CPU fans spinning asynchronously - CPU exhaust fan is slower than the intake fan
47 (0.04/day)
Hello there. Recently I noticed that my exhaust CPU fan pointing to the back is slower than my CPU intake fan, to the point where the fan will turn off completely for a few seconds then spin up a little bit again, before powering down again slowly. I've checked the cables but didn't find anything obvious, will try again. Also tried setting the fan curve in the bios with the fan curve optimization tool on the b450-f gaming motherboard, but is still acting weirdly. Will even turn off while gaming
The CPU cooler is a Cooler Master MA610P.
Any idea why something like this could happen?
1,078 (0.39/day)
Processor Intel i5 8400
Storage 500GB 850 Pro
Power Supply Seasonic S12II 520w
Software W11 Pro
Check if your mobo has a desktop software suite you can install. BIOS typically offers basic fan controls.
If this isn't a hardware fault it mirrors the behavior of an efficiency setting that spins the fan down when the assigned temp sensors are low. If your cpu cooler is performing exceptionally well that would offer a partial explanation. Why the exhaust fan is doing this and not the intake fans is weird to say the least. Typically cpu/exhaust run independently but at a base speed they never drop below.
I'm one who always suggests a physical inspection - carefully reseating fan connector (on the correct 3 pins if not PWM) - never hurts.
Edit: I should try actually reading and making sure I comprehend the question before responding.
16,570 (2.56/day)
Try another fan header and create a fan curve in the BIOS for it.
(I had an issue with my noctua exhaust fan stopped spinning on at the login screen, connected to another header, it seems fine so far)
2,309 (3.40/day)
Knoxville, TN, USA
Another method is a fan splitter - if it does not mirror the other fans on the splitter it is the fan itself.
7,631 (5.81/day)
Texas
System Name Ghetto Rigs x299 & z490 & x99
Processor 9940x w/Optimus Foundation & 10900k w/Black Noctua D15 & 5930k w/Reg-Noctua D15
Motherboard X299 Rampage VI Apex & z490 Maximus XII Apex & x99 Sabertooth
Cooling D5 combo/280 GTX/ VRM copper water block/280 GTX/ Optimus Foundation/ 1080ti FTW3
Memory Trident-Z 3600C16 4x8gb & Trident-Z Royal 4000c16 2x16gb & Trident-Z 3200c14 4x8gb
Video Card(s) 1080ti FTW3-On Loop & Titan Xp-w/ Only GPU loop & evga 980ti gaming-w/ air
Storage Many sammy 2.5" ssd's 850 Pro/ 860 pro's for os & WD BLK's hdd's storage
Case D450 second floor for 2nd rad x2/ Cherry Entertainment center on Test bench
Power Supply EVGA 1200P2 & 1000P2 with APC AX1500 & 850P2 with CyberPower-GX1325U & a 750P2 unused
Mouse Redragon Perdition x3
Keyboard G710+x3
Software Win-7 pro x3 and Linux Cinnamon 20.2x2 & win-10 & 11pro x3
How exactly are they connected to the board, one in cpu and other in cpu assistane ports or splitter off one cpu port for both ?
Cpu assist ports act a little differently than cpu ports sometimes.
2,714 (1.83/day)
Thessaloniki, Greece
System Name PC on since Aug 18th 2019, 1st CPU R5 3600
Processor Ryzen 9 5900X, ECO mode 88W PPT
Motherboard Gigabyte X570 Aorus Pro (Rev1.0), BIOS F35, V2 1.2.0.7
Cooling Corsair H110i 280mm (w/ Contuctonaut since Jan 2020)
Memory 2x16GB G.Skill Trident Z Neo (GTZN) 3600MHz 1.40V CL16-16-16-16-32-48 1T, tRFC:274, B-die
Video Card(s) MSI RX 5700XT Gaming X, GPU 2100MHz, VRAM 1750MHz
Storage Samsung NVMe: 980Pro 1TB (OS 2022), 970Pro 512GB(2019) / SATA-III: 850Pro 1TB(2015) 860Evo 1TB(2020)
Display(s) Dell Alienware AW3423DW 34" QD-OLED curved by Samsung, 3440x1440
Case None... naked on desk
Audio Device(s) Sound Blaster Z <--optical link--> Logitech Z5500 5.1 500W, Logitech G935 headset
Power Supply Corsair HX750i
Software Windows 10 Home 64bit (21H2)
Is the fan a 3-pin or 4-pin. Is the board header 3/4-pin?
You said you set a curve in BIOS but what is the target/assigned temp?
Does the board has the option of zero rpm (fan stop)?
434 (0.55/day)
Tornado Alley
System Name Main W10
Processor i7 2700K
Motherboard Gig Z77 HD4
Cooling Xigmatech Tower Cooler
Memory 16 GB G-Skill 1600Mhz
Video Card(s) GTX 980
Storage WD Gold 2 TB
Display(s) Acer 27" 1440P
Case Phanteks Enthoo Pro
Audio Device(s) JDS Labs Element DAC/AMP
Power Supply Rosewill Hive 650 watt
Mouse MX 518
Keyboard Cherry 3000 with Blues
I also had that exact problem and found that using a PSU cable for power fixed it. The fan header on the mobo was weak or faulty.
172 (0.15/day)
Brazil
Processor AMD Ryzen 5 5600X
Motherboard Asus TUF Gaming B550-Plus
Cooling Thermalright Frost Commander 140
Memory 2x16 3200@3733 Crucial Ballistix
Video Card(s) Gigabyte RX 5600 XT WindForce OC 6G (GV-R56XTWF2OC)
Storage Some
Display(s) Acer XV280K
Case Cooler Master HAF XB EVO
Power Supply Cooler Master MWE 650 Bronze
Mouse Logitech G502SE
Keyboard Ajazz AK35i with AKKO CS Rose Red Switches and white YMDK PBT keys
If anyone wants a good fan control software, this is very good.
47 (0.04/day)
tried the inspection. For some reason that wasnt apparent in the cpu cooler manual, my cpu fans have 2 cables running off of them. they both look like 4 pin PWM cables but one is short and the other is longer and merges (i assume) together with the other CPU fan's cable into a single 4 pin that connects to CPU_FAN. Dont know exactly why the fan needs 2 fans to get it running, its not an RGB fan.
tried CPU_OPT but then the system wouldnt boot. as for using a chassis fan header, i could, but the fan for some reason has 2 cables coming off of it which both look like 4 pin pwm which u can see here
1,078 (0.39/day)
Software W11 Pro
@Empecial
You know, that sorta sounds like you have one normal fan cable and one fan speed reducing cable installed.
Edit: After you edited to add the video starting to consider I might be using strikethrough on every post I make here.
47 (0.04/day)
Might be. From what i understand (which the manual really doesnt make clear) it seems like the cable for the fan merges into another cable for the other fan which then gets plugged into CPU_FAN, so they should both be running the same speeds. but u can see here
that there is a second cable on the fans, not really sure what that's for
The fans are both connected to a smaller cable in the middle and then to another cable that ends in a single output that connects into CPU_FAN like here
Thats interesting since i believe both my cpu fans are connected to a single output cable that plugs into CPU_FAN. i'd assume they'd be the same speeds since they're in the same mobo plug, no?
@Empecial
Here's the "merge" cable both the CPU fans plug into which plugs into CPU_FAN
and this is the small cable in the middle
434 (0.55/day)
Tornado Alley
Processor i7 2700K
Mouse MX 518
In my case, I actually have a bad fan header.
1,078 (0.39/day)
Software W11 Pro
One of the timestamps finally showed you can completely remove the fans and their power cable.
I'd try unplugging your front fan from it's known working header and plug the one running slow into it. You could also try the Y connector from cpu cooler with slow running fan and case fan on that same header and see if it is faulty.
434 (0.55/day)
Tornado Alley
Processor i7 2700K
Mouse MX 518
fair enough. which PSU cable did u use?
I think its an extension cable that ends in a fan header. A converter from a normal cable for Sata, etc. Its an older PC.
