- Nov 16, 2007
- 857 (0.16/day)
- Hampton Roads
Processor | Xeon 5650 |
Motherboard | SABERTOOTH X58 |
Cooling | Fans |
Memory | 24 GB Kingston HyperX 1600 |
Video Card(s) | gtx1060 |
Storage | small ssd |
Display(s) | Dell 2001F, BenQ short throw |
Case | Lian Li |
Audio Device(s) | onboard |
Power Supply | X750 |
Software | Mint 19.2 |
Benchmark Scores | not so fast... |
For grins, just for experiment, take a box from one room and put it in place of a different box. Note the results. If the same box has the same probl3m in a different location, we might suspect the box. Or, if the problem is different, its the location, not the box, that is causing the issue.
Not sure if you know this....the RF signal that the box uses to tune the channel is riding on the surface, or skin of the center conductor. The outer shield can play an important role, too, but not so much in the case. A solid sheathing is more important than perfect shielding. If there is/are imperfections (cuts, scratches, sharp bends, kinks, nicks, etc) the signal will be negatively impacted.
If its not too much effort, swap the boxes around
