Cooling system for i7-8086k (i7-8700k) @ 5.1-5.3 GHZ
Knoxx29
The Power Of Intel
5,951 (3.38/day)
Likes
4,366
Behind a VPN
System Name Black Widow/Red Queen X3
Processor i7 8086K 5.3GHz 1.36V/ Xeon X5690 4.5 GHz 1.377
Motherboard Asus Rog Maximus X Hero / Evga X58 Classified 3
Cooling WaterChiller - both Machines looped
Memory G.SKILL Trident Z 3866MHz @4000MHz - G.SKILL RIPJAWSX V 3000MHz 32GB - G.SKILL RIPJAWSX 2133MHz 12GB
Video Card(s) EVGA GEFORCE GTX 1080 CLASSIFIED/ Zotac 210
Storage Samsung 960 EVO - Samsung 850 EVO 250GB - WD Blue 1TB - WD Black 1TB/ Samsung EVO 250GB
Display(s) Asus PG278Q ROG/ Samsung
Case Cougar Panzer Max/ Lian Li
Audio Device(s) On Board
Power Supply Enermax Platimax 1000W 80plus platinum Super Overclock Edition ATX2
Mouse Logitech G502 spectrum
Keyboard Virtuis Advanced Gaming Keyboard
Software Windows 10 Pro.
#51
As @Vario mentioned today if Cinebench use AVX, i am curious too
Edit: I ran CineBench using -1 AVX and clock speed didn't drop.
3,786 (1.06/day)
Likes
1,780
Ohio
System Name Fractured puke.
Processor Intel I7-8700k
Motherboard MSI z370 Gaming M5
Cooling Corsair H110i
Memory 16GB G.Skill TridentZ 3200MHZ
Video Card(s) Nvidia 1070ti
Storage 960 EVO 500gb/256gb WD Black 2280 M2/Patriot Ignite 480gb SSD/ Inland Pro 256gb SSD
Display(s) Acer 32" 2560x1440
Case Fractal Design Meshify-C
Audio Device(s) Onboard/ TBD
Power Supply Seasonic
Mouse Epicgear
Keyboard Razer Deatstalker
Software Windows 10Pro x64
#52
OMG..
Just putting this out there...
If you have a mixed metal cooling system aka aluminum rads, copper block use something like Hercules corrosion. Inhibitor.
It's $30 but gives you a lifetime supply at that price
Knoxx29
The Power Of Intel
5,951 (3.38/day)
Likes
4,366
Behind a VPN
#53
43 (0.69/day)
Likes
37
Processor i7-8086k
Motherboard ASUS ROG MAXIMUS X CODE
Cooling EVGA 240 WATERCOOLER
Memory G.SKILL DDR4 3200MHZ CL14
Video Card(s) EVGA GeForece 1070ti SC Hybrid
Storage WD Black M.2 NVMe 4x 500gb
Power Supply Dell 1100w (T7500)
Benchmark Scores https://valid.x86.fr/uwqpn1
#54
That would be hilarious if someone does.
Dont forget to add saltwater to the cooling loop. It has a lower heat index and will help the mixed metals bond faster!
So I spent the afternoon optimizing the ram, bclk, and am about 50% into the video card. So far so good and all is stable with some decent increases without changing the cpu heat (which I feared being the controller for the ram is on the CPU). What I just figured out is I can control the pump and fans on the cpu watercooler which may cause me to start over now that I have a little more control over the heat situation. 5.3 with avx-1 may be attainable now with realistic temps, I will find out tomorrow. It also looks like I may have up to another 100mhz on the gpu and another 200mhz on the gpu ram but its a work in progress, and I have a 1080ti on loan to a friend that I should have back the end of this month anyway so I'm not too worried about the gpu right now.
Anyway I increased my passmark by 566 points which was impressive!
**** EDIT **** just realized XOC wasnt showing the stats in the pic above
700 (0.16/day)
Likes
211
Processor i7 8086k @ 5.1 Ghz
Motherboard Asrock Z370 Taichi
Cooling Bitspower Monoblock, EK GPU FC Blocks, 2x 480 swiftech rads, D5, Monsoon Dualbay Res
Memory 32gb G.Skill DDR4 3200mhz CL14
Video Card(s) 2x EVGA 1080Ti FTW3 DT
Storage Samsung Evo 860 500gb, Samsung Evo 860 1Tb x2, WD Red 6TB x3
Display(s) Acer xb270hu 144hz 2560x1440
Case Enthoo Primo
Audio Device(s) Schiit Modi Multibit/Magni3 - M1060 (fuzzor+LQi cable+Eikon suede)/ATH-W1000X (Purrin's mod+suede)
Power Supply EVGA SuperNova 1300w
Mouse Logitech g403
Keyboard Insignia
Software W7 Pro 64 bit
#55
For those that were wondering I have some results:
I'm running at a super stable 5.2ghz AVX -1 with a healthy 1.424v without exceeding 90c in any test (I'm going op back the voltage down but I wanted the head room for testing).
I ran Prime95 stable for 1 hr = max 89c on one core <= 86c on the rest of the cores
I also ran firestrike v1.1 https://www.3dmark.com/3dm/30267016
Below are screenshots of the other tests I ran (all back to back with no reset). Unfortunately CPU-Z will not show my current score at these settings - it just keeps popping up with my 5.386ghz run @ 95c (which was unsustainable with my cooling solution)
Now to start clocking the ram.
View attachment 110460 View attachment 110461
@totalfreq what kind of temps are you hitting just on a cinebench run at 5.2 1.424 and your EVGA 240?
I have just put together an 8086k (delidded CLLP between die and RockitPro copper IHS and CLLP between the ihs and monoblock), z370 taichi, g.skill 32gb 3200 cl4 in a water loop with 2x 480 rads and a bitspower monoblock and I think I may have a dud of a chip. At 5.2 I need over 1.4v and cinebench slams my temps up to mid-high 90's almost immediately. Not to mention Realbench and other AVX stuff.
Right now I am at 5.1 @ 1.36v (manual volts 1.35 in bios, LLC auto)and a single cinebench run gets me in the mid 80s range.
I am thinking I may need to pull apart my loop, reseat my IHS, maybe put the original IHS back on in case the all copper one is just not making proper contact. Things seem out of whack. Although gaming temps barely brush 60C, which seems about right no?
@Knoxx29 @totalfreq Thoughts?
Edit: Also, are you guys using High Performance Power Plan in Windows? Or Balanced?
Knoxx29
The Power Of Intel
5,951 (3.38/day)
Likes
4,366
Behind a VPN
#56
Wait wait wait, let me see if i got this straight, you applied CLLP between the IHS and the Waterblock? i hope i misunderstood what you wrote
700 (0.16/day)
Likes
211
Case Enthoo Primo
Mouse Logitech g403
Keyboard Insignia
#57
Correct. I had CLLP on my 4790k IHS and my raystorm block for about 2 years and I just took it apart last week. It leaves some stain, but a little lapping gets it to come right off.
The monoblock isn't aluminum so it should not be a problem. Have you heard otherwise?
10,315 (2.50/day)
Likes
9,277
System Name Pioneer
Processor Intel i7 8700k @ 5.0 GHz All-Core + Uncore & AVX Offset @ 0
Motherboard ASRock Z370 Taichi
Memory G.SKILL TridentZ Series 32GB (4 x 8GB) DDR4-3200 @ 3333MTs 14-14-14-34-2T
Video Card(s) EVGA GTX 1080 FTW2
Storage HGST UltraStar 7K6000 3.5" HDD 2TB 7200 RPM (w/128MBs of Cache)
Display(s) LG 32GK850G-B 1440p 32" AMVA Panel G-Sync 144hz Display
Case Thermaltake Core X31
Audio Device(s) Onboard Toslink to Schiit Modi Multibit to Asgard 2 Amp to AKG K7XX Ruby Red Massdrop Headphones
Power Supply Seasonic PRIME 750W 80Plus Titanium
Mouse ROCCAT Kone EMP
Keyboard WASD CODE 104-Key w/ Cherry MX Green Keyswitches, Doubleshot Vortex PBT White Transluscent Keycaps
Software Windows 10 Enterprise (From former workplace, yay no telemetry)
Benchmark Scores FSext/TS: FSext 10770:https://www.3dmark.com/fs/17394505 TS 8140:https://www.3dmark.com/spy/5371816
#58
sound like the members on this site?
No. I even am a delidder and I agree: Unless you are a hardcore enthusiast or something it really should be treated as a last resort measure.
I wouldn't go around calling members of this site tech-illiterate by the way, you might get stung.
Knoxx29
The Power Of Intel
5,951 (3.38/day)
Likes
4,366
Behind a VPN
10,315 (2.50/day)
Likes
9,277
System Name Pioneer
#60
As long as it is Nickel-plated you should be fine. Copper is even ok, but longevity suffers.
I would only recommend using CLLP between CPU die and IHS.
You may, but if you are really going all out there's no harm in applying it all over provided it's done carefully and correctly (I know I know, it's ironic this coming from "Mr. CPU socket murderer" but bear with me).
It's easy to screw up though so be cautious doing it.
700 (0.16/day)
Likes
211
Case Enthoo Primo
Mouse Logitech g403
Keyboard Insignia
#61
Yeah I hear ya. Since I bought an IHS just for the chip I decided to CLLP the IHS to block as well. I'm likely going to do a teardown and use the original IHS and some regular paste since I don't to mess up the original IHS.
Your thoughts on my temps though? Does it seem odd?
@R-T-B yes the block is nickel-plated.
Knoxx29
The Power Of Intel
5,951 (3.38/day)
Likes
4,366
Behind a VPN
#62
I am too paranoid about temps so i would say for a Delidded CPU that hit those temp with 2x 480 rads temps are high, however try as you said use the original IHS and some regular paste and see if something change
4,655 (0.97/day)
Likes
2,314
USA
System Name Small ATX Desktop
Processor Intel i5 8600K @ 4.6 GHz Core & 4.3 GHz Cache @ 1.168V
Cooling Phanteks PH-TC14PE, Fans: 2xThermalright TY143 / 2xCorsair SP-120L / 1xYate Loon D14BH-12
Memory G-Skill TridentZ 2X8GB DDR4 3200 CL14 F4-3200C14D-16GTZ @ 3200 14-14-14-34 2T @ 1.35V
Video Card(s) Zotac 1060 6GB Mini ZT-P10600A-10L
Storage Seagate 600 240GB SSD + 2xWD Caviar Blue WD10EZEX 1TB Data
Display(s) 2x Asus PB258Q 2560x1440 25" IPS
Case Lian Li PC A05NB (Inverted Mobo)
Audio Device(s) Audiotechnica ATH M50X, Antlion Mod Mic 4, SYBA SD-CM-UAUD, Acoustic Research 2Ch Speakers
Power Supply Seasonic SS-660XP2 660 Watt Platinum
Mouse Zowie EC2A Mouse, Corsair MM600 hard pad, on top of a Inateck 900x300 XL pad, Tiger Gaming Skates.
Keyboard Filco Majestouch II Ninja TKL, Goldtouch GTC 0033 Ten Key, PS3 Controller
Software Win7 Pro 64 (Installed on Coffee Lake using AsRock's handy PS/2 Simulator in Bios)
#63
CLLP/CLLU tarnished my copper heatsink ages ago, required lapping to make it level again, but nickel plated probably okay.
700 (0.16/day)
Likes
211
Case Enthoo Primo
Mouse Logitech g403
Keyboard Insignia
#64
Yeah I think that is what I will do. I appreciate your time. I'll come back when its done, it may take a while.
@Vario yeah my Raystorm is copper and it looks ugly, but a little lapping will clear it up and I'll re-use it. But was fine for about 2 years with liquid metal on it.
Knoxx29
The Power Of Intel
5,951 (3.38/day)
Likes
4,366
Behind a VPN
#65
CLLP/CLLU tarnished my copper heatsink ages ago but nickel plated probably okay.
Probably but not sure;) not a lot of people doing it out there
4,655 (0.97/day)
Likes
2,314
USA
#66
It left a white birdshit raised up alloy on the top that was rough to the touch. Good news was the pump died on the thing around that time, so despite fixing it with lapping, I ended up throwing it away. Given that the lid itself is nickel plated and those don't react to gallium, it will probably be okay.
43 (0.69/day)
Likes
37
Processor i7-8086k
#67
@Knoxx29 @totalfreq Thoughts? View attachment 111865
I will have to check later - I dont have the PC setup at the moment but I always test with HWMon open and I wouldnt have settled at 5.2 if it were in the 90s (I would have declocked). Also I'm not delidded so you should be even lower. I'll test again though and let you know.
Speed stepping, hibernate, sleep - all BS that I turn off. I asic mine at home so my power bill is already around $700-1000/mo so the extra 100w+ for the cpu and HDD really doesnt affect my power bill. Also, over the years Ive seen tremedous data loss from sleep and hibernate modes - I wouldnt recommend ever using them.
23,792 (5.69/day)
Likes
7,707
700 (0.16/day)
Likes
211
Case Enthoo Primo
Mouse Logitech g403
Keyboard Insignia
#69
Turns out I had applied too little liquid metal on the IHS -> monoblock. When I took it apart there was barely any residue on the monoblock itself. I only applied a thin layer to the IHS, not to the monoblock as well so my contact was not ideal. When I do the die -> IHS I put a thin layer on both to make sure adhesion is good but since I have also killed parts with liquid metal in the past I went a little too shy on my application for the IHS -> monoblock for fear of a spill over.
Anyway, I put the original IHS back on with liquid metal between the die and IHS, then EK TIM between the IHS and monoblock. Temps are much better now. But I don't know about getting up to 1.42+ volts to get 5.3 stable . You must have a nice chip on your hands @Knoxx29 and I'm sure the water chiller helps.
Knoxx29
The Power Of Intel
5,951 (3.38/day)
Likes
4,366
Behind a VPN
#70
Glad to hear you found where the issue was.
Delidding sometimes helps with voltages but unfortunately it doesn't always works that way it looks like you got a power hungry CPU and you can't do much about it maybe tweaking it a little bit could help with voltages.
I guess so, the Chiller helps just when Benching.
43 (0.69/day)
Likes
37
Processor i7-8086k
#71
So I just got everything setup, (had the system off this weekend as I'm playing with a new one lol). I opened HWMon, and then ran Realbench so I wasnt on a cool/startup run and I then ran Cinebench15 through the GPU/Multi/Single and took a screenshot.
To note I have done a little more tweaking since the last bench upping my blck 0.5% to get around 5.23ghz AVX -1 stable. I also have my 3200mhz ram dialed in to 14-14-14-34 @ 3750Mhz which has raised my heat a bit due to the controller being on the CPU, but I'm happy if my max bench temp stays 10% below throttle as my real use temps will be at worst in the 60-70c ranges. I'f I drop the ram OC back down to say 3300mhz my cpu core temps drop down to around max 88c.
Remember I'm using an off the shelf clc, not delidded, but I did use my own thermal paste (generous but not overkill).
167 (0.48/day)
Likes
60
System Name Silent
Processor i7 8700k delidded and OC'd to 5.3
Motherboard Asrock Z370 Extreme 4
Cooling Noctua NH15
Memory G-Skill Trident Z RGB 3200 14CAS
Video Card(s) 1080ti w/morpheus cooler w/Noctua 140mm fans
Storage Optane 905p 500gb, 2 x 1tb 970 Pro Raid 0
Display(s) 144hz 1440p
Case Coolermaster Cosmos
Power Supply Seasonic Prime Titanium 600w Fanless
Benchmark Scores Cinebench 1725
#72
That's decent for off the shelf CLC non delidded, with your settings. You could probably drop temps around 10c by delidding and liquid metal, personally i'm uncomfortable with anything over 85c, 90c would be a big no no for me.
Knoxx29
The Power Of Intel
5,951 (3.38/day)
Likes
4,366
Behind a VPN
#73
Lucky you, anything over 50c and i start tearing my hair out:roll:
If he is lucky 15c/20c, the max drop i got was 25c with a 3700K
43 (0.69/day)
Likes
37
Processor i7-8086k
#74
I'm not too afraid of running a processor within its spec. I pushed my first P233MMX up to 290mhz back in the mid 90s and ran it for about 8 years without issue (other than it being too slow 6 months later lol). I also saw puffs of smoke come out the back of PCs as other OC'd chips blew over the years - Ive learned how to overclock through trial and error, and do it manually with my voltages all the way up and the clocks all the way down working backwards watching thermals. Though you may not be comfortable with 90c (or 50C for Knoxx), 90c on a bench is still 10% below thermal throttle limit and I'll likely never see it in realworld application for any extended period of time. Also the vcore limit is above 1.5 and I'm no where near that so my maximum current capacity is still "processor safe".
In testing I had the ram up at 4000mhz and I hit 95c on prime 95 before the 5min mark (when things really cook) . I shut it all down and declocked. Reason is the memory controller is on the CPU. I can either choose to clock up the CPU or the RAM or find a happy medium which is where Im at. Even though in real world I'd likely never still see the thermal throttle that prime 95 would have hit, that was outside my comfort zone.
If I'm going to delid and go custom (which I dont have time for right now), I'm heading to what the cool kids call phase change. I've been in refrigeration for the past decade+, and have my EPA license so I can buy/build the cool (no pun intended) toys most people cant. I have a few direct expansion (read phase change) air conditioners lying around I have considered parting out to build a CPU/GPU cooler, but just dont have the time right now. One day maybe.
The other thing I'm considering is immersion. Not for my computer, but for my ASICs. I currently crypto mine and run my ASICs at a whopping 150% average overclock. My issue is heat. I basically use fans on their side of the ASICs to create forced induction, and then actual condition the air using direct expansion cooling which is quite power hungry, but its still more profitable than running them without OC in a non AC room. But Ive toyed with how I can get an even greater overclock, using more efficient cooling. My thought is to not only drop an ASIC in mineral oil (for 8x heat dissipation vs air), but then (thanks to KNOXX), run the mineral oil through a fish tank chiller....It would be cheaper than my current cooling and probably net me additional OC headroom...my concern is KABOOM! Ive seen transformers blow during hurricanes and that mineral oil make one heck of green ball of fire. If I get brave enough to try it I'lll post the info.
For now though - im happy with my current build above 5Ghz using off the shelf parts.
167 (0.48/day)
Likes
60
System Name Silent
Cooling Noctua NH15
#75
Max core temp is 98C (Tjunction). Intel recommend a max of 72C for (Tcase) (entire CPU). That's conservative, but 80c+ is a nono for me.
