Best coolant for my liquid cooled system?
101 (0.02/day)
Likes
0
America
Processor AMD athlon 3700+ oc to 2.71 Ghz
Motherboard MSI K8 NEO 4
Cooling Swiftech 120mm rad, CPU Apogee gt, MCP350 pump
Memory 2 gigs of OCZ pc3200 Platinum edition ram
Video Card(s) ATI X1900XT 512 MB 722 core 792 MEM
Storage 320 gb Seagate Barrracuda 7200 Sata
Display(s) 19 inch Samsung Sync Master 955df
Case XBLADE
Power Supply ULTRA X connect 500w
Software Windows xp pro
#1
Hello I just took the plunge in to liquid cooling, I peaced together a swiftech system off eBay and saved allot of money. I went with an APOGEE universal CPU block, MCP350 pump, 120mm quiet power radiator, all from swiftech. Now all I need is the fluid I was thinking about going with primo chill PC ICE, is this a good coolant? It says it’s non conductive so I take it that means it wouldn’t fry my mobo if it leaked? I just want a good performing coolant that inset to expensive 30 dollars or less.
7,626 (1.65/day)
Likes
855
TX, USA
Processor Intel i7 4770K
Motherboard Asrock
Cooling Water
Memory Team Xtreem LV 16GB (2x8GB)
Video Card(s) EK Full WB HD7970
Display(s) CROSSOVER 27Q LED-P 27"
Case Danger Den Torture Rack
Power Supply CORSAIR Professional Series Gold AX1200
Software W 10 Pro
#2
101 (0.02/day)
Likes
0
America
Case XBLADE
#3
curt
584 (0.13/day)
Likes
13
Processor amd phenom II x4 955be @4.2gh 1.4v 24/7 max so far 4.6gh 1.5v in windows
Motherboard asus crosshair V well cooled
Cooling dd mc tdx block with 10000btu a/c rad with cold air piped from outside
Memory ocz low volt reapers 1600mh @ 1667mh 8.8.8.20 1.6v
Video Card(s) bfg gtx 280 1gig core has hit over 733mh
Storage 2 intel 40gb ssd.s in raid 0/ 1tb seagate 7200.12
Display(s) 2x 19inch non wide lcd.s
Case none sits on back plate from a case lol
Audio Device(s) sb xfi extream music [pci]
Power Supply #1corsair tx850 for mobo/vid #2 enermax true 460wat for hd.s/cd/fans
Software xp pro/7 64bit [biggest comp out of 3 i run]
Benchmark Scores the marks ar well ownage lol
#4
hey
i know this is probly not for u but its lots of fun with a liquid chiller
i was useing antyfreez an will agean 1 day [its a bit thick an not real good at room temp ]but at -15c its still flowin strong
worst part about a/f is its corosive eats at serkets on top of being conductive [if allso hered some a/f is toxic an dont get the non evaperating kind it sucks
for room temp running i just use streat water with a cap of bleach in it to keep it clear
i dont get leaks an my board is sealed in case i do
