ARGB & Fan Power advise
49LONE82
3 (0.08/day)
k so I'm doing my first Water cooled, ARGB Everything build. TT Tower 900 Case, MSI MEG x570 Godlike Motherboard w/ AMD Ryzen 9 3900x. It's a big one. I have 13 x 140mm ARGB fans (8 x Coolmaster MasterFan MF140R, 5 x Thermaltake Riing Trio 140mm. About 8 ARGB Tubing connecters (TT), ARGB CPU Water Block (Corsair Hydro X Series, XC7 RGB), ARGB GPU Water Block (Bitspower Lotan VGA Water Block for ASUS ROG Strix GeForce RTX 20 Series), 2 x ARGB Pump/Reservoir's (Thermaltake Pacific PR22-D5 Plus) & probably a couple ARGB LED Strips..... Ohh.. and a ARGB PSU(TT 1200W) Would like it all controlled with Software but I'm dumbfounded on how to hook it all up. Need some advise. Thanks
3,164 (1.17/day)
GMT +2
System Name Red Radiance l under construction
Processor 2600x
Motherboard x470 taichi
Cooling stock wrath
Memory TridentZ rgb 3200mhz (2x8 kit)
Video Card(s) Sapphire Vega 64 nitro+
Storage 970 evo nvme
Display(s) c27gh70
Case tt core x5 tge
Audio Device(s) sennheiser's pc323d usb soundcard
Power Supply corsair AX860i
Mouse roccat leader
Keyboard roccat ryos mk fx
Software windows 10
2,067 (0.83/day)
If'n I tellz ya, den I gotzta, well, you know....
System Name The Big RED One
Processor i9-9900k, oc'd to 5.2 ghz
Motherboard Asus ROG Maximus Hero Wifi Z390
Cooling Corsair H115i pro AIO 280mm push/pull, 11x Corsair 140mm ML RGB Fans (top, sides, rear)
Memory 32GB Corsair Vengence RBG pro DDR4-3200 (4x 8GB) in XMP2
Video Card(s) MSI Seahawk 1070 w/15% o/c
Storage 2x WD Black SN750 1TB m.2 + 4TB Crucial SSD + WD 8TB external
Display(s) 2x Samsung 43" LCD's @4k-1440p
Case Thermaltake TT900 Supertower
Audio Device(s) Built-in
Power Supply EVGA G2 SuperNova 850W Modular
Mouse Logitech MX Master 2
Software Windows 10 pro 64 bit, with all the unnecessary background shiite turned OFF !
Benchmark Scores Quicker than flies on a dung pile
Looks like thats gonna be a helluva rig when finished. I built my current rig 2 yrs ago with the same case and it was such a joy to work in, soooo much room for everything...
Even though I did not w/c it, I also have 13 fans, a 280mm AIO cooler and w/c Seahawk GPU, so lots stuff in there with plenty of room still available for other stuff...
But I used a digital fan controller in the 5.25" slot, with some 2>1 & 3>1 cables to get all the fans connected to it, and my light strips are connected to a lighting controller module, nottaproblemo...
Good luck with your build :peace:
3,164 (1.17/day)
GMT +2
Processor 2600x
Cooling stock wrath
Display(s) c27gh70
Case tt core x5 tge
Mouse roccat leader
Software windows 10
meh.
if you planned to make fancy painting why didnt you got single color fans and use controller to set proper color for wb/fittings.
now rainbow blink will take away attention from cool paint.
49LONE82
3 (0.08/day)
meh.
More options with addressable including single color
3,164 (1.17/day)
GMT +2
Processor 2600x
Cooling stock wrath
Display(s) c27gh70
Case tt core x5 tge
Mouse roccat leader
Software windows 10
but also far more complicated setup for color control.
single color fans need just power plug and work from just any fan header at the cost of ~1W higher power draw.
anyway dont forget to post the video with all blink turned on :)
2,067 (0.83/day)
Almost done with the Painting, Motherboard post test was a success..... More to come
WOW....
just friggin...
W..O..W...:peace:
Great job, kinda reminds me of some stainless steel plating that someone I know went after with a drill-mounted wire brush and got a bit too agressive with it, and then added some black highlights to make it look really coooool..
12,753 (5.93/day)
Mars
Processor i7 8700k 4.7Ghz @ 1.26v
Video Card(s) MSI GTX 1080 Gaming X @ 2100/5500
Display(s) Eizo Foris FG2421
Case Fractal Design Define C TG
Power Supply EVGA G2 750w
Mouse Logitech G502 Protheus Spectrum
Keyboard Sharkoon MK80 (Brown)
Software W10 x64
That is a pretty killer paint job man. A bit busy for my taste, but definitely well done.
But yeah, this could use some understated, single color ARGB theming to tone the whole thing down. I reckon you do want to look at the monitor at some point in time right? :p
I'm almost sure you considered it, but colored lighting will make your highlights either stand out and reflect, or completely get absorbed. So different colors will change the patterns on your case as well. This is why single color, or single color in specific places is going to work well. Too many colors will mix and make it a garbled mess.
