AMD Radeon "Navi 23" OEM Card, Possible RX 6600 XT Spied
42,336 (8.10/day)
A highly plausible looking AMD Radeon RX 6600 series graphics card is doing rounds on the web. The card is purportedly an AMD reference-design OEM-trim "Navi 23" board. We know from recent rumors that the 7 nm "Navi 23" silicon powers the upcoming Radeon RX 6600 XT and RX 6600. The picture only shows a portion of the card, the back-plate as viewed toward the rear I/O, but the bar-code sticker is unmistakable. The sticker reveals the OEM to be PC Partner, which is known to make all OEM and retail reference-design AMD Radeon graphics cards, which are marked "MBA" (made by AMD). You'll find a similar-looking bar-code sticker on all AMD reference-design cards, regardless of the AIB partner marketing it.
The bar-code sticker references "Navi 23 XT," which is very likely the Radeon RX 6600 XT. The card has 8 GB of GDDR6 memory, and its display outputs include one HDMI, and three DisplayPorts. Elsewhere in the picture, we get valuable insights into the design of the cooler, revealing that the card features an aluminium fin-stack heatsink with one or more axial fans (top-flow), rather than a channel-type lateral blower-type cooling solution. The "Navi 23" silicon is rumored to feature up to 32 RDNA2 compute units that amount to 2.048 stream processors, a PCI-Express 4.0 x8 host interface, much like the RX 5500 XT, and a 128-bit wide GDDR6 memory interface.
3,794 (0.80/day)
System Name Cyberline
Processor Intel Core i7 2600k
Motherboard Asus P8P67 LE Rev 3.0
Cooling Tuniq Tower 120
Memory Corsair (4x2) 8gb 1600mhz
Video Card(s) AMD RX480
Storage Samsung 750 Evo 250gb SSD + WD 1tb x 2 + WD 2tb
Display(s) Philips 32inch LPF5605H (television)
Case antec 600
Mouse Elecom EX-G
Keyboard Rapoo V700
yours for only "insert way too high pricetage here"
13,194 (4.97/day)
Sunshine Coast
System Name Black Box
Memory G.Skill 16GB 3600 C18
Audio Device(s) No need.
Power Supply FSP Aurum 650W
Mouse Yes
Keyboard Of course
Software W10 Pro 64 bit
OEM only most likely for now.
At least we know H.P. will have them.
169 (0.10/day)
System Name Linotosh
Processor Dual 800mhz G4
Cooling Air
Memory 1.5 GB
Another card that will be purchased by bots and go to miners and scalpers.
3,616 (3.37/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
Without ETH hashrate limiters, the miners that don't buy 3060 cards will likely be botting to get every last one of these instead.
325 (0.05/day)
Huge gap between 6600XT and 6700 in TBP, 130W respectively 230W (source: https://videocardz.com/newz/amd-radeon-rx-6600-xt-with-navi-23-gpu-pictured). I believed it would be like~170W.
That room is probably for a 6700 non XT
With a 128 bit bus, the hashrate won't be super high. So it will depend on the price instead. AMD hash limiter is the infinity cache/smaller memory bus
3,616 (3.37/day)
Case Veddha T2
Mouse MX Anywhere 2
The 6700XT still gets 48MH/s on its 192-bit bus. That means that this 6600XT could get somewhere in the ballpark of 32MH/s which is still better than most of Turing and Polaris, impressive for such a small, 128-bit chip.
It may be a moot point if ETH completely tanks before these are available, but I wouldn't hold your breath on that. ETH is still worth more than it was 3 weeks ago and we're likely just seeing a knee-jerk reaction to the Chinese government news. Everyone gets their pants in a twist with cryptocurrency spikes and crashes, but that's the nature of cryptocurrency and its been doing that for the last 8+ months now.
34 (0.02/day)
Processor AMD Ryzen 5 3600
Motherboard Asus ROG Strix X470-F
Cooling Reeven RC-1205
Memory G.Skill F4-3200C16D-16GTZKW TridentZ 16GB (2x8GB)
Video Card(s) Powercolor x470 red devil
Storage Mushkin MKNSSDPL500GB-D8 Pilot 500GB
Display(s) Samsung 23"
Case Phanteks PH-EC300PTG
Audio Device(s) SupremeFX S1220A
Power Supply Super Flower SF-650F14MT(BK) Leadex 650W 80 Plus Silver
Mouse Cooler master m530
Keyboard Cheapo
AMD suck at mining in anyway so I do not think people will be buying this for mining 128bit or limiter will not matter.
Biggest issue here is the bus speed of this card only runs at 8x not matter PCI4 or PCI3 older boards will suffer more pre 5 series.
3,616 (3.37/day)
Case Veddha T2
Mouse MX Anywhere 2
https://whattomine.com/gpus
That gives you hashrates of all relevant mining GPUs.
AMD appear to beat Nvidia for both Hashrate/Watt and Hashrate/$, so what makes you say AMD suck at mining? They seem to be better in every metric that matters for mining. Even if you use the completely unrealistic MSRP, AMD are still tied with Nvidia, but that's a ridiculous argument because MSRP is currently a myth.
r9
2,936 (0.60/day)
System Name Primary | Secondary | Poweredge r410|Dell XPS
Processor i7 9700k| Ryzen 1600| 2 x E5620 |i5 5500U
Memory 16GB DDR4 |16GB DDR4 | 32GB ECC DDR3|8GB DDR4
Video Card(s) GTX 1070|2 x RX570 |On-Board|On-Board|
Storage 512GB SSD+1TB SSD|512GB SSD+1TB|2x256GBSSD 2x2TBGB
Display(s) 50" 4k TV | 27" + 2 x 24" LCD Setup
VR HMD Samsung Odyssey+
Software Windows 10 |Windows 10| Server 2012 r2
Can't wait for the crypto bubble to burst which it will and it will be a loud pop.
Might take a while before miners lose hope but the time is coming where the market will overflow with cheapo cards.
You and your facts ...
1,393 (0.34/day)
BTC dropped from 60k to 28k. I'm kind of laughing now knowing it lost value of over 32k in less then a week.
It means that the value for the alt coins as well lowered significantly. BTC back to 2500$ would be best for everyone.
Apart from that, this could be a perfect upgrade from a Polaris.
34 (0.02/day)
Keyboard Cheapo
used this site: Guess they might be wrong then.
AMD 6900XT vs 3090: https://www.nicehash.com/profitability-calculator/amd-rx-6900-xt-16gb/nvidia-rtx-3090
Showing Nvidia twice as good and double the earning potential of AMD top card vs Nvidia top card.
13,194 (4.97/day)
Sunshine Coast
Mouse Yes
Keyboard Of course
They might have forgotten to set the AMD GPU to compute.
3,616 (3.37/day)
Case Veddha T2
Mouse MX Anywhere 2
Profitability needs to take into consideration the power draw and the purchase cost.
If you ignore those things then the best mining card is the €12500 Nvidia A100 with 40GB of HBM2 and this entire coversation is pointless. As you can see, I'm not ignoring those two things because those are the two most important factors.
Nvidia cards cost more to buy per hashrate, and they cost more to run. If your energy is only $0.1/KWh then energy costs will have less of an impact but energy costs are 2-3x that in Europe so it matters a lot.
AMD's current lineup isn't much better for mining than their previous generations, but they're still slightly better options than Nvidia's Ampere cards in the two metrics that count - Hashrate/$ to buy and Hashrate/KWh to run. These numbers don't even factor in that new Nvidia cards are LHR variants that are crippled for mining, and Nicehash is less profitable than Etherium but some Nvidia cards are so terrible at Etherium that Nicehash is their only sensible option.
MaenadFIN
S.T.A.R.S.
7,058 (2.12/day)
Jyväskylä, Finland
System Name Snow White
Processor AMD Ryzen 5 3600 @ PBO +200
Motherboard Gigabyte B550M Aorus Elite
Cooling Alphacool custom loop, Corsair fans
Memory 32GB HyperX Fury DDR4-3200 @ 3466 CL16
Video Card(s) Gigabyte GeForce GTX 1080 Ti Gaming OC Black @ +100/625
Storage 840 Pro 256GB + 3x A400 480GB + 2x Toshiba 128GB + 2TB USB HDD
Display(s) Viewsonic VA2465S + Dell P2412H @ Arctic Z2 gen3
Audio Device(s) Onboard audio, Superlux HD668B
Power Supply Seasonic Focus+ Gold 750W (FX-750)
Mouse Logitech G MX518 Legendary
Keyboard NOS C450 Mini Pro RGB
VR HMD Oculus Rift CV1
Software Windows 11 Pro English
Benchmark Scores 24164 on Fire Strike
As well as paying income taxes from the profits.
7,088 (3.84/day)
System Name Good enough
Processor AMD Ryzen R7 1700X - 4.0 Ghz / 1.350V
Motherboard ASRock B450M Pro4
Cooling Deepcool Gammaxx L240 V2
Memory 16GB - Corsair Vengeance LPX - 3333 Mhz CL16
Video Card(s) OEM Dell GTX 1080 with Kraken G12 + Water 3.0 Performer C
Storage 1x Samsung 850 EVO 250GB , 1x Samsung 860 EVO 500GB
Display(s) 4K Samsung TV
Case Deepcool Matrexx 70
Power Supply GPS-750C
I'm not so sure, the low memory bandwidth will be a real problem with these for mining.
3,616 (3.37/day)
Case Veddha T2
Mouse MX Anywhere 2
The 192-bit memory bandwidth of the 6700XT didn't seem to offput the miners at all. If this 128-bit card puts out two-thirds of the hashrate for two-thirds of the purchase price and power usage, the miners will be all over them like flies.
In addition, there will be fewer Nvidia cards they want to buy thanks to the LHR changes to all Geforce cards from now on.
7,088 (3.84/day)
6700XT has a hashrate of about 40 Mh/s if I'm not mistaken, that's already quite anemic for the price and power, in fact it's worse than a 5700XT. A 6600XT will probably be in the region of 30 Mh/s or below, you're looking at 2016 Pascal levels of mining performance for a lot more money. Thing is retail miners will probably still try to get these because some of them are willing to mine irrespective of how poor the profitability gets but large mining farms that make up the bulk of where these cards go, nah, they'll probably avoid them.
I am not saying these wont be expensive, they will, because the entire GPU market is like this, even cards that can't be used for mining are insanely overpriced. I am just saying these wont be a priority for most miners.
3,616 (3.37/day)
Case Veddha T2
Mouse MX Anywhere 2
Oh there's no denying that the 6000-series cards are inferior to their equivalent 5000-series cards for mining, but the 5000-series are out of production and it's not like the 6000-series cards are bad, they're just 20% worse than "excellent" which is still "good"
For the large-scale purchasing that warehouse-sized mining farms buy via bots, it's Ampere vs RNDA2 and the 6700XT mines at 48MH/s just like the 3060 with the unrestricted driver. Miners will definitely choose AMD over Nvidia once the LHR cards hit the market, and at the moment both AMD and unrestricted Nvidia cards are fair game for the purchasing bots alike.
RX570 8GB farms are still common at "only" 30MH/s. People who didn't sell their rigs when 2018's minig bubble burst are still very active and profitable on the usual forums.
100 (0.20/day)
System Name Home
Processor 2700x
Motherboard Asrock Taichi x370
Cooling Thermalright True Spirit 140
Memory Patriot 32gb DDR4 3200mhz
Video Card(s) Sapphire Radeon RX 480 NITRO+
Storage Too many to count
Display(s) U2518D+u2417h
Case Chieftec
Power Supply Chieftec 700W
Mouse Logitech g502 hero
Keyboard Logitech
Software Windows
They can keep it, nobody wants it at 1000$ or something like that.
6700 XT in my country is now 1800$, in stock everywhere.
1 (0.06/day)
System Name HP OMEN 25L
Processor RYZEN 7 5700G
Memory 16 GB HYPERX FURY 3200MHz
Video Card(s) AMD RADEON 6600XT
I just bought a HP OMEN 25L gaming desktop that has this RX 6600XT along with a RYZEN 7 5700G for £1,099. This GPU performs really well at both 1080P and 1440P and stays really cool and quiet.
