- Apr 20, 2021
- 4 (0.00/day)
- Denmark
System Name | Føniks Eagle III Ultimate |
Processor | Intel Core i9 9900K |
Motherboard | Asus ROG Strix Z3390-F Gaming |
Cooling | NZXT Kraken X72 |
Memory | G.Skill TridentZ RGB 4000 Mhz CL17 2x8 GB |
Video Card(s) | Asus ROG Strix RTX 2080Ti |
Storage | Samsung 970 EVO 500GB NVMe |
Display(s) | 2x Dell 27" S2721DGFA |
Case | NZXT H700 |
Power Supply | Corsair RM850x |
Mouse | Logitech G PRO X SUPERLIGHT |
Keyboard | Logitech G915 TKL Clicky |
Hi
I have been playing with the idea of replacing my current case with one that has better airflow than my current NZXT H700. I have not been following the case market since i bought this one, so i have no idea where to start looking. It should obviously hold the components listed in my system specs. Window and RGB would be a plus, it would also be nice if the RGB can be controlled by Asus Aura, just to keep the software requirements to a minimum.
My Kraken X72 has some weird issues where the RGB keeps cutting out, i have tried a new USB cable and different USB header on the motherboard without it resolving the issue. I also find the CAM software buggy. Instead of tinkering with it i'm just going to get a new CPU cooler. Could you recommend me one, that can cool my i9 9900K with Multicore Enhancements enabled? I don't have any preferences about AIO or air cooler, it just needs to be able to keep my CPU as cool as possible.
I will be handing my current case and AIO (it still works well, just without the RGB) down to my brother, as he could use them as an upgrade for his system.
I would also like some new RGB fans to go with the case, so it would be awesome if you could recommend me some.
My budget is up to $500, i will search for the components on www.pricerunner.dk and just find the cheapest store with the item in stock.
