CPU Scaling Test Ryzen 3600X at CPU Speed of 3800Mhz 4100Mhz 4250Mhz 4400Mhz
94 (0.03/day)
CPU Scaling Test Ryzen 3600X at CPU Speed of 3800Mhz 4100Mhz 4250Mhz 4400Mhz 1920x1080 Ultra settings for anyone interested.
I have completed 10+ games tested and just added the 5 games with the most difference in AVG FPS at 1080p.
All gaming experience was the same ,list of games.
♦ Battlefield V
♦ Crysis 3 1:06
♦ Kingdom Come Deliverance 2:36
♦ Shadow of the Tomb Raider 3:36
♦ Metro Exodus 4:25
♦ Summary of results 4:59
Link to summary of tested
COMPUTER USED
♦ CPU - AMD 3600X With MasterLiquid Lite ML240L RGB AIO
♦ GPU - Nvidia RTX 2080
♦ RAM - G.Skill Trident Z 16gb DDR4 (F4-4000C18D-16GTZ) (3733mhz CL16-17-16-16-28)
♦ Mobo - MSI X470 - Gaming Plus
♦ SSD - M.2 2280 WD Blue 3D NAND 500GB
♦ DSP - LG 27" 4K UHD FreeSync Gaming Monitor (27UD59P-B.AUS)
♦ PSU - Antec High Current Pro 1200W
VIDEO INFORMATION
► FPS Monitoring : MSI Afterburner/RTSS
► Gameplay Recorder : Nvidia Shadowplay
► Edit Videos : VSDC Free Video Editor http://www.videosoftdev.com/
109 (2.06/day)
Processor R7 1700 non-X @ 4.0 GHz
Motherboard Gigabyte AORUS Gaming 5
Cooling Noctua
Memory 32 GB 3200 MT/s CL16
Video Card(s) Sapphire Vega 64
Storage 2x 500 GB SSD, 2x 3 TB HDD
Case Silverstone FT02
Software Manjaro Linux, W10 if I have to
What happened with Kingdom Come Deliverance?
9,869 (5.40/day)
Too Long to fit in a single line here.
Processor i7 8700k 4.7Ghz @ 1.26v
Video Card(s) MSI GTX 1080 Gaming X @ 2100/5500
Display(s) Eizo Foris FG2421
Case Fractal Design Define C TG
Power Supply EVGA G2 750w
Mouse Logitech G502 Protheus Spectrum
Keyboard Sharkoon MK80 (Brown)
Software W10 x64
Nice test, but I'm seeing only first and third person action games, ie very low CPU load type of games, and only in the most favorable situations most of the time.
This is not very interesting for a CPU test for gaming, to me. This tells me only how those games you tested actually run, its impossible to say anything about the use of this CPU for, say, a game of Civilization VI; or a space sim; or a game like Total War.
Basically you've picked games and situations even much weaker CPUs would perform quite similar at. That means you also miss an opportunity to really show scaling differences. The gist of it now is that you might as well run stock.
94 (0.03/day)
Yep stock is a great way to go.Do not own any of the games you mentioned.
9,869 (5.40/day)
Software W10 x64
Its a shame, it would add a lot of value to your testing to have a more varied set of applications. Not just for me btw. Something to consider, perhaps.
94 (0.03/day)
Well I was asked for these test by someone,otherwise I would not bother with 1080p test at all.
I do agree with you about the more varied gaming/applications ,I am no reviewer,just putting some results out there.Really though stock is the best bet for anyone gaming.
94 (0.03/day)
Thanks.Here is a different one 3600Mhz looks good for CPU .
Deus Ex Mankind Divided Ryzen CPU Test 3600Mhz vs 3800Mhz vs 4400Mhz
Video of all three resolutions tested one after another no breaks/restarts
Msi Afterburner Raw data 3600Mhz
19-08-2019, 18:58:10 DXMD.exe benchmark completed, 10221 frames rendered in 91.672 s
Average framerate : 111.4 FPS
Minimum framerate : 89.1 FPS
Maximum framerate : 143.3 FPS
1% low framerate : 88.5 FPS
0.1% low framerate : 83.3 FPS
Msi Afterburner Raw data 3800Mhz
Average framerate : 109.7 FPS
Minimum framerate : 86.6 FPS
Maximum framerate : 141.8 FPS
1% low framerate : 86.3 FPS
0.1% low framerate : 83.6 FPS
Msi Afterburner Raw data 4400Mhz
19-08-2019, 19:00:51 DXMD.exe benchmark completed, 10227 frames rendered in 93.046 s
Average framerate : 109.9 FPS
Minimum framerate : 86.5 FPS
Maximum framerate : 141.9 FPS
0.1% low framerate : 82.7 FPS
19-08-2019, 19:03:29 DXMD.exe benchmark completed, 10234 frames rendered in 93.266 s
5,473 (1.08/day)
USA
System Name Small ATX Desktop
Processor Intel i5 8600K @ 4.6 GHz Core & 4.3 GHz Cache @ 1.168V
Motherboard Asrock Z370 Taichi
Cooling Phanteks PH-TC14PE, MonoPlus, Fans: 2xThermalright TY143 / 2xCorsair SP-120L / 2xYate Loon D14BH-12
Memory G-Skill TridentZ 2X8GB DDR4 3200 CL14 F4-3200C14D-16GTZ @ 3200 14-14-14-34 2T @ 1.35V
Video Card(s) Zotac 1060 6GB Mini ZT-P10600A-10L with Arctic MonoPlus and Yate Loon D14BH-12 Fan
Storage OS Samsung 970 Pro 512GB NVMe, Games Phison E12 NVMe 1TB, Data WD10EZEX HDD 1TB
Display(s) 2x Asus PB258Q 2560x1440 25" IPS
Case Lian Li PC A05NB (Inverted Mobo)
Audio Device(s) Audiotechnica ATH M50X, Antlion Mod Mic 4, SYBA SD-CM-UAUD, Acoustic Research 2Ch Speakers
Power Supply Seasonic SS-660XP2 660 Watt Platinum
Mouse Zowie EC2A Mouse, Razer Naga Chroma '14, Corsair MM600, Inateck 900x300 XL pad, Tiger Gaming Skates.
Keyboard Filco Majestouch II Ninja TKL, Goldtouch GTC 0033 Ten Key, PS3 Controller
Software Win7 Pro 64 (Installed on Coffee Lake using AsRock's handy PS/2 Simulator in Bios)
A good one to test might be a RTS such as Starcraft 2 or Benches of the Singularity. I found it very interesting all the same. If AMD releases a higher clocked 'Tock' Ryzen 4000 series, say around 4.5GHz, 10+ FPS could be gained on some games even without an IPC increase.
1,713 (1.79/day)
Processor i5-8400
Motherboard ASUS ROG STRIX Z370-I GAMING
Cooling Alpenföhn Black Ridge
Memory 2*16GB DDR4-3200 CL16
Video Card(s) Gainward GeForce RTX 2080 Phoenix
Storage 1TB Samsung 970 Pro, 2TB Intel 660p
Display(s) ASUS PG279Q, Eizo EV2736W
Case Dan Cases A4-SFX
Power Supply Corsair SF600
Mouse Logitech G700
Keyboard Corsair K60
Starcraft 2 is effectively limited to single core. Or two, nowadays. So a good sincle-core test.
Ashes of the Benchmarks (especially the CPU-focused test) is a good CPU test but has almost no real-world relevance.
