Clamwin Open Source antiviris/Norton 360 2010
Exile_Chavez
283 (0.05/day)
System Name Build 1
Processor AMD Phenom II X4 955 3.2ghz
Motherboard MSI 770-C45 AM3 AMD 770 ATX AMD Motherboard
Cooling Xigmatek Dark Knight, 3 120mm Intakes, 1 200mm Exchaust, 2 140mm Exchausts
Memory OCZ Gold 4GB 240-Pin DDR3 1333mhz
Video Card(s) XFX HD-577A-ZNDC Radeon HD 5770 XXX Edition 1GB 128-bit DDR5 PCI Express 2.0 x16 HDCP
Storage WD Blue 640GB 7200 RPM
Display(s) ACER 23" Full HD HDMI Widescreen Monitor
Case NZXT Phantom Black
Audio Device(s) None
Power Supply OCZ StealthXStream 700W ATX12V/EPS12V SLI Ready Crossfire Ready
Software Windows 7 Home Premium 64-bit
So I have a question. I found this antiviris program called clamwin. I would like to know if its good or not. I have Norton 360 2010 edition currently installed.
there decent last i heard they passed the virus bulletin tests to be certified so its much the same as avast AVG free etc etc as long as its certified its good enough for the average user
and for the record i hate norton
basically if its certified with the VB 100 its good enough
http://www.virusbtn.com/vb100/rap-index.xml
basically in that little graph there the ones cloest to the top and the farthest to the right is the best ;) hope that helps if u dont see your AV on there look up who the creator is example Norton = Symantec
the only downside to Clamwin is its a manual only scanner meaning it has no automatic detection so u have to scan files manually so its rather limited
Sweet. Thank you for the response and the graph
