Alphacool Announces NexXxoS HPE-45 & HPE-60 X-Flow Full Copper Radiators
Uskompuf
1,221 (1.83/day)
Alphacool today presents the HPE-45 and HPE-60 X-Flow, the new generation of high-performance radiators from Alphacool's proven NexXxoS full copper radiator series. What is new? With the HPE series, Alphacool increases the number of cooling channels within the radiator. This change gives a significant increase in cooling performance without increasing the restriction in the radiator. Another performance-enhancing feature of Alphacool's HPE series is the high fin density. With a fin spacing of 15 or 16 FPI, it enables an optimal flow of air. If the radiator is equipped with 80 mm fans on both sides in push/pull mode, a significant reduction in water temperature is demonstrably possible compared to standard radiators.
The NexXxoS HPE-60 all-copper radiators also feature Alphacool's proven X-Flow technology. This means that the Inlets and outlets are located on the opposite sides and thus enable an easy realisation of a water circuit within a server rack. The 60 mm thick radiators can be equipped with three or four 80 mm fans per radiator side.
Alphacool NexXxoS HPE-45 Full Copper 80mm Triple Radiator
  • L x W x H: 286 x 80 x 42 mm
  • Material cooling fins, channels & prechamber: copper
  • Material outer housing: steel
  • Fins per Inch: 16
  • Threads: 2x G1/4"
  • Fan size: 80 mm
  • Fan slots: 3 one-sided / 6 double-sided
  • MSRP: 93.49 €
Alphacool NexXxoS HPE-60 Full Copper X-Flow 80mm Triple Radiator
  • L x W x H: 287 x 80 x 60 mm
  • Material cooling fins, channels & prechamber: Kupfer
  • Material outer housing: Stahl
  • Fins per Inch: 15
  • Threads: 6x G1/4"
  • Fan size: 80 mm
  • MSRP: 109.99 €
Alphacool NexXxoS HPE-60 Full Copper X-Flow 80mm Quad Radiator
  • L x W x H: 367 x 80 x 60 mm
  • Fins per Inch: 15
  • Threads: 6x G1/4"
  • Fan size: 80 mm
  • Fan slots: 4 one-sided / 8 double-sided
  • MSRP: 119.99 €
612 (0.83/day)
System Name Still waiting for a 5900x/3080 or 6800xt...or not.
Processor I9 9900kf w/ HEATKILLER IV PRO Copper Nickel
Motherboard MSI MEG Z390 ACE
Cooling BarrowCH Boxfish 200mm-HWLabs SR2 420/GTX&GTS 360-BP Dual D5 MOD TOP-Koolance PMP 450-EK D5 PWM G2
Memory 4x8gb HyperX Predator RGB DDR4 4000
Video Card(s) MSI RTX 2070 Duke 8G OC w/ Byski N RTX2080TI X
Storage XPG SX8200 PRO 1TB NVMe M.2 / Crucial MX500 1TB
Display(s) Acer XG270HU
Case ThermalTake X71 w/5 Noctua NF-A14 2000 IP67 PWM/3 Noctua NF-F12 2000 IP67 PWM/3 CorsairML120 Pro RGB
Audio Device(s) Klipsch Promedia 2.1
Power Supply EVGA SuperNOVA 1300 G2
Mouse Logitech G502 SE
Keyboard Black Aluminun Mechanical Clicky Thing With Blue LEDs, hows that for a name?!
Software Win10pro updated to whatever the latest MS crap is.
Ok, so why are we only seeing 80mm versions if it increases cooling so significantly?
Bring on the big dogs Alphacool! These little guys are cute and all but no self respecting wcer is putting 8x80mm fans anywhere near their case. Wheres the 360s and 420s?
Do you finally have something new for us or is this server only? Inquiring minds want to know :p
330 (0.11/day)
It looks like you haven't done water cooling, so you don't know where to use them.
612 (0.83/day)
Oh really? How about you edumacate me oh mighty wise one!
274 (0.12/day)
Perhaps you should read the article to get "edumacated", whatever that means.
It stand right there that this is for server environment. For a regilar PC the nexxxos series is good enough.
612 (0.83/day)
Hahaha
Perhaps you should have read my first post?
It stand right there...eh whatever that's supposed to mean?? I specifically asked if it was for server only. Hrrmmm
Yawn, and yes, im aware of the Alphacool NexXxoS(notice the cool spelling) rads that have been around for the last oh 15 years or so. Pay close attention to the first part of my question above. If you need clarification just ask ;)
EddyAlphacool
Alphacool Rep
57 (0.03/day)
@maxfly
These are industrial radiators for server cases. We achieve between 3-6° lower water temperatures, depending on waste heat and fan speed.
The end-customer variants, i mean 120/140mm radiator sizes, will come later.
16,051 (5.97/day)
Video Card(s) MSI GTX 1080 Gaming X @ 2100/5500
Case Fractal Design Define C TG
Audio Device(s) Situational :)
Power Supply EVGA G2 750W
Mouse Logitech G502 Protheus Spectrum
Keyboard Lenovo Thinkpad Trackpoint II (Best K/B ever... <3)
Software W10 x64
THREE X's and X-Flow technology on top.
This must be awesome.
75 (0.01/day)
Peterborough, UK
System Name IONE
Processor Intel Xeon E5-1650 v3
Motherboard Gigabyte MW50-SV0
Cooling Noctua HSF
Memory 4x 16GB Crucial DDR4 ECC Registered
Video Card(s) Nvidia 710GT
Storage 250GB Samsung 850 EVO (boot), WD Black 1TB NVMe (system), 14x Seagate IronWolf 10TB (RAID6 storage)
Display(s) Dell UP3017
Case Lian-Li PC-777B
Audio Device(s) Blue Sadie headphones
Power Supply Corsair AX1200
Mouse Logitech M510
Keyboard Microsoft Ergonomic
Software Xubuntu 20.04
Benchmark Scores N/A
Vin Diesel approves of this new radiator series.
