Best Cooler up to 80£ Air/water for my 2700x?
2,988 (0.69/day)
Northampton,UK
System Name Jaffakeik
Processor Ryzen 2700X
Motherboard Asus Strix X370-F
Cooling Stock
Memory Team Group Dark T-Force 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz
Video Card(s) KFA2 GeForce GTX 1070 EX OC 8192MB
Storage WD Black 500GB M.2 2280 NVMe Solid State Drive
Display(s) AOC 27''+LG 29''
Case Mid Tower
Audio Device(s) Soundblaster Zx
Power Supply Super Flower Golden Green HX 650W "80 Plus Gold"
Mouse Razer Lancehead
Keyboard APEX 150
I'm looking for a nice mid-range budget cooler air or closed loop water system cooler. Cos As I'm running on default bios settings CPU is always boosting to 4.0+- instead of 3.7mhz. so temps go up to 70+ when playing heavy games with some streaming even on max fan rpm. So what u suggest?
5,112 (1.11/day)
Australia
Processor AMD R7 2700X | Ryzen 1600X | i7 970
Cooling AMD Wraith cooler| Stock Cooler, Copper Core)| Big shairkan B
Video Card(s) ASUS GTX 970 OC in Sli | Inno3d GTX 1050 TI | MSI RX 580 8GB
Storage 250GB Plextor SSD Por 5 /1TB WD Black | 500GB SSD WD, 2x1TB, 1x750 | WD 320/Seagate 320
Power Supply Silverstone 750 | Silverstone Mini 450W | Corsair CX-750
Software Windows 7 Pro 64 | Windows 7 Pro 64 | Windows 7 Pro 64/Windows 10 Home
Are you using the stock cooler at the moment?
I use the stock cooler and it doesnt go over 64c, but I have set my own fan curve in the BIOS for it as I didnt like the default settings
644 (0.37/day)
127.0.0.1, London, UK
System Name Warranty Void Mk.IV
Processor AMD Ryzen 5 2600 @ 4Ghz
Motherboard Asus X470-I Strix
Cooling Arctic Freezer 240 + 2x Be Quiet! Pure Wings 2 140mm / Silverstone 120mm Slim
Memory Crucial Ballistix Elite 3600MHz 2x8GB CL16 - Tightened Sub-timings
Video Card(s) EVGA RTX 2080 XC Ultra / Palit JetStream GTX 1070
Storage Crucial MX300 525GB/MX500/ADATA SP550 250GB
Display(s) LG 29UM69G-B / 2560x1080 + Oculus Rift S
Case Fractal Design Meshify TG/ Silverstone RVZ03-B
Audio Device(s) Realtek ALC 1220+SupremeFX
Power Supply Corsair CX550M 550W / Silverstone SX650-G 650W
Mouse A4Tech Bloody V3/SteelSeries Rival 100/Logitech G302/G502
Keyboard Microsoft Comfort 3000 Curve/ CM Masterkeys Pro M
Software Windows 10 Pro x64 - LTSB
The best that you could get would be a Noctua or something from BeQuiet! in the air category.
If you need the AIO and the looks, I would pick DeepCool Captain 240, which has better stock fans than most cheap AIOs. I have one and it has never let me down in these 2 years. Probably the best purchase of my PC's lifetime. I'm running my 2600 @ 4GHz with really low voltage and LLC 3 daily while gaming.
2,988 (0.69/day)
Northampton,UK
Cooling Stock
Case Mid Tower
Keyboard APEX 150
The stock cooler, when i stream 900p60 + darksouls3 on max 1080p it does go up to 72 when performance mode enabled, when I use power saving profile in AI suite it straight goes down to 44+-, BUt I never tried to play games with power saving mode. But its still better to get good cooler just in case right? I had dark rock4 pro on my previous build with 7700 worked good, but will it work on this one with same performance?
644 (0.37/day)
Well the mid-70's are fine, but that's almost on the borderline, afaik Ryzen shuts off at 80C-ish as a safety measure. 55-60 maxed out on the CPU is what I'd be fine with in the long term, so any of the mentioned options should fit that I guess, though I'm not sure what clock speed you want to run at all the time.
Ryzen Balanced profile seems good enough, all around. Power saving is only useful if you tend to only web browse and stuff. Switching in-between is annoying. So I'd recommend a program called ASUS ZenStates, which you can use to set P-State clock speeds. Best part about it is, it re-applies everything on windows start-up, unlike Ryzen Master.
2,988 (0.69/day)
Northampton,UK
Cooling Stock
Case Mid Tower
Keyboard APEX 150
I will use default bios, auto boost that boosts to 4.0+- all cores as needed. I wont OC or anything. So I will check those options as u mentioned will see how it goes. SI there any point of buying different thermal paste? Or whatever will go with cooling device will be more than enough?
644 (0.37/day)
Yeah, any decent tower cooler should do just fine then, for performance I'd go with the best, biggest and baddest Noctua you can afford. If you want the looks and a more quiet profile I'd go with BeQuiet! Dark Rock series. And if getting a DeepCool Captain 240 cheap isn't an option, sometimes theres a sale on a Corsair H100, beware though, I recall the fans being loud and less efficient compared to their newer units, which cost a bit more. Same with CM MasterLiquid ML240L, while it is a decent unit, the stock fans aren't too good on the quietness front. Another thing I want to mention, I don't think the H100 has AM4 brackets... which the Captain 240 does. (It was one of the first AIO's to have AM4 brackets on Zen launch)
I've also seen some Fractal Design S24's for a good price, and I don't know if those have AM4 brackets.
Sometimes you can get away by buying a really dirt cheap AIO and just replacing the crappy stock fans does it a favor, but you have to take into account how much extra you will be paying and if you can sell or re-use the stock fans. And quality-wise reviews are mostly on point about what you are getting, you definitely don't want the pump failing within 3 years, most conservative AIO blocks seem to run at a speed that is comfortable for them.
There used to be a time where me and their grandma were worried about an AIO leaking. Honestly I was willing to take the risk because a good company will replace everything that is damaged nowadays and have decent QA to spot problem units so those never reach the market, its never a guarantee though, such is life. The pump quality has gotten better since the old days, you don't have to spend £100+ for something good. (Though I think nobody would mind an NZXT X62 or the like) But if you want the super-duper safe way that will last decades, air coolers are the way to go, plus the big ones usually work better than most 240mm AIOs according to TPU's own reviews.
Whichever you pick, you can't really go wrong. It will come down to price, performance and personal preference.
1,227 (1.40/day)
Cusp Of Mania, FL
System Name humble reentry to pc-building after too many years
Processor Ryzen 9 3900X
Cooling Dark Rock 4
Video Card(s) Asus ROG Strix RTX 2060 OC
Display(s) 32" Samsung F395 [1080/60]
Case NZXT H710
Audio Device(s) Schiit Modi 2 Uber, Sys, Vali 2, Scarlett 2i2 gen2 - LSR 305's, DT-990 Pro's, HD600's
Keyboard HyperX Alloy Pro
No love for Scythe in this thread. Mugen MAX and Mugen 5 rev b are both exceptional air coolers that can run with the best of them for like half the money. Really doesnt get much better on air. Even many of the aios dont keep up, or the edge up doesnt justify the cost... though that seems generally true of aios, save for a few
9,247 (3.16/day)
Massachusetts
Processor i5 8600k
Motherboard Asrock Z370 Extreme 4
Cooling Corsair H-110i GTX
Memory 2x 4Gb Crucial Sport LT
Video Card(s) MSI GTX 980 Gaming
Storage Samsung 850 evo 250Gb
Display(s) Dell Ultra Sharp Widescreen 24" 1200P
Case Fractal Design Meshify-C
Power Supply Seasonic Focus+ 750 Gold
Mouse Logitech G502 spectrum
Scythe & coolermaster are great cooling/fan makers. Ive had the good fortune to test many from scythe & although i cant speak to their ryzen capabilitis, i will say they are great with intel & the support team @ scythe is one of the best ive ever dealt with
1,227 (1.40/day)
Cusp Of Mania, FL
Cooling Dark Rock 4
Case NZXT H710
I've got a Mugen MAX cooling my 2600. Overclocking all cores to 4.25ghz I manage 75C max under really heavy stress tests such as linpack and small fft. Gaming was 60-65 max, averaging 58. And that's really pushing that chip. Current really shoots up at 4.2+. Efficiency just takes a dump. Gets real hot, real fast. But the cooler keeps up. Now, I run 4ghz and at most I see 52C when gaming, though most times when I pop over and check it's mid-upper 40's. Low 60's when pushed to the absolute max. Plenty of fan headroom, too. Thing runs dead quiet. I'd bet a 2700x @ 4ghz would be perfectly happy under a cooler like that.
However, I might ask... ...what is your case setup like? Even for the stock cooler your temps seem on the high side. Good cooler can't save you from bad case flow.
13,805 (4.27/day)
USA
System Name My Fortress/Julia (WCG)/Trish (WCG)/Ella (WCG)/Junior (WCG)/4P (WCG)/Kreij (WCG)/Trish02 (WCG)
Processor Ryzen 1700X/Ryzen 1700X/Ryzen 1700/Ryzen 1600X/Ryzen 1800X/Opteron 6168x4/FX-8350/Ryzen 1800X
Motherboard X370 Taichi/A320 Pro-VHL/B350 M/B350 M/AB350 K4/SuperMicro 4P/ASUS 990X/ Asrock X370 mITX
Cooling NH-D14/SNH-U14S/Scythe Mugen5/Scythe Mugen 5/NH-U14S/CM 212+ (x4)/Xig DK Nighthawk/Scythe Mugen 5
Memory 16GB GSkill TridentZ-3200 (1700X), 16GB GSkill FlareX-2400 (1800X),... various...., 4P- 16x1GB
Video Card(s) RX 580/HD 7770/HD 4670/GTX 1080/8400GS/onboard/GTX 1080/HD 7870
Storage WD 500GB SSD/Seagate 2TB SSHD, .... misc...
Display(s) Dual Dell Ultrasharp U2414H
Case Silverstone FT01B/Corsair 230T/Versa H15/Silverstone FT05/Define R4/custom/Tt P3 open/Define XL r2
Audio Device(s) on board (All)
Power Supply Corsair HX850/CS650M/Focus Gold 650/EVGA P2 850/HX 650/X Gold 1050/M12 II 750/X Gold 750
Mouse Logitech G300s
Keyboard Thermaltake Challenger Prime (Great for $30!!!)
Software Win 10 Pro (Fortress), Win 10 Pro (Ella02), Ubuntu for everything else
Benchmark Scores Why sit on the Bench when you can get in the game and Crunch!!!
Recommend the Scythe Mugen 5 rev b or Noctua NH-U14S- I'm using both on various Ryzen rigs and getting great performance from them
crazyeyesreaper
Not a Moderator
9,521 (2.25/day)
System Name Old reliable
Processor Intel 8700K @ 4.8 GHz
Motherboard MSI Z370 Gaming Pro Carbon AC
Cooling Custom Water
Memory 32 GB Crucial Ballistix 3666 MHz
Video Card(s) MSI GTX 1080 Ti Gaming X
Storage 3x SSDs 2x HDDs
Display(s) Dell U2412M + Samsung TA350
Case Thermaltake Core P3 TG
Audio Device(s) Samson Meteor Mic / Generic 2.1 / KRK KNS 6400 headset
Power Supply Zalman EBT-1000
Mouse Mionix NAOS 7000
Keyboard Mionix
Depends on the case, since that will determine max cooler height and AIO support. Generic mid-tower doesn't really say much.
My initial recommendation for mid tier cooler would be the CRYORIG H5 Universal granted there is a chance it wont come with the AM4 bracket (you can email support and get one for free no issue) Has 100% memory clearance so no issues there usually available for around $50. Performs fairly well overall. If wanting high end air with those memory sticks of yours I would recommend the R1 Universal (similar or better performance to the Be Quiet Dark Rock Pro 4 but with better memory compatibility.)
AIOs are getting a bit pricey these days.
565 (0.78/day)
Zadar, Croatia
System Name SloMo
Processor G4560
Motherboard MSi H110-PRO-D
Cooling LC-CC-95 @ Arctic Cooling fan
Memory 2X Crucial DDR4 2400 4GB
Video Card(s) Integrated HD 610
Storage WD 500 GB + Seagate 500 GB + Toshiba 3 TB
Display(s) Lenovo D221
Audio Device(s) Manhattan Flex BT Headphones, Encore P-801 stereo speakers
Power Supply Corsair CX450M
Mouse microsoft office mouse
Keyboard Modecom mc-800m
Benchmark Scores gorstak @ hwbot.org
I'd go for Arctic Freezer a33, if you aren't going to OC much...
2,988 (0.69/day)
Northampton,UK
Cooling Stock
Case Mid Tower
Keyboard APEX 150
In the end, I went with Noctua NH-D15 SE-AM4, I always wanted to try it kinda heard lots of good things about NOcta, As I had dark rock on my 7700, and it was sold as a bundle of my previous MB, so I had to try something new, As I use open case with 2 extra case fans, it keeps my cpu under 35c on idle and under 50c with stream and gaming. So i pretty happy with it, so thanks a lot for suggestions.
2,783 (1.36/day)
Long Island
The $45 Scythe Fuma will perform as well as or better than the $90 flagships from Noctua or Cryorig ... and any of those will beat 2 x 120mm air coolers easily.
725 (0.94/day)
Processor X5690 ES
Motherboard Asus Rampage III Formula
Cooling Thermalright Le Grand Macho RT, TY143
Memory 10Gb G.Skill mix
Video Card(s) EVGA GTX 980 Classified 3988 @ 1495/2001
Storage Intel 545S
Display(s) Hisense 55"
Case Fractal Design Meshify C TG, White
Audio Device(s) Asus Xonar Essence ST
Power Supply CM Silent Pro M2 850
Mouse Zowie EC2 Evo
Keyboard Logitech G15
Software Yes
Or for 50 bucks, you could get a Thermalright True Spirit 140 Power, as good, if not a little better than Le Grand Macho RT. Add a TY143 to step it up a notch. It comes with clips for two..
2,988 (0.69/day)
Northampton,UK
Cooling Stock
Case Mid Tower
Keyboard APEX 150
I BOught what I bought I'm happy. I used my budget what I could afford, so i dont regret I'm happy with its cooling. If there is better or same for less, I will look into it when this will break. THanks.
