ASUS DUAL RTX 2080TI OC, Power target 400% and GPU clock 300MHZ
1,233 (0.31/day)
Heart of Europe
System Name ibuytheusedstuff
Processor 5960x
Motherboard x99 sabertooth
Cooling water
Memory 32 dual ranked
Video Card(s) 1080ti
Storage raptors+ssd
Display(s) 120hz
Case open bench
Power Supply antec 1200 oc
Mouse mx 518
Keyboard roccat arvo
is this a used card or new?
could be a shunt mod going wrong
1,841 (0.69/day)
KL, Malaysia
System Name The Rainbow Puke Machine (Upgrading to Ryzen; * = WIP)
Processor AMD Ryzen 5 3600 or 4xxx (Zen3)*
Motherboard AMD B550 ATX (ASUS ROG STRIX or Gigabyte AORUS)*
Cooling Corsair 120/240mm AIO* + HD120 RGB (2 intake, 1 ext) + SP120 RGB PRO (3 intake) + Commander PRO
Memory Corsair Vengeance RGB PRO 16GB (2 x 8GB) DDR4 3200MHz*
Video Card(s) Zotac RTX2060 Twin Fan 6GB GDDR6 (1.9GHz OC stable via MSI Afterburner)
Storage Samsung 960 EVO 250GB M.2 PCIe SSD + 1TB M.2 PCIe SSD (any brand, with or w/o Gen4)*
Display(s) LG 29WK600-W Ultrawide 1080p IPS w/ AMD FreeSync
Case Corsair iCUE 220T RGB Airflow (White) w/Lighting Node CORE + Lighting Node PRO RGB LED Strips (4).
Audio Device(s) Onboard HD Audio (Realtek based/modified) + Corsair VOID Stereo Headphones
Power Supply Corsair RMx 750W 80 Plus Gold Fully Modular
Mouse Corsair M65 RGB FPS Mouse (White)
Keyboard Corsair Strafe RGB Mechanical Keyboard (Cherry MX RGB Red Switches)
Software Windows 10 Professional x64 (April Update v2004)
flash the BIOS? It's a stretch but you can try that. Make sure you got the correct BIOS though. After that's done, use DDU to clean the drivers & install the drivers from Nvidia, not from ASUS driver support.
1,233 (0.31/day)
Heart of Europe
Processor 5960x
Cooling water
Storage raptors+ssd
Display(s) 120hz
Case open bench
Mouse mx 518
compare with your card if something is modified or looks off over the 5ohm resistors-could be solder or silver ink or liquid metal
replika
12 (0.13/day)
