Cooler Master Seidon 120V V3 how to open one way screw?
4 (0.00/day)
System Name i miss my 6 core xeon :/
Processor i5 9600K Stock
Motherboard Gigabyte Z390UD
Cooling Cooler Master Seidon 120 V3 Plus
Memory 16 GB Gskill @3000mhz 15-16-16-35 2x8GB
Video Card(s) Oem Asus 1060 3G
Storage Crucial BX500 240 GB / Kingston A2000 500GB / Seagate 500 GB SHDD + Optane 16GB
Display(s) Dell S2421HGF
Case Cooler Master RC 690
Audio Device(s) Xonar U7 Echolon
Power Supply Cooler Master V750
Mouse Asus Rog Sica
Keyboard Steelseries Apex M400
I'm using this cooler for a long time its performs decent but its too old its probably have a gunk in that cold plate but i dont know how to open a one way screw without damaging the cold plate or that screw slot
Thanks for any advice!
Edit: i think im gonna try to shape it to philips pattern with dremel or something...
stinger608
10,850 (2.11/day)
Wyoming
Processor Intel 4790K/AMD Ryzen 3700X
Motherboard MSI 1150 Gaming mATX/Gigabyte AORUS ELITE B550
Memory 16 gigs Crucial Ballistix Tactical Tracer/16 gigs G.Skill TridentZ NEO DDR4
Video Card(s) Gigabyte 1660 Super/Gigabyte GTX 1660
Case Corsair Air 540
Audio Device(s) On board
There is a special tool for pulling that type of screw. A lot of commercial applications use that same type. Not sure where a person can get one though.
4 (0.00/day)
Mouse Asus Rog Sica
I saw that kinda tools online but im living in third world country so thats not gonna work :D
maybe you could try a normal srcew driver and go gently, maybe it loosens enough so that you can remove it safely
I tried that but no luck
Im working, probably try something tomorrow thanks...
139 (0.51/day)
well, I dont know what else I could sugest on this, you wil have to be creative on this one, sorry
dorsetknob
9,074 (1.40/day)
Ghetto fix :)
Cut the tip off a knackered Screwdriver, ( note it should be hardened steel).
Shape (file or Dremmel ) End of cut screw driver to size.
Deleted member 24505
What about a damaged screw remover, they grip in reverse.
7,803 (2.55/day)
SE Michigan
System Name Dumbass
Processor AMD FX-9370
Motherboard ASUS SABERTOOTH 990FX R2.0 +SB950
Memory G.Skill Sniper 16gb DDR3 2400
Video Card(s) GreenTeam 1080 Gaming X 8GB
Storage Samsung EVO 500gb & 1Tb, 2tb HDD
Power Supply Corsair HX1000i
Mouse Logitech G604
Keyboard Logitech G910 Orion Spark
Software windows 10
I used a jewelers screwdriver as a chisel to loosen, then it was easier to use a screwdriver. I have not found the right screw to replace them so only took 1 out.
CH7
2 (0.03/day)
I had the same problem, i didn't even know it was a screw until i found this forum. I thought it was solder.
Anyway, I searched and found this hack on youtube for removing 'clutch head one-way screws'.
The best tip is about 4:10 in, it involves a device called a spring-loaded center punch.
I happen to have one and found this worked.
1,581 (2.38/day)
Germany
Processor AMD Ryzen 7 5800X3D (-30 CO)
Motherboard MSI B550 Tomahawk
Memory 2x16GB G.Skill Trident Z Neo 3600 Mhz CL16
Video Card(s) Sapphire Radeon RX 6900XT Nitro + (2710 Mhz/2100 Fast 375W)
Storage Corsair MP 600 Pro 1TB, Crucial P5 Plus 2TB, 2x Samsung 870 QVO 4TB (external)
Display(s) Alienware AW2723DF, LG GP850-B, LG GN950-B
Case Streacom BC1 V2
Audio Device(s) Bose Companion Series 2 III, Sennheiser GSP600 and HD599 SE - Sharkoon Gaming DAC Pro S V2
Power Supply bequiet! Dark Power Pro 12 1200w Titanium
Mouse Logitech G303 Shroud Edition, G502 X
Keyboard Corsair K65 RGB Mini
VR HMD Oculus Rift S
rubberband + screwdriver.
CH7
2 (0.03/day)
Just to add, I found there was a lot of copper oxide on the plate, so the heat fins needed a could clean. Also, I think they used some kind of silicon glue, as something like that residue to be cleaned off the copper plate.
I also replaced the coolant with this stuff - 'XSPC XS-EC6-CL Non Conductive Coolant' , which is also supposed to be electrically non conductive.
https://www.amazon.co.uk/gp/product/B008PA1G00/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
It was relatively easy to refill with the back plate off. A syringe was used whilst jiggling the radiator to get the air out.
qubit
Overclocked quantum bit
17,609 (3.22/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
Those one way screws are evil. Just look at what it takes to remove them.
7,803 (2.55/day)
SE Michigan
System Name Dumbass
Mouse Logitech G604
Software windows 10
yea and its hard to find replacement normal screws.
