- Nov 11, 2010
- 176 (0.06/day)
- Likes
- 14
Processor | Intel i5-3450 3.1GHz |
Motherboard | ASUS P8Z77-M |
Memory | G-Skill DDR3 8GB (2x4GB) RipjawsX Dual Channel 1600MHz |
Video Card(s) | HIS Radeon HD 7950 IceQ X² Boost Clock |
Storage | OCZ Agility 2 64GB |
Display(s) | Samsung SyncMaster P2450H 24" |
Case | X Blade |
Power Supply | OCZ Fata1ity 550W |
Software | Windows 7 x64 |
Hello,
My pertinent system specs are:
NZXT S340 Elite
Asus Maximus Code IX
Intel i7-7700K
G-Skill Trident Z RGB (2x8GB)
Asus ROG something or other 1070
Had a NZXT Kraken X62 v1 for cooling, up until yesterday when the pump decided to give up. Was the first AIO I had bought..and probably the last (for now). Hence looking for a suitable Air cooler recommendation which has adequate clearance for my components. Was going to go for the Noctua DH15, but believe its not gonna fit unless you start faffing with moving the fans to be as low as possible - rather just get an cooler which will just sit in as designed.
Been looking at this as a solution https://www.amazon.co.uk/Noctua-NH-...&qid=1544991811&sr=1-5&keywords=noctua+cooler , but open to recommendations
In addition to the air cooler, I'll probably need to get an intake fan, as I had my kraken 280 radiator at the front - whats the recommendation -> 1x 140mm Noctua fan or worth getting 2 for front intake?
Thanks
NZXT S340 Elite
Intel i7-7700K
Thanks
