Advice on how to clean the insulating foam inside a PC case after a fire
suedezu
19 (0.07/day)
I managed to get my hands on an older Fractal Design Meshify PC case that has been in a building affected by a fire.
The case itself was not affected by the fire: it's not burned, melted or deformed in any way. The case is empty of components.
The problem is the inside insulating foam covering all sides of the interior REEKS of smoke and I cannot clean this foam just by using cleaning wipes, no matter how hard I try.
It really needs to be washed. I'm thinking about putting the case in a large basin and just wash it with detergent and then let it dry until it's completely dry.
Any suggestion on how to best wash the insulating foam? What products should I use?
Thanks!
Ahhzz
5,952 (1.37/day)
System Name Ironic
Processor Intel 2500k 4.4Ghz
Motherboard ASROCK|Z68 PROFESSIONAL Gen 3
Cooling Corsair H60
Memory 32GB GSkill Ripjaw X 1866
Video Card(s) Sapphire R9 290 Vapor-X 4Gb
Storage Samsung 860 EVO 1Tb/WD BLACK SN750 500GB NVMe
Display(s) 22" Dell Wide/ 22" Acer wide/24" Asus
Case Antec Lanboy Air Black & Blue
Audio Device(s) SB Audigy 7.1
Power Supply Corsair Enthusiast TX750
Keyboard Corsair Vengeance K90
Software Win 7 Ult 64 bit
Could you post up a pic of the foam? Might give us an idea of what cleaning options we could offer.
suedezu
19 (0.07/day)
I'm not at home right now but I can perhaps better explain the situation.
The foam is glued to the side panels and I believe the top panel too. It's a 1 cm thick black foam, kind of dense and It's meant to sound proof the case.
The fire was substantial with a lot of black smoke that circulated through the case and the foam kind of stored the smoke just like the vacuum cleaner sponge-like filters do.
I fear that if I don't wash the inside foam to really get rid of the smoke as soon as I install the components inside and turn on the PC the house will star smelling like a fire.
11,315 (3.09/day)
Oregon
System Name Delta // Alpha-HTPC
Processor Intel i7 6700K // Intel i5 4570
Motherboard GIGABYTE Z270X-Gaming K7 // Gigabyte H97M -D3H
Cooling Corsair H80i V2 // Silverstone NT-06 Pro
Memory Corsair DDR4 3000 32gb //G.SKILL Ripjaws X Series 8GB 1600
Video Card(s) EVGA RTX 2080// EVGA GTX 980 ti
Storage Samsung 950 Pro NVMe 512, 2 Tb FireCuda// Samsung 1Tb SSD
Display(s) ASUS PB278Q 27" 1440X 2560 // 55" LG 4K SK8000 Series
Case Corsair Obsidian Series 550D // Silverstone Granada GD05
Audio Device(s) Focusrite Scarlett // HDMI to Samsung HW-R650 sound bar
Power Supply Corsair TX850M // SeaSonic G Series 550w
Keyboard Cooler Master CK550 RBG
paint remover and a hose. It will also remove plastic so remove any
suedezu
19 (0.07/day)
Using paint remover won't affect the foam? Obviously I want to keep the foam intact and glued to the side metal panels.
I was thinking using regular detergent and lots of water or any other kind of substance as long as It doesn't destroy the foam.
1,005 (0.26/day)
austria
Processor 2500k
Motherboard ud4
Cooling water
Memory 4gb
Video Card(s) 560ti
Power Supply 300sfx
you really want to wash this and not remove the foam?
i think what you said yourself that if it gets warmer with hardware inside then it will start to smell again.
remove and\or replace foam maybe with a spatula
suedezu
19 (0.07/day)
No, I don't want to remove the foam. The whole point of this particular kind of case is the sound insulating foam. By removing it it's just another regular PC case.
1,005 (0.26/day)
austria
Processor 2500k
Motherboard ud4
Cooling water
Memory 4gb
Video Card(s) 560ti
Power Supply 300sfx
you could replace the foam
i think less of a job
4,003 (1.78/day)
Kiev, Ukraine
System Name WS#1337
Processor Ryzen 5 1600X
Motherboard Gigabyte x470 AORUS Ultra Gamin
Cooling Xigmatek Scylla 240 AIO
Memory 2x8GB Team T-Force Vulkan DDR4-3000
Video Card(s) MSI RTX 2060 Super Armor OC
Storage Adata SX8200 Pro 1TB
Case Chieftec AL-01B-OP
Audio Device(s) ALC1220
Mouse Logitech G603
Keyboard Zalman K500 modded (Gateron brown)
Software Windows 10, Ubuntu 18.04 LTS
If the chassis is after fire - you do want to replace that foam. As @basco said, it's going to smell as soon as you put it back into service.
Best way to remove it: acetone or any type of chemical solvent. Just get a lot of it, along with some sort of spatula, and perform the procedure outside the house, unless you are into getting high on chemicals )))
BTW, just a regular black packing foam works just as well as that fancy stuff that's in FD or CM cases. Alternatively, you can get an off-brand sound-absorbing foam for speakers (which is what PC case manufacturers actually use, cause it's dirt-cheap). Just found a local store that sells it for around $2.5 for a 50x50cm panel w/ 30mm thickness, or somewhere around $1.50 for a 20mm thick 45x45cm panel.
5,715 (1.10/day)
USA
System Name Small ATX Desktop
Processor Intel i5 8600K @ 4.6 GHz Core & 4.3 GHz Uncore @ 1.168V
Motherboard Asrock Z370 Taichi
Cooling Phanteks PH-TC14PE, MonoPlus, Fans: 2xThermalright TY143 / 2xCorsair SP-120L / 2xYate Loon D14BH-12
Memory G-Skill TridentZ 2X8GB DDR4 3200 CL14 F4-3200C14D-16GTZ @ 3200 14-14-14-34 2T @ 1.35V
Video Card(s) Zotac 1060 6GB Mini ZT-P10600A-10L with Arctic MonoPlus and Yate Loon D14BH-12 Fan
Storage OS Samsung 970 Pro 512GB NVMe, Games Phison E12 NVMe 1TB, HDD WD Black 4TB WD4005FZBX, 2xWD10EZEX
Display(s) 2x Asus PB258Q 2560x1440 25" IPS
Case Lian Li PC A05NB (Inverted Mobo)
Audio Device(s) Audiotechnica ATH M50X, Antlion Mod Mic 4, SYBA SD-CM-UAUD, Acoustic Research 2Ch Speakers
Power Supply Seasonic SS-660XP2 660 Watt Platinum
Mouse Zowie EC2A Mouse, Razer Naga Chroma '14, Corsair MM600, Inateck 900x300 XL pad, Tiger Gaming Skates.
Keyboard Filco Majestouch II Ninja TKL, Goldtouch GTC 0033 Ten Key, PS3 Controller
Software Win 10 LTSC 1809
Wait until summer, leave the case panel outside in the heat and sun for a few days, might break down a bit but the sunlight will remove odor.
404 (0.82/day)
Processor 3770K @ 4700MHz 1.375v
Motherboard Asus P8Z77-V
Cooling Le Grand Macho RT, TY143
Memory 2x2GB G.Skill TridentX, 2x2GB G.Skill Perfect Storm @ 1000 8-9-8-24 1T 1.65v
Video Card(s) EVGA GTX 980 Classified @ 1495/2001
Storage Crucial M4 256, WD 1TB Black, and some misc spinners.
Display(s) Hisense 55"
Case Fractal Design Meshify C TG, White
Audio Device(s) NAD T748, Mission M something, Monitor Audio FB-210, Monster HDP 1800
Power Supply CM Silent Pro M2 850
Mouse Zowie EC2 Evo
Keyboard Logitech G15
Software Yes
Benchmark Scores Ask your mom.
I think you have a Define, not a Meshify. Meshify doesn't have any sound dampening. While my Define R4 and my Define C Mini TG does. You can try to soak it in soapy water and clean and rinse it as best you can, but I don't think you are going to get those sheets out in one piece. There might be a commercially available chemical that can eat the odor too, but I don't know.. I would try what Vario said. Its cheap and easy.
1,005 (0.26/day)
austria
Processor 2500k
Motherboard ud4
Cooling water
Memory 4gb
Video Card(s) 560ti
Power Supply 300sfx
25% vinegar is very good at removing odor
404 (0.82/day)
Mouse Zowie EC2 Evo
Software Yes
Oh yeah, my mom uses vinegar to clean, that stuff is brutal lol. Makes your lungs burn. That should do it.
4,003 (1.78/day)
Kiev, Ukraine
System Name WS#1337
Mouse Logitech G603
118 (0.17/day)
Finland
Processor i7 4770K
Motherboard Asus Z87-Expert
Cooling Noctua NH-U12S, &case fans all controlled by Aquaero 6
Memory 2x8GB TeamGroup Xtreem LV 2133MHz
Video Card(s) Vega 64
Storage Samsung 840 Pro + 2x 5GB WD Red@RAID1
Display(s) Dell U3014
Case Lian Li PC-A71B
Audio Device(s) Sound Blaster ZxR, Objective2 (2x), AKG K702&712, Beyerdynamic DT990
Power Supply Seasonic Prime Titanium 650 (+Eaton 5P 1550 as "backup power")
Mouse Logitech G700
Keyboard Logitech G810
You can replace it with bitumen etc acoustic mass sheets.
Those should be cheaply available for car acoustics.
And they're not foams.
Those cosmetic scams used by some cases lack mass to damp vibrations of case panels/block airborne sound.
Doubt it even corrodes concrete and machinery unlike 85% formic acid...;)
404 (0.82/day)
Mouse Zowie EC2 Evo
Software Yes
Its not a cosmetic scam, they are heavy. Go huff some and let me know how your lungs feel after. I cleaned a bathtub with it once, worked good but burns your lungs. No one said anything about using caustic materials. You wont burn yourself even if you shower with it. Its vinegar, just really strong.
dorsetknob
8,444 (1.56/day)
Should be ok to wash with normal detergent
allow to dry in a warm place (store with foam at bottem
cover foam with cat litter ( it adsorbs smells and is inexpensive just keep the cats away from it :) )
rotate case so foam is at bottem always and reapply new cat litter
case should be ready to use after a few days
you can test for smell (smoke and such) by warming case inside with a hair dryer.
6,939 (1.93/day)
Manchester uk
System Name RyzenGtEvo
Processor Amd R7 3800X@4.350/525
Motherboard Crosshair hero7 @bios 2703
Cooling 360EK extreme rad+ 360$EK slim all push, cpu Monoblock Gpu full cover all EK
Memory Corsair Vengeance Rgb pro 3600cas14 16Gb in two sticks.
Video Card(s) Sapphire refference Rx vega 64 EK waterblocked
Storage Samsung Nvme Pg981, silicon power 1Tb samsung 840 basic as a primocache drive for, WD2Tbgrn +3Tbgrn,
Display(s) Samsung UAE28"850R 4k freesync, LG 49" 4K 60hz ,Oculus
Case Lianli p0-11 dynamic
Power Supply corsair 1200Hxi
Mouse Roccat Kova
Keyboard Roccat Iksu force fx
Benchmark Scores 8726 vega 3dmark timespy
You can replace the foam with new stuff?
118 (0.17/day)
Finland
Processor i7 4770K
Mouse Logitech G700
Stuff used by Fractal Design in side panels isn't some "bubly" foam, but dense solid stuff.
Unlike mass damping, foams like Akasa Paxmate, Silverstone SST-SF01 etc present in some cases are totally useless in thin layers.
Such foams need thickness enough to fill like half the case to work well.
404 (0.82/day)
Mouse Zowie EC2 Evo
Software Yes
Yeah I don't know about any of that stuff, I just know its not foam, and its heavy and works really well.
826 (0.17/day)
Processor i7 7700k @ 4.8ghz 1.28v
Motherboard Asus Z170-e
Cooling Megahalems Rev2 with Kaze Ultra 120 fan
Memory HyperX Fury 64GB (4 x 16GB) DDR4 2400MHz
Video Card(s) Quatro P4000
Storage 1tb Samsung 970 EVO,500gb,750gb
Display(s) Asus 23in 1920X1080
Case CoolerMaster HAF 932
Audio Device(s) X-Fi
Power Supply Corsair tx650w
Mouse Logitech G5
Keyboard Dell
Software 10 Home 64bit
You would be better off just replacing the foam.
434 (0.09/day)
Oak Ridge, TN
System Name BorgX79
Processor i7-3930k 6/12cores@4.4GHz
Motherboard Sabertoothx79
Cooling Capitan 360
Memory Muhskin DDR3-1866
Video Card(s) Sapphire R480 8GB
Storage Chronos SSD
Display(s) 3x VW266H
Case Ching Mien 600
Audio Device(s) Realtek
Power Supply Cooler Master 1000W Silent Pro
Mouse Logitech G900
Keyboard Rosewill RK-1000
Software Win7x64
Dishwasher, on medium heat, with alconox.
It will get most of the loose carbon.
Realize that the carbon surface is mildly conductive, so any circuitboard, switch, anything in there should be replaced, as the carbon will be inside stuff.
I had this happen with a smoky kerosene heater I was using temporarily, and it wasted every drive, every PCB; only the case was usable after washing.
11,315 (3.09/day)
Oregon
The foam is toast if it smells of smoke. Just replace it. I thought you burnt the foam to the metal. But you can buy that foam
118 (0.17/day)
Finland
Processor i7 4770K
Mouse Logitech G700
Ozone treatment would be best hope for "non-destructive" way.
Though because of being obviously rather strong oxidizer with that loose third wheel in ozone molecule looking for any other stuff (like users lungs) to party with, it can damage materials in higher concentrations.
And cost is no doubt more than just scrapping those damping materials and replacing them.
