Asus Strix 2070 Super stuck @ 0.7 Voltage with huge fps loss! Need Your Help!
1,490 (0.35/day)
Heart of Europia what!
System Name ibuytheusedstuff
Processor 5960x
Motherboard x99 sabertooth
Cooling old socket775 cooler
Memory 32 Viper
Storage raptors+ssd
Display(s) acer 120hz
Case open bench
Audio Device(s) onb
Mouse mx 518
Keyboard roccat arvo
never had a corrupted bios and i did flash a lot on cards from 8800 till 980ti and amd same.
maybe a near shop or friend can lend ya a psu or bring the card there and they can run a small bench-only way to say for sure is swapping
psu should be enough and if not for 2070 then ya will have probs with 5700xt. how old is it?
psu problems normally throw out different errors all the time not the same in a row
17 (0.04/day)
Canada
System Name fat rig
Processor 2700x@4.0
Motherboard asus x470 prime pro
Cooling Winter in Canada East
Memory adata 8gx2 @3000
Video Card(s) 2070 super asus strix rog
Storage 1t hdd west blue within 800gb porn
Display(s) No
Case Shoesbox
Audio Device(s) No
Power Supply superflower SF-550P14XE
Mouse Jerry
Keyboard Tom
Software PornHub
Benchmark Scores No
except swapping cards around, any method? I have no friends using a desktop QAQ
1,490 (0.35/day)
Processor 5960x
Memory 32 Viper
Storage raptors+ssd
Case open bench
Audio Device(s) onb
Mouse mx 518
ask a fellow canadian tpu user near you? if thats possible-my country is very small so i could drive to the end in 5 hours
is bestbuy a shop with a hardware return guy? if yes then go there and ask them to test your card for a small tip(normally they have equipment for quick tests)
is your motherboard asus x470 pro?? because i cannot find your bios version 1004?? did ya ever update it or is this the bios with which it was delivered
1,795 (0.98/day)
Buenos Aires
System Name Ryzen Monster
Processor Ryzen 5 5600X
Memory Corsair Vengeance 32GB (4x8GB) 2400Mhz
Display(s) LG 32GK650F-B 32" UltraGear™ QHD/Samsung C27F591 curved
Mouse Corsair M65 Pro
Software Windows 10 x64 Start 10
Benchmark Scores 3DMark Time Spy 4532
Perhaps you should see how the card runs on Windows 10 before returning it?
80 (0.15/day)
Processor Intel Core i5-3570k @ 4.2ghz
Motherboard ASRock z77 Fatal1ty Professional-M
Cooling Corsair Hydro H90
Memory 16gb G.Skill Ripjaws X Series DDR3-1333
Video Card(s) MSI Armour GTX 1070Ti
Storage Seagate Barracudo 500 gb HDD
Case Corsair Obsidian 350d
Power Supply Corsair TX750
May or may not be the problem, but Asus is recommending 650 watts for their 2070 Super 2070 Super Tech Specs
edit: for spelling
1,484 (0.45/day)
Anchorage Alaska
System Name Matter's / Helios 300 Predator
Processor Ryzen 7 2700 / i7 7700HQ
Motherboard B450 Tomahawk / Acer Helios 300 Predator
Cooling Arctic Freezer eSports Duo
Memory Patriot Viper ddr4 32gb / 32gb gskill ddr4
Video Card(s) MSI RTX 2080 Super Ventus OC / GTX 1060 6gb
Storage Patriot Viper nvme M2, crucial MX300 275gb, Samsung 860 qvo 1tb
Display(s) Acer 24" 1080p / 15.6 1080p HD
Case Antec 300 / Acer Helios 300 Predator
Audio Device(s) On Board - Steel Series Arctis Pro Wireless Cans
Power Supply Antec 850watt high current pro
Mouse Steel series Rival 600
Keyboard Corsair K70 / Acer Helios 300 Predator
Software Win 10 Pro / Win 10 Home
As @lmille16 pointed out for the super version of these cards, 650 watt psu is the minimum recommended. yes you can get away with less but minimum is 650, a 700 or 750 would be much better.
Also @Lucaxour stop using furmark to bench the card, use heaven or firestrike or valley.
17 (0.04/day)
Canada
System Name fat rig
Processor 2700x@4.0
Display(s) No
Case Shoesbox
Audio Device(s) No
Mouse Jerry
Keyboard Tom
Software PornHub
Benchmark Scores No
bios 1004 I mean AMD 1.0.0.4 because different mobo maker number their bios differently, so I just put the official amd version there for better understanding.....
I only have furmark and valley rightnow, you may check the screenshot while valley benchmarking on the very first post page...3dmark for some reason, I have tried many methods but all failed to install....
I know they recommend 650W psu, but I want to make sure if psu is true factor for my problem, because my local rertailers do not refund psu under any condition(I live in small town)
would you help me confirm the psu is the factor? but if psu is the problem, why GPU draws seemly its max power and performance under furmark but in valley and games get really low performance..?
Is there a windows 10 PE that I can test in...? I only have one HDD and unable to reinstall afterwards
563 (0.33/day)
System Name Main System
Processor i9-10940x
Motherboard MSI X299 Xpower Gaming AC
Memory G.Skill 64GB @3600MHz XMP
Video Card(s) ASUS ROG Strix RTX 3090
Storage 2TB Samsung 970 EVO Plus; 2TB Corsair Force MP600
Display(s) LG 43MU79-B
Case Corsair A540
Audio Device(s) Creative Lab SoundBlaster ZX-R
Power Supply EVGA G2 1300
Mouse Logitech MK550
Keyboard Logitech MK550
Benchmark Scores Cinebench R20 - 6910
You mentioned you had an AMD card installed previously. Did you perform a clean uninstall of the AMD drivers before installing the Nvidia drivers?
I suspect your PSU could be the problem here. It may not deliver enough power to the card via the 8 pin connector.
17 (0.04/day)
Canada
System Name fat rig
Processor 2700x@4.0
Display(s) No
Case Shoesbox
Audio Device(s) No
Mouse Jerry
Keyboard Tom
Software PornHub
Benchmark Scores No
only If DDU did not ensure a clear uninstall
1,484 (0.45/day)
Anchorage Alaska
Well you have 2 options here, RMA the gpu back to ASUS and wait for them to send you another one or go buy the proper recommended psu for the 2070 super. I would not buy just a 650w bare minimum I would go with a 750 watt just to be safe. If you do not like your local retail return policy then buy thru amazon or newegg. Either way you will need a bigger psu to properly run your gpu if you stick with the 2070 super. I am sure it has been asked already but all the power connectors are seated fully in the gpu? I had that happen once where one did not seat and the gpu ran like crap.
1,490 (0.35/day)
Processor 5960x
Memory 32 Viper
Storage raptors+ssd
Case open bench
Audio Device(s) onb
Mouse mx 518
do ya have the power supply version with 4xpci-e or only 2x ?
17 (0.04/day)
Canada
System Name fat rig
Processor 2700x@4.0
Display(s) No
Case Shoesbox
Audio Device(s) No
Mouse Jerry
Keyboard Tom
Software PornHub
Benchmark Scores No
@flmatter
@LFaWolf
@basco
@Vya Domus
@Toothless
updates: I got a corsair rm850x replacing my superflower550w, I reconnected every part, especially using 2 PCIE Cable connect to my gpu via 8+8pin
problems still exists, never exceed 0.76 Voltage in path of exile, gets like 30fps in town which is worse than my old msi gtx970....
In the valley benchmark, it hits 1.03V (I searched that should be proper voltage for 2070super), its core hits 1900mhz, but I am still getting max 60fps....which is abnormally low..
(I uninstalled the driver with DDU and update it to 440.61,)
14,535 (6.17/day)
Processor i7 8700k 4.7Ghz @ 1.26v
Video Card(s) MSI GTX 1080 Gaming X @ 2100/5500
Display(s) Gigabyte G34QWC (34'' 3440x1440x)
Case Fractal Design Define C TG
Power Supply EVGA G2 750w
Mouse Logitech G502 Protheus Spectrum
Keyboard Sharkoon MK80 (Brown)
Software W10 x64
interesting that ya have a dual bios switch but dont want to try it out but talk about flashing earlier-but thats fine with me-just interesting.
and on your furmark screenshot the card seems to run on higher clocks 1800\7000 - so for me it seems there is some other prob maybe but ...........
Furmark and clocks tell you exactly nothing. In fact, furmark entirely tells you nothing. Well, you know the card isn't artifacting, that's about it, and you can see it heat up. Its a pointless test, you can't see proper load behaviour with it at all. And its a silly test to be drawing any conclusions from. FYI & future reference.
@Lucaxour Nvidia cards need to work out of the box and boost properly with their stock BIOS. If they don't, card has likely been tampered with or is faulty to begin with. Stop wasting time, return the card and get another. I wouldn't even think twice, its not like you buy these at the dollar store.
BIOS updating on Nvidia cards is a risky affair. You can indeed brick cards with it, and its a sure way to throw 400 bucks away, though with a dual bios switch you can always fall back to a working one. What I am seeing here is that at least your current BIOS is stuck in a lower power state which is nice and efficient but not the product as its advertised, nor how you like it. TL DR: RMA
The card would still boost much higher than this. Its pulling 70-100W and could easily do much more within the PSU's capability. Additionally, the card doesn't care what PSU is in there, it will try to max out and that can pull the system into shutdown before it stops boosting, due to lack of power.
550W with a decent 12V rail is plenty for this card. His rig might pull 350W-400W under load and that is being generous.
I mean this is peak...
