CeBIT: Samsung Introduces 30-inch LED-based Monitor
Discussion in 'News' started by malware, Mar 15, 2007.
  1. malware New Member
    Nov 7, 2004
    5,422 (1.16/day)
    954
    Bulgaria
    During the ongoing CeBIT show in Hannover, Samsung Electronics is introducing a 30-inch LCD monitor that incorporates an LED as the backlight source. Featuring a 123% color production, 3000:1 dynamic contrast ratio, 2ms response time and viewing angle of 170 degrees, this monitor has the perfect specs. The SyncMaster XL30 will come equipped with "Eyeone Design & Eyeone Photo" and "Natural Color Expert" software. Various input terminals such as USB terminal, DVI-D are available and the 30-inch monitor also features HDCP for viewing high-definition (HD) contents via DVI ports. At the show, Samsung is also launching the 19-inch SyncMaster 940UX LCD monitor we told you about earlier this year, that can be connected using only an USB port.
    Source: DigiTimes
    10 Year Member at TPU
  2. WarEagleAU
    WarEagleAU Bird of Prey
    Jul 9, 2006
    10,809 (2.66/day)
    548
    Gurley, AL
    Pretty awesome. But, with an LED, is it white light or red light they are using?
  3. kakazza New Member
    Aug 25, 2006
    470 (0.12/day)
    7
    What kinda stupid question is that? Think before you post.
    Edit: But to answer your question, last time I checked (months ago, so maybe they found a new way) they used a red, green and blue LED to create white light. I think Osram calls it "MultiLED".
    Edit2: Ok, I got curious so I checked again and found a whitepaper:
    http://www.cree.com/products/pdf/Backlighting_Revolution_White_Paper.pdf
    Shows the RGP-LED solution and others. (Blue LED + Phosphor layer)
    Oh well, not like you post more than once in a newsthread or actually read the news >_>
