- Jan 6, 2007
- 2,555 (0.38/day)
- Illinois
Processor | i7 2600k@4.6ghz |
Motherboard | MSI z68ma-ed55 |
Cooling | Silentx Extreem 120mm |
Memory | 2x4gb XMS 7-8-7-20 1600 |
Video Card(s) | HD6870 |
Storage | 2x128gb Kingston Hyper-X (Raid0), 2x750gb RE3 (RAID1), 2x750gb RE3 (RAID1) |
Display(s) | Soyo 24", Gateway 22" |
Case | Fractal Design Arc Mini 6x120mm fans. |
Audio Device(s) | Onboard |
Power Supply | Zalman 750w |
Software | Windows 7 |
I have a Crucial CT128M225 that's back from RMA and doesn't have much use. Maybe a few months of web browsing and whatnot. When I use the drive, it'll work ok for awhile then lock the computer with the HDD LED stuck on. When I reboot, the drive isn't found by the BIOS. If I keep the computer off for awhile it'll work again for awhile but eventually fails. Seems to be a common problem. I have version 1916 firmware on it. It will not accept the 2030 update for some reason.
Firmware page: http://www.crucial.com/support/firmware.aspx
Is there a utility for Crucial SSDs that can diagnose the drive and tell me what the problem is?
