Best Current B die Bins for 3950x 3800mhz CL14
395 (0.18/day)
System Name Harm's Rig's
Processor 5950X /2700x / AMD 8370e 4500
Motherboard ASUS DARK HERO / ASUS X470 PRIME PRO
Cooling Enermax LIQMAX III ARGB 360 AIO/ Zalman cooler fan 110mm
Memory TRIDENT Z F-43600V15D-16GTZ /G.SKILL DDR4 3800CL14 FASTEST PRESET 32GB /EVGA 16Gb 2400 DDR3
Video Card(s) 1080 Ti / 290x/290a cfx
Storage 2X Sabrent Rocket NVMe 512GB / 1 SSD 250GB / 1 HHD 3 TB
Display(s) 40"TV / 24" Asus
Case TT 37 VIEW 200MM'S/ NZXT Tempest custom
Audio Device(s) Sharp Aquos
Power Supply EVGA 1300G2/Corsair w750
Mouse G502
Keyboard G413
For a $108.00 dollar's, open box at Micro Center, have to play with the bios for sure .
314 (0.07/day)
Atlanta
System Name Daily/SFF
Processor Ryzen 3900X
Motherboard ASUS ROG Strix X570-I Gaming
Cooling Noctua NH-U9B SE2
Memory GSKILL Flare X F4-3200C14D-16GFX
Video Card(s) Zotac GTX 1660 Ti Amp
Storage WD Black SN750 500GB NVMe SSD
Display(s) SAMSUNG 24" SD590 Series
Case NCASE M1
Audio Device(s) On-board
Power Supply CORSAIR SF600
Mouse Microsoft IntelliMouse Explorer 3.0
Keyboard KB Paradise V80 Olivette TKL
Software W10
For counterpoint, I have finally got a stable system on X470 Taichi (which is *definitely* t-top) with 4x8Gb 3733 16-16-16-32 coupled CR1. DRAM @ 1.45v and SoC 1.1v. Nothing I have tried gets me to 3800.
I am running some top rated Team Group XTREEM 4133 18-18-18-38 underclocked to 3733, and feel comfortable eliminating the DRAM as the weak link.
I went back to the X570 Taichi today and decided to swap out the 3950X with a 3900X from another setup. I was able to boot and run at 3800C16 1:1 with the 2nd chip. :)
I booted first at 3733 and then tried 3800 with 2x8GB and again later with 4x8GB installed. I didn't have any of my previous... "No post/hang: code 07 issue" with the 3900X. 4x4GB did required more BIOS fine tuning/dialing in of settings then running just 2x8GB sticks.
3900X X570 Taichi @3800C16 ~1.42v DRAM: ~1.075v SOC... Quick 1 hr. AIDA64 mem/cache stress:
314 (0.07/day)
Atlanta
Case NCASE M1
Software W10
Running on the CH8H today... 3950X @3733C14 (4x8GB) ~1.44v DRAM and ~1.1v SOC running a quick 1hr. AIDA64 mem/cache stress.
I don't know for sure but I'm thinking now that 3800C14 (2x8GB) is probably going to take up towards ~1.5v DRAM provided that I'm lucky enough to have a kit spec'd with a level of "quality IC margin" that could do it? Then I'd need two more similar quality sticks to even attempt 4x4GB??
1,471 (0.26/day)
Processor Ryzen 1600AF @4.2Ghz 1.35v
Motherboard MSI B450M PRO-A-MAX
Cooling Deepcool Gammaxx L120t
Memory 16GB Team Group Dark Pro Sammy-B-die 3400mhz 14.15.14.30-1.4v
Video Card(s) XFX RX 5600 XT THICC II PRO
Storage 240GB Brave eagle SSD/ 2TB Seagate Barracuda
Display(s) Dell SE2719HR
Case MSI Mag Vampiric 011C AMD Ryzen Edition
Power Supply EVGA 600W 80+
I just purchased 16GB Team Group Dark Pro (2x8GB) DDR4 3000 15.15.15 from www.overclockers.co.uk for £75, they are Samsung B-Die and I'm hoping for some 3600mhz C14-C16 on my lowly little Ryzen 1600 AF
7 (0.00/day)
On a 3950x with my b-die G.Skill 2x16GB 16-16-16-36 Neo 3600 RAM with a MSI X570 board on the old AGESA 1.0.0.5 BIOS (best for memory overclocking) I get the below TM5 and HCI MemTest stable which is pretty much unheard of.
1,317 (0.50/day)
Grunn
System Name Indis the Fair
Processor R5 3600 (PBO 150/130/130, 73c temp limit, FCLK/UCLK 1866)
Motherboard Asus Prime X470 Pro
Cooling Heatkiller VI Pro, VPP755 V.3, XT45 240mm, 2xA12x25, Arctic P14 case fans
Memory G.Skill Ripjaws V 2x16GB 4000 16-19-19 (b-die@3733 14-15/9-13-26-36 1.45v)
Video Card(s) EVGA 2080 Super Hybrid (A12x25 fan)
Storage 860EVO 500GB, 660p 1TB, WD Blue 3D 1TB, Sandisk Ultra 3D 2TB
Display(s) BenQ XL2430T, Dell P2417H
Case Phanteks Enthoo Pro M
Audio Device(s) DT770 Pro, Topping A50, Focusrite Scarlett 2i2, Røde VXLR+, Modmic 5
Power Supply Seasonic 860w Platinum
Mouse Razer Viper Mini, Razer Gigantus
Keyboard GMMK Fullsize v2 (Gateron Browns)
Software Win10 x64/Win7 x64/Ubuntu
Most fast b-die bins will run 3800 14-14-14 at around 1.45-1.5v. My current kit is a 2x16GB 4000 16-19-19 Gskill kit which does it with no fuss at 1.45v on a B550-A pro (though it struggles to get to the XMP, frequency wise that board with dual rank kits seems to tap out just short of 4000), my old 2x8 4000 19-19-19 patriot kit does it as well on that board. My daily X470 board is pretty crummy at memory so the RCDs end up settling at 15 no matter what kit at 3733.
My recommendation would be with 2x16GB kits, firstly 3200 14-14-14 kits for value, but otherwise the faster kits aren't terrible either.
1,879 (3.92/day)
Texas
System Name Ghetto Rigs x299 & z490 & Q9550 Old timer
Processor 9940x with optimus sigV2 & 10900k with optimus foundation & Q9550 with EK Evo
Motherboard X299 Rampage VI Apex & z490 Maximus XII Apex & Acer WG43M
Cooling D5 combo/280 GTX/ VRM water block copper/280 GTX/ D5 Top/Optimus sigV2/TitanXp/Mora 360x2
Memory Trident-Z 3600C16 4x8gb & Trident-Z 3600c16 2x8gb & 4x2gb crucial
Video Card(s) Titan Xp & 1080ti ftw3 & evga 980ti gaming
Storage 970 evo plus 500gb & 970 evo 500gb many 2.5" ssd's and WD BLK hdd's
Case D450 second floor for 2nd rad x2/ Cherry Entertainment center/ 2 Test benches
Audio Device(s) Built in Realtek x2 with Insignia 2.0 sound bars & 1-LG sound bar
Power Supply evga 1200P2 & 1000P2 with APC AX1500 & 850P2 & CyberPower-GX1325U
Mouse Redragon Perdition x3
Keyboard G910 & G710+x2
Software Win-7 pro x3 and Linux Cinnamon 20.1x2 & win-10 pro x3
Last set I looked at was 4000c18 2x16gb kit and 1.4v
7 (0.00/day)
I think the original question was for a 3950x. I really doubt one will do 3800 14-14-14 2x16GB stress-tested stable.
1,317 (0.50/day)
Grunn
3800 will depend on the IF, but 3800 14-14-14 at under 1.5v is not a challenge for most 3200 14-14-14 b-die kits I've seen. Like I mentioned above some boards (400 series, I've seen B450 tomahawks struggle with this as well) will not like RCDRD at 14 or lower at 3800, but given that a B550-A Pro does 3800 14-14-14 no fuss at all I strongly doubt most decent 500-series boards will have a problem with it.
