Buying a second cable modem instead of renting
310 (0.05/day)
Processor AMD Ryzen R7 3900X
Motherboard Gigabyte X570 Asrock X570 Taichi
Cooling 2x LL140, 4x LL120 / bequiet! Dark Rock 4
Memory 32GB Corsair Vengence RGB DDR4 (3600 Mhz)
Video Card(s) Red Devil 5700XT
Storage x1 Inland 1TB Nvme, 1x Samsung 860 EVO 1TB, 1x WD 1TB, 1x Crucial MX500 500GB, 1x Sandisk X400 256GB
Display(s) Samsung C32H711
Case Fractal Design Meshify C
Keyboard Logitech G910
I called my ISP a few days ago, and asked them how much it would be to rent a second modem. I was shocked to find out they want to charge full subscription price (which actually makes sense). I checked newegg for a modem, and I was thinking of buying one and hooking it up to my cable, so I wouldn't have to pay the extra subscription fee. Is that illegal, or have a just found a good loop-hole?
And how do you plan on using this second modem?
I mean in theory, you wouldn't be able to use it without registering it's MAC address to your ISP, then they would charge you a second subscription fee anyway.
I was just going to use it for my PS3. I didn't want to get a router and have to muck around with all that port access stuff.
It's the easiest and cheapest way, getting a router. Plus, as long as it's got UPnP (Universal Plug'n'Play), it should configure ports automagically, or mine does anyway.
