Are there wear problems from partitioning a SSD?
1,665 (2.73/day)
6% wear for ~46TB over 7-8 years.
In terms of unallocated, I did some research before making my partitions, and I have 140mb unallocated MSR, not sure if that's relevant at all.
My original partition layout for the SSD and Windows was the following:
GPT
480mb - NTFS, label: Recovery
280mb - Fat32, label: EFI
140mb - Unallocated, MSR, label: Reserved
40.02gb (40981mb), NTFS, label: Windows
408.02gb (417813mb) NTFS, label: Master
16.84gb (17245mb) NTFS, label: Page
Still much the same now, but as secondary:
5,230 (5.79/day)
Texas
System Name Ghetto Rigs x299 & z490 & x99
Processor 9940x w/Optimus SigV2 & 10900k w/Optimus Foundation & 5930k w/Noctua D15
Motherboard X299 Rampage VI Apex & z490 Maximus XII Apex & x99 Sabertooth
Cooling D5 combo/280 GTX/ VRM water block copper/280 GTX/ D5 Top/Optimus sigV2/TitanXp/Mora 360x2
Memory Trident-Z 3600C16 4x8gb & Trident-Z Royal 4000c16 2x16gb & Trident-Z 3200c14 4x8gb
Video Card(s) 1080ti FTW3 & Titan Xp & evga 980ti gaming
Storage 970 evo plus 500gb & 970 evo 500gb many sammy 2.5" ssd's and WD BLK hdd's
Case D450 second floor for 2nd rad x2/ Cherry Entertainment center on Test bench
Power Supply EVGA 1200P2 & 1000P2 with APC AX1500 & 850P2 with CyberPower-GX1325U & 750P2
Mouse Redragon Perdition x3
Keyboard G710+x3
Software Win-7 pro x3 and Linux Cinnamon 20.2x2 & win-10 & 11pro x3
People aren't gunna learn if they don't ask questions and get answers
Guessing you missed the /end of thread bit kudos for that and all others that keep commenting :cool:
929 (0.72/day)
UK, Leicester
System Name Main PC
Processor 9900k@4.8ghz 1.25v
Motherboard Asrock Fatality K6 Z370
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Video Card(s) 3080 RTX FE
Storage 980 PRO 1TB (OS, others not listed)
Display(s) LG 27GL850
Case Fractal Define R4
This document by Intel explains some basics and also has some calculations for Intel drives. Basically, any free space within a partition is as good as unpartitioned (=guaranteed to be always free) space. As long as you're able to keep ~20% of total drive space free, most of the time, you're good, and you gain a lot of endurance. Most of the time doesn't even mean all of the time, so you can still do some large transfers that fill up all of the drive occasionally.
Edit: even on spindles it's not 1 to 1. The difference is that the mapping doesn't change every day, it only does when the drive finds new bad sectors.
Thats true, I never said you had to leave it unpartitioned, but various manufacturers still reccomend doing so. Probably because people can accidently use free space easily.
Mussels
Freshwater Moderator
54,431 (8.35/day)
Oystralia
Processor Ryzen R7 5800X (PBO tweaked, 4.4-5.05GHz)
Motherboard Asus x570 Gaming-F
Cooling EK Quantum Velocity AM4 + EK Quantum ARGB 3090 w/ active backplate. Dual rad.
Memory 2x32GB DDR4 3600 Corsair Vengeance RGB @3800 C18-22-22-22-42 TRFC704 (1.4V, SoC 1.15V Hynix MJR)
Video Card(s) Galax RTX 3090 SG 24GB: Underclocked to 1500Mhz 0.737v | 1600Mhz 0.75v | 1900Mhz 0.9v
Storage 2TB WD SN850 NVME + 1TB Sasmsung 970 Pro NVME + WD AN1500 1TB + 1TB Intel 6000P NVME USB 3.2
Display(s) Kogan 32" 4K 72Hz +Gigabyte G32QC (1440p 165Hz) + Phillips 328m6fjrmb (1440p 144Hz)
Case Fractal Design R6
Power Supply Fractal Ion+ 2 860W (Platinum)
Keyboard Razer Huntsman TE (custom white and steel keycaps)
VR HMD Oculus Rift S
Software Windows 11 pro x64 (Yes, it's genuinely a good OS)
Benchmark Scores I don't quite know how i managed to get such a top tier PC, I am not rich.
~10TB writes in 6 years is like a drop in the endurance bucket though.
There are drives with really low TBW lifespan these days, which would be scary for anyone except users like that
I found some new drives for sale right now, with only 40TBW. Sad to think i'd kill that drive in 1-2 years with just windows and steam.
Mine are at 55TBW (1TB) and 32TBW (2TB, newer) - I'm not a heavy user, that's just like 3 years and 1.5 years as OS and gaming drives
So uh, why are you in charge of that?
You aren't a moderator, or the OP of the thread - and you're giving out incorrect terrible advice that's not based in reality whatsoever.
Take some time out to reflect on the attitude, before it's forced on you.
856 (1.46/day)
Slovenia
Processor i5-6600K
Motherboard Asus Z170A
Cooling some cheap Cooler Master
Memory 16GB DDR4-2400
Video Card(s) IGP
Storage Samsung 850 EVO 250GB
Case Bitfenix Nova white windowless
Power Supply Seasonic G-360
Software Oldwin
/end of thread means end of end of thread, I'm fine with that
./endofthread, as it was originally put, means ... something scary in Linux?
What capacity? Also, do they look at least half-legit, judging by things like price/TB?
1,694 (0.88/day)
I just want to point out some older Samsung SSD are still under warranty despite it's age. Do they still offer 10+ year warranty in the year 2022?
19,905 (5.99/day)
USA
You're picking a fight with a moderator when no one said anything to you. You want to not do that. Just throwing it out there...
6,812 (3.53/day)
Norway, currently in Lund, Sweden
System Name Hotbox
Processor AMD Ryzen 7 5800X, 142/95/120, PBO +150Mhz, CO -7,-7,-20(x6),
Storage 2TB Adata SX8200 Pro
Case SSUPD Meshlicious
Keyboard Cooler Master MasterKeys Pro M w/DSA profile caps
Wait, what? What capacities are those 40TBW drives? That sounds scary low indeed - but remember that it's a lot harder to write that much data to a lower capacity drive in the first place, as the overhead over "files that are always there" on a system install is much lower. If they're 256GB or something, I wouldn't be worried even by that rating.
6,812 (3.53/day)
System Name Hotbox
Low end QLC based drives.
I did a quick skim across cheap QLC drives on Newegg, and while most didn't list TBW ratings, the lowest I saw were 512GB drives at ~170TBW. Now, I also discovered that 128GB QLC SSDs actually exist (ewwwww), and I can't imagine those having much of an endurance rating. But then again you wouldn't really be able to write that much to a 128GB drive anyway, so the point is mostly moot. On the other hand, if there are 512GB or above QLC drives with endurance raitings that low, I'd treat them as WORM drives, and definitely not use them as a system drive. They can't be that much cheaper than a cheap TLC drive.
13,170 (2.17/day)
Processor Intel i7 12700K / Intel i3 7100U
Audio Device(s) ALC1220-VB + ESS ES9118 DAC / Realtek onboard + B&O speaker system
Benchmark Scores Cinebench R23 (Single Core) 1911 @ stock Cinebench R23 (Multi Core) 22813 @ stock
No, all of them including the Pro SSD/NVMe's are now 5 years warranty only.
1,694 (0.88/day)
You would think with all the improvement's over the years it will remain the same or better, but it's being cut in half. I wonder why, because this is a step backwards.
13,170 (2.17/day)
As far as I know the 2.5" 850 serie was the last with 10 years.
I still have an 850 Pro 512GB with 3d v-nand (MLC).
Samsung now only makes drives with 3d v-nand (TLC) or 3d v-nand (QLC).
The TLC comes with a 5 year warranty
The QLC comes with a 3 year warranty (the cheapest)
13,170 (2.17/day)
5,230 (5.79/day)
Texas
Keyboard G710+x3
Tad out of placement onemoar originally said it I just kudo'd for not listening to his statement
Not sure what terrible/ bad advise you're referring to either.
All my os ssd's are this size
I do have some personal files like music/ images/ programs on them to so not all personal files are on different storage drives but back ups are.
None have out and out died except one linux mint killed long ago by never running trim on it seemed to be a crucial firmware bug clash with mint 17
Replacement mx100 256gb still works to this day.
I don't partition ssd's though beside a single system reserved in the front otherwise the rest spans except a little unallocated space at the end for the firmware to use for over provisioning
Can't be this
Yep if you've ever used samsung magician and had it do the over improvising for you you'd see unallocated space after this is all the firmware needs.
I'll add the firmware also only needs zero activity to do it's work/ hibernation...
Or this
19,905 (5.99/day)
USA
They are fine for game storage, I just wouldn't use them as OS drive with windows pagefile...
Sure, not a whole lot of data changing happens to a game install once installed. QLC drives make good and less expensive drives for data backups as well. Just not an OS/heavy use drive.
Mussels
54,431 (8.35/day)
Oystralia
This thread might have needed a cleanup, but any perceived grumpiness got sorted out via PM's
Let's keep things nice, we all seem to have different views on SSD's but seriously - there are garbage drives out there, and a lot of garbage information too. Things change in the SSD world, common knowledge from the SLC days means nothing on a QLC drive.
This thread has changed topic, because we got the answer to the OP's question (no) - but we're still discussing the actual concern of SSD wear
I'll summarise the entire mess below into: You can buy 1TB drives right now, that range from 1,200TBW to 80TBW.
I've only spent 15 minutes looking into this, i'm sure worse drives exist out there.
Smaller SSD's are at the highest risk of more TBW, because the simple fact of running out of room means you need to delete things and likely re-create them later. Even automated windows tasks like the page file behave this way, with greater storage space helping alleviate re-writes.
I wrote some big annoyed rant a while back about samsungs naming scheme and how a 980 pro has half the TLC of a 970 pro - and every new release (evo, evo plus, evo plus plus, whatever - was it the SD cards that did that?) was fairly consistent, until now when it smashed backwards.
Modern SSD's went backwards in TBW, fast. Theres a lot of 250GB and under drives with low TBW's and some brands that refuse to even advertise them, and give you "hours" instead.
Lower capacity drives often have more writes, not less - a PC gamer is going to delete games to install a new one far more times than a user who installs and leaves it there.
Deleting to free up space, only to re-create is the worst case scenario here.
From here on i'm only comparing NVME drives that are for sale today.
Ranked in order of samsung as reference, then best to worst.
Keep in mind, these are considered the top tier premium drives by manu
Sticking to just the 1TB models since every series has them:
980 Pro: 600
980: 600
970 pro: 1200
970 Evo plus: 600
970 evo: 600
980 (regular)
Evo plus range:
970 evo range
What about their QLC range, well known for being cheap, at the reduction of lifespan?
360TBW. Honestly, it's low but it's not terrible - and they get much more reasonable on the bigger models.
So if samsung, the king of consumer gaming SSD's are going backwards (the 980 series) what about other brands?
Team MP34:
Huh. That's actually impressive.
XPG's SX8200 Pro?
Not so bad, on par with samsung.
Crucial P2 series:
Basically, halve samsungs. Except for the 970 pro, quarter that.
Kingston's NV1 range:
Oh, making crucial look good here.
WD green? Oh no. Oh fuck no. 80 TBW for the TLC 960GB and 100TBW for 1TB and 2TB QLC
From 1200TBW to 80TBW.
In Sata SSD's, things are just depressing.
These are generally on par with small NVME drives, but you can imagine these drives would end up with data deleted and created far more often than bigger drives that can retain data easier
These 40TBW drives wouldn't last me as an OS drive for a year.
Kingston A400:
Crucial BX500:
WD dont even list the TBW for their WD green SATA drives, they know its so bad. They state "upto 1 million hours" instead for all drives
6,812 (3.53/day)
System Name Hotbox
980 Pro: 600
980: 600
970 pro: 1200
970 Evo plus: 600
970 evo: 600
980 (regular)
Evo plus range:
970 evo range
Team MP34:
XPG's SX8200 Pro?
Crucial P2 series:
Kingston A400:
Crucial BX500:
That's a bunch of useful info, thanks!
One objection though: I don't agree with smaller drives being prone to more writes as a general/linear rule. Why? Because as size goes down, they don't have room for further writes on top of the base software that stays installed at all times - whether that is an OS and basic software, or a game drive with the handful of games that are played regularly and kept. With current AAA game install sizes, larger SSDs also afford installing multiple large games in a way that simply isn't possible on a smaller drive even with deleting a lot of stuff. In short, this being a linear relation seems too simple to me. I would assume there's a kind of bell curve for SSD writes/lifetime, where the amplification due to space constraints that you describe most likely happens in the 500-1000GB range, but is unlikely to happen at 256GB, let alone 128GB - and a 2TB or larger drive might see a relatively lower amount of writes per capacity due to there being less need to delete stuff. Nobody running a 256GB SSD is going to regularly install 50+GB games, uninstall them soon after, and install another 50+GB game in their place. And if you're running a 128GB SSD, even as a game drive, you don't have the capacity to do a lot of writes at all, assuming you're not just stress testing the SSD with writes constantly.
Sadly all of my old low capacity drives are either in my NAS or hooked to consoles that don't allow for host writes to be read from them (why TrueNAS doesn't let you see total host writes though, that's weird), but my old 500GB 960 Evo system drive - which was paired with a 500GB SATA SSD as a game drive, but games were installed on both due to capacity - has seen ~31TB written since I bought it in late 2017, being used as a portable drive (with a not insignificant amount of writes) since I upgraded to a 2TB drive last year. That 2TB drive has seen 16TB written since April last year - and, of course, there's a big boost in writes early in a drive's lifetime. Normalizing for capacity, the 500GB drive has seen more writes/year than the 2TB drive (31/5/0.5 = 12.4 drive writes/year vs. 16/1.3/2 = 6.2), but in raw data the 2TB drive has seen ~2x the data written per year.
Mussels
54,431 (8.35/day)
Oystralia
In my gaming group we have two users with 240GB SSD's
Both have to uninstall one game, to fit another (Be it CoD, WoW, Ark, or whatever) - they're my insight into this.
They eventually go back, adding a whole extra set of (large) writes that a bigger drive would never have had to do
You're using NAS drives in a NAS, which isn't exactly the same thing as windows or games drives, where a user has to make regular decisions about deleting A to fit B, and then deleting B to fit C or go back to A
I do agree it's only a potential situation, but as it's one i hear about regularly from those two gamers it does come to mind as a problem
One of them regularly downloads shows to his SSD, watches, deletes - and then rewatches a week or two later. He's managed to kill three WD greens this year alone, because he simply can't accept torrenting to it is sheer madness.
6,812 (3.53/day)
System Name Hotbox
I get that, but how often does that happen, and does that cancel out the "Sure, I've got room for this game too" effect of higher capacity drives? And, the lower capacity you go, the higher the chance of you not being able to clear up enough room to install something new without sacrificing something you'd really prefer to keep. Unless you have the privilege of extremely fast internet access, I guess.
Hm? I said I can't read out the host writes data from my NAS, so I sadly can't check those (older, lower capacity drives). The ones I wrote about were my previous and current main system drives, the older one of which now lives in an external enclosure as a "thumbdrive".
Well, torrenting to any low grade SSD is madness, so ... that is what it is. The write amplification on those small blocks of data must be insane. At this rate it sounds like he'd be better off just ... buying an external HDD? Or an internal one if he's got the room? Heck, if he's going through SSDs at that rate he could probably save money in the long run just buying a NAS, even with their high base cost. But that's another issue entirely :p This definitely sounds like a rather extreme edge case IMO.
1,552 (0.37/day)
A 500GB drive here has 64GB of overprovisioning. That is used to kind of extend the drive's life. The more you assign to it (just a Unallocated chunk of space) the longer your drive will last.
Partitioning does'nt help at all really; i think it's the controller that decides which bit is stored where. These are'nt traditional HDD's with potential bad sectors.
6,812 (3.53/day)
System Name Hotbox
I think you've got the OP's question backwards: they were asking if partitioning would increase SSD wear, not if it could be used to work around bad sectors. But that's pretty much settled (as you say, the controller puts data wherever it wants, so partitions only exist on a file system level), as @Mussels said above the topic has changed to one of general SSD wear discussion.
