Best easy way to repair small scratches on Lian Li black Aluminum chassis?
198 (0.09/day)
Japan
System Name ChronicleScienceWorkStation
Processor AMD Threadripper 1950X
Motherboard Asrock X399 Taichi
Cooling Noctua U14S-TR4
Memory G.Skill DDR4 3200 C14 16GB*4
Video Card(s) AMD Radeon VII
Storage Samsung 970 Pro*1, Kingston A2000 1TB*2 RAID 0, HGST 8TB*5 RAID 6
Case Lian Li PC-A75X
Power Supply Corsair AX1600i
Software Proxmox 6.2
The chassis's side panel has a bump (there was a defect when the aluminum was folded), that made it hard to close the case properly.
I only realize it today after the machine has been assembled after a week, I didn't want to return the chassis for this reason so I used a plier to flatten the bump.
To so do, I put multilayers of foam between both side of the panel and the pliers to not leave scratches, but then I could still see some marks:
They are actually quite small and on a side that I don't get to see, but I wonder if there is anything I can apply to make them less apparent?
32 (0.07/day)
I would try something what people use to remove scratches on cars. This or something similar.
sneekypeet
Retired Super Moderator
28,914 (5.18/day)
System Name His
Processor Intel i9 7920X
Motherboard Asus Prime X299 Deluxe
Cooling Corsair H115i RGB Platinum
Memory G.Skill TridentZ RGB 32GB @ 3600MHz
Video Card(s) nVidia RTX 2080ti
Storage Samsung 960 Pro / Crucial MX300 750GB / Seagate 1TB Spinner
Display(s) Samsung 55" 4K 60hz
Case Cooler Master Cosmos C700P (Inverted Layout)
Audio Device(s) Realtek on board > Sony Receiver > Cerwin Vega's
Power Supply Thermaltake TPSG 1050W
Mouse Always Changing
Keyboard Always Changing
Software Windows 10 Pro 64
To me it looks less like scratches, and possibly something left behind from the foam.
Not sure compound would work as it will be a pain to get out of the hairline finish of the aluminum. I would try alcohol first and see if it comes off (if it isn't scratches). If it truly is scratches, you are going to need to color it with something to match the aluminum, otherwise you will be left with exposed aluminum with anything you try to remove scratches with.
Your best bet is to get ahold of Lian Li, explain the situation, and ask for a replacement panel.
198 (0.09/day)
Japan
Thanks for the advice, part of it was left over of the foam, but others looks like scratched as I could feel the metal roughness on touch.
I could try contacting Lian Li, but now it’s partly my fault so I am not sure if they will help, though I can also show them the manufacturing defect which is now a partly repaired. (Spent me a whole afternoon to understand why the case does not close properly)
sneekypeet
28,914 (5.18/day)
System Name His
You were attempting to fix a damaged part. Just be honest in your request. Worst they can say is no.
578 (1.31/day)
If a return request fails which I think it will, just ask a local auto body repair shop if they can do anything. Personally I wouldn't bother.
I'm still staring at that big scratch I put on the front of my my Tt case a while back, thinking of putting a sticker over it and leaving it at that.
198 (0.09/day)
Japan
Thanks for the suggestion, as adviced I contacted Lian Li and now waiting for their reply.
I sent them the picture shared here, and told them the full story. I might have to take the side panel off again (lots of work as it is in a crowded spot) to show them the bump, though I have it flatten a bit comparing to before, it still looks bumped up comparing to the bottom corner.
LOL, I don't really worry about it as much as I was 10 years ago with my first Lian Li case.
I have had so far 5 Lian Li cases (A75, A76, Q35, Q04, B25S) in total and I dare say none of them has an obvious scratch - I pay extra attention in handling, always wearing nitrile gloves and put them on carpet or foam sheets.
Just a pity to me that the case would have looked like new after another decade if it wasn't for my mistake here. So I kind of wonder if I can paint it somehow to just make less easy to see haha
423 (0.07/day)
System Name Dekstop | Eluktronics Max 17
Processor X5675@4.8Ghz|Intel Core i7 9750H -140mW undervolt
Motherboard ASUS P6T Deluxe LGA 1366 Intel X58
Cooling Thermalright True Black Ultra-120 Extreme | pk-3 | conductonaut
Memory 16Gb Trident DDR3 2400Mhz@2095Mhz | 10-9-10-20
Video Card(s) BFG GTX 280 | RTX 2070 Max P
Storage Vertex 4 Raid 0 | 2 x 2Tb Inland Premium nvme
Display(s) Dell fpw 2005 20.1" 16:10 1680x1050
Case Tt Black Armor
Audio Device(s) Creative X-FI Fatality platinum | Extrememusic x-fi
Power Supply Evga P2 1000 | Corsair H1000i
Mouse Razer Viper ulti
Keyboard Saitek
Benchmark Scores (9750H Cne15 2100|Cne20-3150) (as-SSD-7000 &6600pts 2 Tb Nvme) (x5675 Cne11.5 -1102Pts)
go in with straight up polishing compound and cotten/wool attached to dremel or pneumatic grinder. degrease it first. start with the finest method and work backwards to harsher methods. if polishing doesnt work, and the paint isnt too far gone, then use 2000 grit sandpaper and repolish. then 1500 grit ect. hopefully its not anodized aluminum.
sneekypeet
28,914 (5.18/day)
System Name His
Issue is with any form of polishing is that it will remove the anodized black color as well. In essence, you will only make things worse.
198 (0.09/day)
Japan
Update: They actually got back to me today, and agree to send me a replacement immediately. I never had to contact Lian-Li so I never knew they were this nice!
Crashman
16 (0.05/day)
For future reference, Lian-Li's black aluminum IS anodized that color, and the closest match you can probably get is with a black magic marker and a bunch of practice/patience. "Experts" in "Finishes" such as auto body shops typically can't help, because the only "correct" method is to strip the entire panel and re-anodize it.
