Case fans run full speed when MB temp is above 51 C
18 (0.01/day)
Processor i7 6700K @4.5 GHz
Motherboard ASUS TUF Sabertooth Z170s
Cooling Thermalright Le Grand Macho RT
Memory 2x8 GB HyperX Fury Black 2666 MHz DDR4
Video Card(s) MSI GTX 1080Ti Gaming X Trio
Storage Hyperx 60 GB SSD, Samsung 850 EVO 250 GB SSD, 1 TB WD Red HDD (WD10EFRX)
Display(s) Samsung C24FG70
Case Cooler Master CM 690 with six be quiet fans
Audio Device(s) Asus Xonar DSX 7.1
Power Supply Corsair RM650x
Mouse MSI DS 200
Keyboard Tracer Avanger TRK-323 keypad
Hi everyone!
My problem is that when motherboard temp (PCH or chipset temp I think) goes above 50-51°C, the case fans starts to run full speed immediately, and it's noisy. I read that my MB chipset (Intel Z97) - and usually MB chipsets - can handle much higher temps than 50°C.
So how can I set this temp threshold higher? Or what else can be the solution?
I set fan speeds to manual in the BIOS, finetuned everything, and it works well balanced until MB temp reaches 50 or 51°C.
I have a good airflow case (CM 690) and a lot of good fans.
Thanks for the help!
2,058 (0.72/day)
System Name AM4 / 775
Processor 2600x / C2D E7600
Motherboard B450 Aorus / ASUS P5G41C-M LX
Cooling TT Esports Duo / Chinesium cooler
Memory 16GB DDR4 3ghz / 4GB DDR2 800mhz
Video Card(s) 2060 Super / 5700-XT / GTX 650Ti
Storage 120GB + 1TB SSD / 160GB SSD
Display(s) Samsung CRG5 144hz QD
Case CiT shit chassis modded / Coolermaster Elite 430
Audio Device(s) Soundblaster FX / Audigy 2 ZX
Power Supply Superflower Leadex III GOLD / BeQuiet 450w bronze.
Mouse Razer Basilisk
Keyboard Read Dragon Kumara
Benchmark Scores 1 Billion
50c is normal, i would worry once you exceed around 80c.
There must be a setting in your bios to stop auto fan speeds.
227 (0.07/day)
Manchester, UK
System Name Full LC'd Node 202 || Asus X202e
Processor i7-7700K || i3-2365M
Motherboard Asus Z270I || HM76 int.
Cooling Full Custom Loop|| Stock
Memory Hyper Fury DDR4 32GB || 4GB 1333
Video Card(s) GTX 1080 FE || HD3000
Storage 950 Pro M.2 +WD 2TB M.2 SSD || Sandisk 256 SSD
Display(s) Asus MG278Q
Case Fractal Node 202
Audio Device(s) OnBoard
Power Supply Corsair SF600
Mouse Logitech G502 ||Asus WT710
Keyboard Logitech G410 || Logitech K830
You aren't using any other temperature monitoring software to control fan speeds? i've heard this happens when speedfan is installed
18 (0.01/day)
Mouse MSI DS 200
I have temp monitoring softwares, but have not any fan control softwares like speedfan.
8,118 (2.27/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
SpeedFan has an option that will spin up fans to max when you exit. However, if you exit SeedFan and temps are still high, the MB might still spin fans up.
depending on the number of fans, might wanna consider a decent multi-channel fan controller or a fanhub with power from a molex to take the load off your mb.
13,210 (3.80/day)
Sunshine Coast
System Name Black Box
Memory G.Skill 16GB 3600 C18
Audio Device(s) No need.
Power Supply FSP Aurum 650W
Mouse Yes
Keyboard Of course
Software W10 Pro 64 bit
Are they connected to the PWM headers or the normal 3 pin Case Fan headers?
8,118 (2.27/day)
SE Michigan
System Name Dumbass
I found out that some boards might have all 4-pin PWM headers but not all of them actually are. So its prolly a safe bet to count on the 4-pin CPU fan headers to really be PWM and controllable. My board for example, only the CPU headers are PWM controlled, the rest might be PWM but not controllable.
peche
Thermaltake fanboy
6,709 (1.94/day)
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
reset you bios, save your current settings and try it out, PCH [intel chipset ] could hanlde higher temps ... above 65-70
Regards,
13,791 (1.93/day)
If it has 4, it has 4. You have to control them in BIOS what they are, PWM or DC. Some boards have this automatic (I know my Rampage II Gene had such method) which means you can't force PWM to operate in DC mode). The rest of connectors that weren't PWM capable were 3 pin only to begin with.
8,118 (2.27/day)
SE Michigan
System Name Dumbass
Some manufacturers did use 4pin where they should been using 3pin. I had a Biostar board like that.
