Advice sought for 3900x build, accepted bios settings and varying highest speed recorded in various monitors
647 (5.22/day)
Crawley
System Name 3900x
Processor AMD Ryzen 3900x
Motherboard Gigabyte Aorus X470 gaming 7 WiFi
Cooling Noctua NH DI-15S soon Alphacool Eisbaer 360 with Noctua redux fans, then an open loop
Memory 32GB (4 x 8GB) Corsair 3200 C16 Dominator Platinum OC to 3733 16-16-16-32-48
Video Card(s) Gigabyte Aorus GeForce® RTX 2070 Super
Storage Samsung Evo 970 1TB NVMe M.2 SSD as boot drive, Intel 660P 2TB NVMe M.2 SSD second drive
Display(s) AOC Q3279VWFD8
Case Cooler Master H500M mesh front soon Thermaltaje View 7
Audio Device(s) Sound Blaster G6
Power Supply Seasonic Titanium 1000W with cable mods cables
Mouse Corsair Dark Core SE & Logitech G815 Keyboard
Keyboard Logitech G815
Software wIn 10 Pro possibly Manjaro at some point
I have the h115i platinum on my 3900X it outperforms the h150i pretty sure that mostly just comes down to having higher rpm fans though. There's a new Arctic 360 aio coming out that looks promising the 280mm version performs well.
Thank you :)
INSTG8R
Vanguard Beta Tester
6,030 (1.08/day)
Canuck in Norway
System Name Hellbox 3.0(same case new guts)
Processor i7 4790K 4.6
Motherboard Asus Z97 Sabertooth Mark 1
Cooling TT Kandalf L.C.S.(Water/Air)AC Cuplex Kryos CPU Block/Noctua
Memory 2x8GB Corsair Vengance Pro 2400
Video Card(s) Sapphire 5700XT Nitro+
Storage WD Caviar Black SATA 3 1TB x2 RAID 0 2xSamsung 850 Evo 500GB RAID 0 1TB WD Blue
Display(s) Samsung CGH70 27” 1440 144hz Freesync 2 HDR
Case TT Kandalf L.C.S.
Power Supply Seasonic X-1050W 80+ Gold
Mouse G502 Proteus Spectrum
Keyboard G19s
Software Win 10 Pro x64
Nice speed! my best is 396 down, 32 up
Yeah I install and uninstall games like people surf the web. We were talking about DRM and older games so I downloaded Crysis Crysis 2 and Crysis Warhead in a just a few minutes just to fire each one up once to see if they worked
647 (5.22/day)
Crawley
System Name 3900x
:laugh:
How much storage do you have then??
INSTG8R
6,030 (1.08/day)
Canuck in Norway
Keyboard G19s
:laugh:
3TB for games 1TB SDD for the big open worlders and a 2TB RAID 0 Spinny array for everything else
647 (5.22/day)
Crawley
System Name 3900x
I need to add more to this. I have an Evo 970 1TB and a 660P 2TB, need to add some larger in the future
Those temps seem fine and adding another fan should improve them even further.
Well, adding the second fan seems to have made zero difference, still 70c
A bit disappointing, but I seem to remember Now that the NH DI-15S with one fan, matched the NH DI-15 with two fans
1,014 (1.77/day)
California
System Name His & Hers
Processor i9 9900k @5ghz/ R9 3900X Stock
Motherboard Asus Maximus XI Code/ X570 Aorus Master
Cooling Corsair h150i Pro Push/Pull. 5x Corsair ML120 + 4x Corsair LL120/ Corsair h115i Platinum
Memory 32 GB 4x8GB 3600mhz Corsair RGB Pro/ 32 GB 3200 CL14 @3800 CL16
Video Card(s) Asus ROG Strix 2080 ti/ Titan XP
Storage lots of SSD.
Display(s) Asus ROG PG278QR / MSI 27 inch VA panel.
Case Corsair 500D SE RGB/ Phanteks Evolv X
Audio Device(s) Arctis Pro + gaming Dac/ Corsair sp 2500/ Logitech Z 625
Power Supply Seasonic Ultra Prime Titanium 850w x2
Mouse Logitech G903 Lightspeed/ Logitech G Pro Hero.
Keyboard Corsair K95 RGB Platinum/ Logitech G Pro
70C for a 3900X under full load is pretty good. You will likely not get better performance with an AIO
what are you using to load the cores?
647 (5.22/day)
Crawley
System Name 3900x
Really?
I thought that water cooling was supposed to be better?
1,014 (1.77/day)
California
Really?
Open loop yes... High end air vs High end aio is pretty similar it's really going to come down to ambient temps and how fast you let your aio fans spin.
647 (5.22/day)
Crawley
System Name 3900x
Any suggestions then please?
1,014 (1.77/day)
California
The amount you would have to spend to improve over your Noctua cooler in a real stress test that last 30-60m doesn't make a whole lot of sense especially if you consider how much noise the aio would need to make for you to get better Temps.
Cinebench R20 doesn't last long enough to get a good idea of how your cooler is functioning especially an aio cooler that may take 5-10m to heat soak before reaching maximum steady temps. I would use Aida 64 extreme just the standard non fpu test at a minimum to test your cooling for a min of 30m preferably 1 hour.
647 (5.22/day)
Crawley
System Name 3900x
The Noctua fans were maxed out pretty much at 1439 rpm reported, they weren't That noisy though.
I did the EKWB Custom loop configurator last night and that ended with about a £350 cost ?
INSTG8R
6,030 (1.08/day)
Canuck in Norway
Keyboard G19s
Next drive will be a 10TB I think. I’ve run out of space for any more drives so I’ll take out my 1TB WD Blue storage driive and not think about space for awhile
1,014 (1.77/day)
California
I've seen some really good temps from people using an open loop I would do some research and go that route over going from your excellent noctua cooler to an aio that at best will give you 2-5C while being substantially louder. Don't get me wrong I love aio and that is all I use and if you had a box cooler I would recommend one over an air cooler because I cant stand gigantic air coolers in my case lol.
647 (5.22/day)
Crawley
System Name 3900x
ATM I just have a 3TB external seagate USB attached. Not looked into raid as yet, well I mean I've read about it etc but not looked into it fully
I must admit that using one now I am not a fan and it has now completely blocked off all the ARGB from the Corsair ram.
I think I will look into an open loop for the future, I have the room in the case which is good.
Depending on how much better the temps would be with an open loop what I Might do is possibly get an AIO for now and look into open loop for the future
INSTG8R
6,030 (1.08/day)
Canuck in Norway
Keyboard G19s
I have 5TB total but my OS is 1TB RAID 0 2x850 EVOs 1TB storage and 3TB Gaming
647 (5.22/day)
Crawley
System Name 3900x
Can you have a SSD and say a 2.5 inch SSD together in a raid?
647 (5.22/day)
Crawley
System Name 3900x
They are both SSDs... their physical size doesn't matter... did you mean to say that?
Or are you saying an SSD and HDD?
I have a evo 970 1tb As my boot drive, could i add a evo 860 sata 1tb and make a raid that way?
1,014 (1.77/day)
California
Hardware Unboxed during their 3950X review had a 3900X under a pretty decent open loop they did an hour long blender avx workload and peak temps were 68C.
INSTG8R
6,030 (1.08/day)
Canuck in Norway
Keyboard G19s
RAID 0 just combines 2 drives into a single volume but I‘‘ve always used 2 matching drives
647 (5.22/day)
Crawley
System Name 3900x
Blimey that's not That great is it
1,014 (1.77/day)
California
647 (5.22/day)
Crawley
System Name 3900x
There's only 2 m.2 slots on this MB and I have both in use, hence looking at a say an evo 860
Run something with avx for an hour you will likely get over 80c.
So what sort of temps could I expect with an open loop during gaming?
(as that's likely to be my heaviest use atm)
1,014 (1.77/day)
California
during gaming 40-60c on your current cooling would be my guess with an open loop you may be able to get that into the 40-50c range depending on how large a loop you're using
with the Corsair h115i platinum I see a max of 45-55c depending on how cpu demanding the game is.
gaming isn't very demanding though honestly even a 240mm radiator can handle gaming with a 3900x without breaking a sweat.
You can't really compare different chips though some of our cpu may be running at slightly higher or lower voltage depending on silicon quality and motherboard variances.
647 (5.22/day)
Crawley
System Name 3900x
But if I am going to do this than I might as well go for the best performance as I can. After all you can guarantee that cooling demands aren't going to lower with any future CPUs( unless Ryzen 4000 series has something up its sleeve that we know nothing about).
This what EKWB comes up with, at €370
