Advice needed... Cleaning AIO Rad after spill?
612 (0.83/day)
System Name Still waiting for a 5900x/3080 or 6800xt...or not.
Processor I9 9900kf w/ HEATKILLER IV PRO Copper Nickel
Motherboard MSI MEG Z390 ACE
Cooling BarrowCH Boxfish 200mm-HWLabs SR2 420/GTX&GTS 360-BP Dual D5 MOD TOP-Koolance PMP 450-EK D5 PWM G2
Memory 4x8gb HyperX Predator RGB DDR4 4000
Video Card(s) MSI RTX 2070 Duke 8G OC w/ Byski N RTX2080TI X
Storage XPG SX8200 PRO 1TB NVMe M.2 / Crucial MX500 1TB
Display(s) Acer XG270HU
Case ThermalTake X71 w/5 Noctua NF-A14 2000 IP67 PWM/3 Noctua NF-F12 2000 IP67 PWM/3 CorsairML120 Pro RGB
Audio Device(s) Klipsch Promedia 2.1
Power Supply EVGA SuperNOVA 1300 G2
Mouse Logitech G502 SE
Keyboard Black Aluminun Mechanical Clicky Thing With Blue LEDs, hows that for a name?!
Software Win10pro updated to whatever the latest MS crap is.
Use your faucet sprayer to clean the rad fins out after its soaked. You wont have to worry about overspraying quite as much ;)
Mussels
Freshwater Moderator
52,565 (8.31/day)
Oystralia
System Name Rainbow Sparkles
Processor Ryzen R7 5800X (PBO tweaked, 4.4-5.05GHz)
Motherboard Asus x570 Gaming-F
Cooling EK Quantum Velocity AM4 + EK Quantum ARGB 3090 w/ active backplate. Dual rad.
Memory 2x32GB DDR4 3600 Corsair Vengeance RGB @3800 C18-22-22-22-42 TRFC704 (1.4V, SoC 1.15V Hynix MJR)
Video Card(s) Galax RTX 3090 SG 24GB: Often underclocked to 1500Mhz 0.737v
Storage 2TB WD SN850 NVME + 1TB Sasmsung 970 Pro NVME + WD AN1500 1TB + 1TB Intel 6000P NVME USB 3.2
Display(s) Gigabyte G32QC (4k80Hz, 1440p 165Hz) + Phillips 328m6fjrmb (4K 60Hz, 1440p 144Hz)
Case Fractal Design R6
Audio Device(s) Logitech G560 |Razer Leviathan | Corsair Void pro RGB |Blue Yeti mic
Power Supply Corsair HX 750i (Platinum, fan off til 300W)
Keyboard Razer Huntsman TE (custom white and steel keycaps)
VR HMD Oculus Rift S
Software Windows 11 pro x64 (Yes, it's genuinely a good OS)
Benchmark Scores I don't quite know how i managed to get such a top tier PC, I am not rich.
Do the bucket dunk first then take it outside, put a spray head on a hose and blast the dirt out.
If you want, you could try blowing some compressed air through the fins first. My guess is that this will not dislodge all of it since the soil was wet. You could also try gently using a thin wood skewer or toothpick.
i like that idea, garden hose shouldnt get enough pressure to damage anything - but should blast any hardened dust/dirt/debris out
plastic bag the pump part (honestly even that should be fine if it gets wet, and dries out)
33,594 (6.31/day)
Just hose the rad out and then use isopropylalcohol to dry it out with air
204 (0.05/day)
Kent, UK
System Name Cannon
Processor Intel Core i9 9900K
Motherboard Asus Z390-A
Cooling Corsair H100i PRO XT w/ Corsair ML120 White LED x2
Memory 16GB (2x8GB) Corsair Vengeance Pro RGB 3600MHz
Video Card(s) GTX 980
Storage 500GB 970 Evo Plus NVMe + 2x 500GB 850 Evo + 3TB Toshiba P300 HDD
Display(s) 31.5" AOC CQ32G1 2560x1440 144hz Curved VA + 21.5" Dell P2219H IPS 1080p
Case Corsair 4000X RGB - 3xSP120 ELITE RGB + 1xML120 White LED
Audio Device(s) Creative X-Fi Titanium + Logitech z623 2.1
Power Supply Corsair TX650M
Keyboard Corsair K70 RGB
Software Windows 11 Pro x64 || Linux Mint 19
Benchmark Scores None. Primary uses are browsing, music, gaming (mostly Battlefield & Doom) and virtualization!
Hey everyone, sorry for the late response; long story short, I followed the advice given and washed the H100 rad whilst being careful with the CPU block (wrapped in plastic) and it all works! Rad is clean and I just installed in my new rig/case; keeping the new 9900k pretty cool!
Thanks again everyone!
