be quiet! Announces Shadow Rock 3 White CPU Cooler
43,241 (7.97/day)
be quiet!, the market leader for PC power supplies in Germany since 2007, announces Shadow Rock 3 White. Instead of the silver/black bi-color scheme of the original version, the new cooler sports a white/black design that will feel right at home in fitting color-themed builds. Shadow Rock 3 White boasts a similar cooling capacity as the original silver version, which was released in March 2020. It is rated at an impressive 190 W TDP thanks to its advanced heat sink design and heat pipe layout, and the included Shadow Wings 2 high-speed fan.
Shadow Rock 3 White implements five 6 mm heat pipes with heat pipe direct touch (HDT) technology. The heat pipes are in direct contact with the processor surface, which results in fast heat transfer from the CPU to the heat sink. Shadow Rock 3 White comes with a black fan, offering a neat contrast to the white electrophoretic coating of the heat pipes and heat sink. This Shadow Wings 2 120 mm PWM high-speed fan is decoupled from the heat sink and offers a silent operation at no higher than 24.4 dB(A), even at maximum speed. Combined with a high fin pitch this results in a cooling performance capability of up to 190 W TDP, enough to enable trouble-free overclocking of mainstream desktop processors. Users who are looking for even higher cooling performance have the option to attach a second fan to the heatsink.
Asymmetrical design and top mounting system
The asymmetrical design of Shadow Rock 3 White moves the heatsink towards the rear exhaust of the case for unobstructed access to all memory slots. This guarantees maximum compatibility with high-performance memory modules, including RAM with tall heat spreaders or LED lighting. Installation is simplified thanks to a top mount design and an included screwdriver. The cooler is compatible with all current CPU sockets from Intel and AMD (except TR4 and sTRX4) and fits best on Intel Socket 1200 and 115X or AMD Socket AM4 motherboards with up to four memory slots.
Pricing and availability
Shadow Rock 3 White will be available for sale on October 27 at a recommended retail price of $59.90 / €59.90 / £54.99.
36 (0.01/day)
it's a good HS but why don't constrain the height under 160 thus allowing a lot more compatibility like D15s?
3,602 (1.12/day)
Behind that massive .44 mag that's in your face
System Name The Little One
Processor i5-8279u
Motherboard AZW Speed S
Memory 32GB Crucial DDR4-3200 (2x 16GB)
Video Card(s) Iris Plus 655
Storage WD Black SN750 2TB m.2 + WD 2TB external nvme
Display(s) 2x Samsung 43" LCD's @1440p
Power Supply 65w brick
Mouse Logitech MX Master 2
Benchmark Scores PDQ - all things considered !
Here we go again with the false advertising....
I don't understand why or how or when or where the term "WHITE" is meant to designate "White but with some other color(s) thrown in too" ???????
I mean, like, seriously. would it really have been that much harder to make the top cap & fans white also, ...
Soooo glad I saw those real white coolers here a few weeks ago, which will be in my upcoming Snowblind rig :)
13,209 (2.18/day)
Processor Intel i7 12700K / Intel i3 7100U
Audio Device(s) ALC1220-VB + ESS ES9118 DAC / Realtek onboard + B&O speaker system
Benchmark Scores Cinebench R23 (Single Core) 1911 @ stock Cinebench R23 (Multi Core) 22813 @ stock
You want a real white screw driver with that as well?.... :p :D
FreedomEclipse
~Technological Technocrat~
22,541 (4.03/day)
London,UK
System Name Codename: Icarus Mk.V
Storage Samsung 970Evo 512GB SSD (Boot)|WD Blue 1TB SSD|2x 3TB Toshiba DT01ACA300
Display(s) LG GP850-B
Case Corsair 760T (White)
Power Supply Corsair AX760
Mouse Logitech G900/G502
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
16,885 (5.84/day)
Video Card(s) MSI GTX 1080 Gaming X @ 2100/5500
Case Fractal Design Define C TG
Audio Device(s) Situational :)
Power Supply EVGA G2 750W
Mouse XTRFY M42
Software W10 x64
It gets worse, man. This is a white shadow.
Dafuq is that anyway... have you ever seen a white shadow? maybe those are the black bits, or its opposite day at BeQuiet?
Still though, White is obviously better for temps
992 (0.47/day)
NH, USA
System Name Lightbringer
Processor Ryzen 7 2700X
Keyboard Royal Kludge RK71
Kind of ridiculous that they couldn't make the fan white as well..... Wish there were more white components in the PC DIY space, though it is improving. I'm not sure when it was decided that PC enthusiasts want everything to be black.... Kind of like how they tried to force the whole "'red and black' is the coolest color scheme ever imagined" a few years ago which you still see remnants of today... Personally I think it's one of the worst, cliché played out tropes there is....
Behold... The ugliest motherboard ever conceived by man (and that includes ones with green PCBs):
844 (0.19/day)
Michigan
System Name Daves
Processor AMD Ryzen 3900x
Case Phanteks P600S
Audio Device(s) N/A
Power Supply Corsair RM 750
Mouse EVGA
Keyboard Corsair Strafe
Wonder how this would do with a 3900x.
3,602 (1.12/day)
Processor i5-8279u
2,540 (0.57/day)
how so, please elaborate ???
You know, the only difference between Arctic Freezer 34 and its "Esports Duo" upgraded version is this paint. It creates turbulence to lift off the stagnant air foil.
Also, I would give Shadow Rock 3 top honors along with Scythe Kotetsu II. They do very well in the p/p bracket.
3,602 (1.12/day)
Processor i5-8279u
And you know this how ??
Can you please post (or link to) the independent 3rd party engineering/wind tunnel/thermal imaging test results to sustantiate this statement ?
2,540 (0.57/day)
That is how Arctic markets their stuff. I think you can give Arctic the benefit of doubt. They 3rd party develop for other brands, too.
THERMAL COATING
A thermal coating creates micro-turbulences with a special surface structure. Combined with offset heat pipes this leads to an optimised heat-dissipation and to an increased cooling performance.
Funny thing is, Arctic positions these above Bequiet 3 and 4 series which is questionable, imo. I read through hardware.info and computerbase.de. It doesn't occur to me that way. They most gain when eardrums aren't the impediment.
Mussels
Freshwater Moderator
54,496 (8.36/day)
Oystralia
Processor Ryzen R7 5800X (PBO tweaked, 4.4-5.05GHz)
Motherboard Asus x570 Gaming-F
Cooling Alphacool Apex UV - EK Quantum Velocity AM4 + EK Quantum ARGB 3090 w/ active backplate
Memory 2x32GB DDR4 3600 Corsair Vengeance RGB @3800 C18-22-22-22-42 TRFC704 (1.4V, SoC 1.15V Hynix MJR)
Video Card(s) Galax RTX 3090 SG 24GB: Underclocked to either 1500Mhz 0.737v | 1700Mhz 0.75v | 1900Mhz 0.9v
Storage 2TB WD SN850 NVME + 1TB Sasmsung 970 Pro NVME + WD AN1500 1TB + 1TB Intel 6000P NVME USB 3.2
Display(s) Kogan 32" 4K 72Hz + Gigabyte G32QC (1440p 165Hz) + Phillips 328m6fjrmb (1440p 144Hz)
Case Fractal Design R6
Keyboard Razer Huntsman TE (custom white and steel keycaps)
VR HMD Oculus Rift S
Software Windows 11 pro x64 (Yes, it's genuinely a good OS)
Benchmark Scores I don't quite know how i managed to get such a top tier PC, I am not rich.
Oh come on, no white fan? No white top?
I used to have a sick white build that i had to ditch because every brand did dumb colour combos like this
16,885 (5.84/day)
Mouse XTRFY M42
Software W10 x64
:toast:
Isn't it obvious?!
Now, add RGB in blue and you can go sub zero
16,885 (5.84/day)
Mouse XTRFY M42
Software W10 x64
It just hit me, they want this to be an inclusive product. Needs balance
crazyeyesreaper
Not a Moderator
9,634 (1.97/day)
System Name Old reliable
Processor Intel 8700K @ 4.8 GHz
Motherboard MSI Z370 Gaming Pro Carbon AC
Cooling Custom Water
Memory 32 GB Crucial Ballistix 3666 MHz
Video Card(s) MSI GTX 1080 Ti Gaming X
Storage 3x SSDs 2x HDDs
Display(s) Dell U2412M + Samsung TA350
Case Thermaltake Core P3 TG
Audio Device(s) Samson Meteor Mic / Generic 2.1 / KRK KNS 6400 headset
Power Supply Zalman EBT-1000
Mouse Mionix NAOS 7000
Keyboard Mionix
One for @crazyeyesreaper to get in and review.
Already was reviewed, there is no real difference other than color scheme at least according to the PR.
2,540 (0.57/day)
I don't know. I want to give a huge applause to be quiet! for delivering some of the best aircoolers. You have to hand it to them, along with Noctua - these threadrippers aren't going to cool themselves, and cooled competitively at that.
Sometimes my heart warms at the thought of a well composed air cooler. There aren't very many solid components like they sport. I get anxious to make some airducts for water-grade case internals. Not shadow rock 3, but anyway.
