Boot linux on USB drive
Pitchblack1110
62 (0.01/day)
Processor AMD Athalon 64 X2 3800
Motherboard Foxconn NVIDIA nforce 590 SLI
Cooling 1 x 120mm side fan, 1 x 80mm back fan
Memory Kingston HyperX 1.5 gigs
Video Card(s) Radeon X1300
Storage 320gb Seagate Barracuda
Display(s) Gateway 22"
Case Raidmax Ninja
Audio Device(s) On-Board
Power Supply Raidmax 450w
Software Windows XP Home
Hi, I was trying to boot linux from a usb jump drive. I followed a tutorial i found online, and It didn't seem to hard. But when I go into BIOS to try select it as the boot device, i cant find it. What am I doing wrong?
Any help is apreciated.
be sure that your flash drive is a bootable device. and if so, make sure you make linux bootable.
it might just be that your bios doesn't support it, but it should anyway.
make sure you go into the bios and make sure "boot other device" is enabled and try seeing if the usb is listed as an hdd.. as bootable flash drives are usually picked up as usb hdd's and check if your bios detects the flash drive.
When I go into bios, I selected boot other device, but I dont see any thing about a USB. Does this mean my BIOS doesnt support booting from a USB device?
Most likely not. Try finding a BIOS update.
