Anyone Recommend A GPU Fan Control&Temp Program?
457 (0.07/day)
System Name The Terminator.
Processor Intel i7 950 3.06Ghz.
Motherboard Asus P6X58D-Extreme
Cooling Stock.
Memory Corsair 6GB (3x2GB) DDR3 2000MHz Dominator-GT Memory Kit CL8 (8-9-8-24) 1.65V
Video Card(s) Sapphire HD 6950 2GB GDDR5.
Storage WD 1TB 3.5" SATA-III 6Gb/s / OCZ Vertex 120GB SSD.
Display(s) 24'' Widescreen Samsung 1080p.
Case Antec 1200 Gaming Case.
Audio Device(s) Realtek.
Power Supply TX 650W Corsair
Software Windows 7 Enterprise 64 bit
Title says it all; Need a Temperature & Fan Controlling program other than ATi Tool as i do not like this program one bit and i'm not interested in overclocking.
Thanks.
Title says it all; Need a Temperature & Fan Controlling program other than ATi Tool as i do not like this program one bit and i'm not interested in overclocking. Thanks.
Why don't you like it? I'm having issues with it and an X1900 right now, so I'm looking for the same. RivaTuner came up a few times in discussion.
ATITool worked like a champ for my X800GTO, a fantastic tool in my opinion.
ATi Tool absolutely sucks for my X1900XT - i even have a feeling its done something to my fucking card which im really pissed off about right now.
Riva Tuner is an Nvidia only tool as far as i know and doesnt work with ATi cards?
Thanks...
Thanks...
Same boat here... I haven't tried RivaTuner - read it has "limited" support for ATI cards. If you are in the situation I'm in, you quickly find with ATITool running, everything is controlled by the 2D clock settings. (ATITool does not yet suppport the two modes!)
I think I'm going to ditch ATITool for the meantime and just go with CCC. When I finally determine I'm good to go, I've got a GPU watercooler to replace the shop-vac on the card. Here's a good thread on ATITool and the 2D/3D X1900 modes.
http://www.techpowerup.com/reviews/Diamond/X1900XT/6
SASQUI - I just read that guide - it says there should be 3 services running
# Ati2evxx.exe
# ATI HotKey Poller
# OverClocker.exe
I ONLY HAVE ONE SERVICE RUNNING!? (# Ati2evxx.exe)
What happened to my other two??? Would this be causing my performance issues?? I dont have ATi Tool installed anymore.
Someone please help as this could explain my performance issues im experiencing right now, it might not be shifting to 3D mode.
# Ati2evxx.exe
# ATI HotKey Poller
# OverClocker.exe
Same boat again - I was getting 7000 in 3DMark05 which tells me I'm in 2D clock mode even in 3D. I think everything needs to be uninstalled (ATITool, and All CAT drivers), then reinstall CAT drivers. I haven't had a chance to try it yet.
Oh and Cat 6.9 is out! Another reason to uninstall: https://support.ati.com/ics/support/default.asp?deptID=894&task=knowledge&questionID=640
Can anyone comment?
Sasqui - I reinstalled my CAT drivers. It was screwing up, once i had installed the cat drivers nothing worked. It was acting as if i hadnt installed them. Same happened with the 6.9 until i went into the directory and selected the display driver setup. Only then did it respond to my graphics card although i still feel my performance is screwed up and should be a lot better when playing company of heroes for egsample. Load times are also SLOW! Argh! Why is it doing this?
Wizzard!? Someone else?
ati hotkey poller is a SERVICE not a process .. go to your services control panel it's listed there
overclocker.exe is the process name of the ati overclocking application .. if you dont install it and dont click the icon it's not running
Okay, Hotkey poller is actually running in Services. As for the overclocker.exe, i guess thats not running if its not under my processes - should this be running? As for the icon & install, i dont know where that is?
Sasqui - Ahead of you there mate, already did that 3 times over. Let me know how you progress - still getting performance issues?
Shit... unistall 6.8, run driver cleaner... three times! Install CAT 6.9 3DMark05 score = 7400. It appears that the 2D speeds are being used. Someone help me! I do not want to RMA this card, and I have 4 days left to get the rebate.
HL2 Banchmark at 1024x768 - is this good?
Thats a good score, not sure what sorta score you should be getting with an X1900XT though mate.
*Sigh* I feel for ya dude, somethings definately up cos a 7400 score with 3DMark05 aint right. Try taking the card out and re-inserting, MIGHT reset the clock speeds. Other than that i'm not sure what to do, there needs to be some sort of damn support for these relatively serious side effects after using ATiTool.
Have you ran 3DMark06 benchmark?
Have you totally uninstalled ATI tool, deleted all files and gone into Catalyst Control Centre and hit preferences > Reset to factory defaults?
If i were you i'd get that RMA ready, file the form so you can send it off ASAP as a last resort if you dont fix the issue.
Damn ATI tool!
yoyou know thats why its beta:shadedshu maybe systool not familiar w/ this stuff as i only use coolbits yeah nvidia:D
