[DGK]
93 (0.02/day)
Phillippines
If the top is cold and the bottom hot that would indicate that there is no water in the top. I'm assuming that you have it mounted with the barbs at the bottom, in which case a large bubble will form at the top of the rad, as the tubes form an inverted "U" shape:
In your case the water is not making it all the way to the top of the rad, so it can't displace the air. This normally happens, but needs fixing. You need to get the air out of the top of the rad, either by unscrewing that bleed screw or by tilting the rad so that the air can escape.
If you unscrew the bleed screw, make sure that your res is full and your pump running, loosen the screw and allow the air to escape but be ready to do it up again as soon as water starts to come out. Leave everything for a bit and try again until there is no more air.
I Did what John said it happened to be that my RAD isnt Bled good.
