Corsair MP600 Core and Water Cooled MP600 PRO HydroX SSDs Pictured
45,584 (7.72/day)
Newegg listings indicate Corsair is ready with the MP600 Core and MP600 PRO HydroX, which they state release later today. The MP600 Core is an M.2 NVMe SSD that's a cost-effective variant of the MP600 PRO. Built in the M.2-2280 form-factor, the drive takes advantage of PCI-Express 4.0 x4, but unlike the MP600 PRO, uses QLC NAND flash memory. The drive uses the Phison PS5016-E16 controller just like the original MP600, but swaps out its TLC NAND flash for QLC. On offer, are sequential transfer rates of up to 4950 MB/s reads, and up to 3700 MB/s writes, up to 380,000 IOPS 4K random reads, and up to 580,000 IOPS 4K random writes.
The MP600 PRO HydroX, on the other hand, is a premium variant of the MP600 PRO that comes with a factory-fitted water block that you connect to your DIY liquid cooling loop. It uses the same combination of the latest Phison PS5018-E18 controller with 3D TLC NAND flash, and offers the same on-paper performance, with up to 7000 MB/s sequential reads, up to 6550 MB/s sequential writes, up to 660,000 IOPS 4K random reads, and up to 800,000 IOPS 4K random writes. The MP600 Core and MP600 PRO HydroX are expected to launch alongside the original MP600 PRO, later this week. Both the MP600 Core and MP600 PRO HydroX are listed on the international stores of Newegg, with the 2 TB MP600 PRO HydroX going for $459, and the 2 TB MP600 Core going for £286 (incl. VAT).
5,271 (0.97/day)
System Name Cyberline
Video Card(s) AMD RX480 -> ... nope still the same :'(
Mouse Elecom EX-G
Keyboard Rapoo V700
seems about as needed as watercooled ram
455 (0.15/day)
System Name My Addiction
Processor AMD Ryzen 5900X
Motherboard Asus Crosshair VII Hero
Memory G.Skill Trident Z 32GB 3200MHz
Video Card(s) Sapphire Pulse 7900XTX
Storage Some SSDs
Display(s) 42" Samsung TV + 22" Dell monitor vertically
Case Fractal Design Define 7 XL
Audio Device(s) Denon + Bose
Power Supply Seasonic 1000W
Mouse Logitech
Keyboard Glorious
VR HMD None
Software Win 10
Benchmark Scores None taken
I bet they know that waterblock literally halves the lifetime of the ssd...
deu
492 (0.18/day)
System Name Bo-minator (my name is bo)
Processor AMD 3900X
Motherboard Gigabyte X570 AORUS MASTER
Memory G-SkiLL 2x8GB RAM 3600Mhz (CL16-16-16-16-36)
Video Card(s) ASUS STRIX 1080Ti OC
Storage Samsung EVO 850 1TB
Display(s) ACER XB271HU + DELL 2717D
Case Fractal Design Define R4
Audio Device(s) ASUS Xonar Essence STX
Power Supply Antec HCP 1000W
Mouse G403
Keyboard CM STORM Quick Fire Rapid
Software Windows 10 64-bit Pro
Benchmark Scores XX
To behonest there IS a need for better cooling the NVMe's since they throttle, but we can agree that watercooling is taking it 3 steps too far :D And as Kohl Bass notes: lifespan will go down if temps are too low on that type of hardware which adds to the insanity
1,815 (1.52/day)
Bulgaria
$460 for 2tb...if was MLC price is almost fear but for TLC is too high.
1,592 (1.18/day)
I assume they do. And all the more better for them so that your SSD will kick the bucket earlier, and you need to get new ones faster. Haha.
In my opinion, people that requires SSD with high sequential read/write speed are using their PC for photo/ video editing kind of use case. Chances of these people using custom coolers is quite slim. I feel its mostly gamers that will go custom cooling. So while I agree that NVME SSDs need better cooling, on the other hand, the faster sequential speed makes no tangible improvement for gamers. Game don't run nor load faster with these "fast" SSDs.
8,064 (2.35/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Video Card(s) GreenTeam 1080 Gaming X 8GB
Power Supply Corsair HX1000i
Mouse forgot....
Software windows 10 H
whoever buys this will likely need hard tubing because soft tubing is not supportive and any wiggle could physically damage the mounting and/or the ssd itself.
62 (0.04/day)
Germany
Processor Ryzen 5 3600
Motherboard MSI B450M Gaming Plus
Cooling EK Supremacy EVO, Bykski N-GV1080TIG1-X (Gigabyte 1080TI Turbo) [280mm front, 240mm top, 120mm back]
Memory 16GiB 3600Mhz CL16 Patriot Viper
Video Card(s) Gigabyte GTX 1080Ti Turbo
Storage 4TiB Seagate Baracuda + 256 GiB Samsung 970 Evo Plus (StoreMI) & 500GiB Intenso SSD
Display(s) MSI Optix MAG271CR
Case CoolerMaster NR600
Power Supply Seagate Focus Plus 650 Watt GOLD
Mouse Sharkoon SHARK Force
Keyboard ReIDEA KM06
Well the controller needs cooling otherwise it will thorttle, but it seems that NAND has a lower error rate at higher temperatures. If the waterblock is designed that way, then i wont complain. watercool all the things!
1,457 (0.56/day)
NH, USA
System Name Lightbringer
Processor Ryzen 7 2700X
Keyboard Royal Kludge RK71
It's funny you should say that, because about two years ago I thought: "I bet a RAM cooling block would be perfect for an M.2 SSD" and it actually worked perfectly with one minor modification, but that looks exactly like what corsair has done here in a way, albeit smaller than a RAM block it looks
217 (0.04/day)
Actually they will not be available today. It seems you can 'pre-order' these items today on Newegg with expected availability around 27 February.
455 (0.15/day)
Storage Some SSDs
Mouse Logitech
Keyboard Glorious
VR HMD None
Software Win 10
SSD is a funny thing in this regard. NAND does not like to be below 50°C when writing in opposition with the controller chip which does not like to be warmer than 60°C. The best compromise was a not too big aluminum heatsink which transferred the heat of the controller to keep the NAND warm. This thing is overkill... Unless you have a balanced dual-loop system with 50-55°C water temp for the GPU. That would be absolutely ideal for this.
1,852 (0.28/day)
Toronto, Ontario
System Name The Expanse
Processor AMD Ryzen 7 5800X3D
Motherboard Asus Prime X570-Pro BIOS 5003 AM4 AGESA V2 PI 1.2.0.B
Cooling Corsair H150i Pro
Video Card(s) AMD Radeon RX 7900 XTX 24GB
Storage WD SN850X 2TB / Corsair MP600 1TB / Samsung 860Evo 1TB x2 Raid 0 / Asus NAS AS1004T V2 14TB
Benchmark Scores 3800X https://valid.x86.fr/1zr4a5 5800X https://valid.x86.fr/2dey9c
The MP600 Core using QLC but why?
The regular MP600 uses TLC and the same controller so why would you buy the QLC version.
7,916 (5.69/day)
Louisianna
System Name Ghetto Rigs x299|z490|x99|Acer 17 Nitro 7840hs/ 4060/ 1tb acer stock m.2/ 4tb sn850x
Processor 9940x w/Optimus Foundation | 10900k w/Black Noctua D15 | 5930k w/Reg-Noctua D15
Motherboard X299 Rampage VI Apex | z490 Maximus XII Apex | x99 Sabertooth
Cooling D5 combo/280 GTX/ VRM copper water block/280 GTX/ Optimus Foundation/ 1080ti FTW3
Memory Trident-Z 3600C16 4x8gb | Trident-Z Royal 4000c16 2x16gb | Trident-Z 3200c14 4x8gb
Video Card(s) 1080ti FTW3-On Loop | Titan Xp-w/ Only GPU loop | evga 980ti gaming-w/ air
Storage 970evo500gb/ 980Pro2tb|970evo+/ sn850x 4tb |Acer m.2 1tb/ sn850x 4tb| Many 2.5" sata's ssd 3.5hdd's
Case D450 second floor for 2nd rad x2/ Cherry Entertainment center on Test bench
Power Supply EVGA 1200P2 | 1000P2 with APC AX1500 | 850P2 with CyberPower-GX1325U | a 750P2 unused
Mouse Redragon Perdition x3
Keyboard G710+x3
Fan would of been better heck I have a few of those they do work :cool:
283 (0.21/day)
Holy cow, did any of you took any EE classes? Or just plain engineering grade physics?
"NAND does not like below 50°C" :O
Any flash based storage system benefits from lower operational temperature for longer lifespan, because the inherit resistance is lower thus cell degradation during destructive flash process is lesser.
