- Nov 24, 2009
- 39 (0.01/day)
- Eire
System Name | Be very Quiet! |
Processor | Intel Core i5-2500k 4GHz |
Motherboard | Asus ROG Gene-Z |
Cooling | CPU: Noctua NH-U9B SE2. Case: aaiiirrr 2x12cm + 14cm |
Memory | 2x4gb Corsair Vengeance LP 1600Mhz 1.5V |
Video Card(s) | Asus HD6850 1GB DirectCU V2 840Mhz/1140Mhz |
Storage | OCZ Vertex 2 120gb v1.33 |
Display(s) | LED Acer 21.5" S221HQL DVI |
Case | Fractal design Arc Mini |
Audio Device(s) | Sound Blaster X-Fi 2 |
Power Supply | Be Quiet! E8-CM-580W Silver, 91 Eff @ 80% Load |
Software | Windows 7 Pro 64bit |
Benchmark Scores | \o/ |
I can't connect VGA cable into the slot on mobo
It goes in maybe 1mm but can't hold, doesn't go further inside
Tried to be gentle then a bit rough but still closed doors
Well this prob made me buy DVI cable finally hehe, which fits in fine BUT
1. Picture is not showing up until in Windows only, can't see post screen, BIOS, Windows logo loading.. picture shows up straight in loaded Windows
2. Sometimes I have to boot computer many times before I get picture
3. Sometimes I get "System recovered from serious error" in Windows
4. SATA disk AHCI mode doesn't work if onboard graphics set as default, does this make any sense?
I still didn't install VIRTU thingy, maybe this could make a difference? will try it today when back home.
is there any people with the same mobo? or ATX size Pro3. All good with yours?
