Custom power LED
2 (0.01/day)
Missouri
System Name The Phantom
Processor AMD FX-8350 Black Edition
Motherboard Gigabyte 990-FXA UD3
Cooling Zalman 135mm Blue LED cooler
Memory 16GB G.skill Sniper DDR3 1866
Video Card(s) MSI Duke Nvidia GeForce GTX 1080Ti
Storage WD VelociRaptor 500GB system drive, WD Blue 6TB storage drive
Display(s) LG 25” UltraWide IPS Gaming monitor
Case NZXT Phantom 410 Gunmetal
Audio Device(s) Eivotor 18” Mini Soundbar, onboard audio
Power Supply EVGA SuperNova 1000PQ
Keyboard Logitech G510
Software Windows 10 Home
Hi everyone, first time on here.
I built my first computer about 7 years ago, and have been slowly upgrading it over the years. Well I’m basically maxed out on the build, and with AMD’s new releases, it’s time to build a new, updated system.
I’ve been looking into case modding a lot recently and have decided to build a custom case for my new build rather than buying one. I’m pretty handy with tools and it wouldn’t be the first time I’ve built something.
What I can’t figure out, and can find no answers on google, is if I can use a LED strip in place of a single LED for the power LED on the case. Would the header (that you normally plug the power LED into) on the mobo provide enough power for about 3ft of LEDs?
I figured I have to put a power LED anyway, and I wanted some exterior accent lighting, so I’d just combine the two. LEDs will be a single color strip, not RGB, if that makes any difference.
Thanks for any help.
714 (2.40/day)
System Name Fatboii
Processor AMD Ryzen 7 3700X @ 4.2 GHz (all cores)
Motherboard ASUS Crosshair VIII Hero WiFI
Cooling Custom water
Memory Patriot Viper Steel 2x8GB @ 3733 15-15-15-34-52-1T
Video Card(s) EVGA GTX 1080 Ti FTW3 under water
Storage Samsung SM951 256GB + 860 EVO 1TB
Display(s) ASUS ROG PG278Q 144Hz
Case Fractal Design R6 Tempered Glass
Power Supply EVGA SuperNOVA G3 850w
Keyboard Cooler Master Pro Keys L
Benchmark Scores I only game on this system... built for silence, not absolute max performance. ;)
I don’t think it’ll provide enough power and may even burn that circuit. They’re built to provide very little juice as this isn’t your typical thing.
All modern motherboards (bar a few eccentric ones) come with RGB headers. Just use one of those...? They’ll power on when the rig turns on, producing the same effect; right?
Ahhzz
5,891 (1.37/day)
System Name Ironic
Processor Intel 2500k 4.4Ghz
Motherboard ASROCK|Z68 PROFESSIONAL Gen 3
Cooling Corsair H60
Memory 32GB GSkill Ripjaw X 1866
Video Card(s) Sapphire R9 290 Vapor-X 4Gb
Storage Samsung 860 EVO 1Tb/WD BLACK SN750 500GB NVMe
Display(s) 22" Dell Wide/ 22" Acer wide/24" Asus
Case Antec Lanboy Air Black & Blue
Audio Device(s) SB Audigy 7.1
Power Supply Corsair Enthusiast TX750
Keyboard Corsair Vengeance K90
Software Win 7 Ult 64 bit
Not a helpful reply, but I am looking forward to this!
As a guesstimate, I wouldn't expect it to be able to drive more than a couple, possibly 3, LEDs. I have a sheet of 10 feet, and that requires a lot more amperage than you'll get off the motherboard. There's a reason you have to purchase those power bricks for strips of LEDs. Now, having said that, I wouldn't think it would take much to rig a brick inside the case, and toggle it with the power switch. Obviously, a small strip of lights would be best, as you could get away with a smaller power bank.
2 (0.01/day)
Missouri
Most of the LED strips I’ve seen are wired for sata/molex tho. Or come with a connector to plug directly into a sata/molex cable without a brick.
The rgb LED header on my mobo supports up to a 12V/3A 36W strip, I found a 48” strip that runs at 12V/20-25mA (see below). If the math is correct, that’s only 0.3W. But it only has the option for a 4-pin connector, is that what I need to plug into the mobo header? Or is the 4-pin for a molex? (I’m new to RGB)
LED strip I found:
2,294 (1.32/day)
Long Island
I built my own ... bought LED strips from China and matched them to the power plug provided with Phanteks cases. This was strict / plain lighting tho ... no interest in RGB blingie things.
I couldn't find the connector plug link I used as the strip didnt come with one; I called Phanteks at the time, they gave the the plug type / name and i found them in an electronics store ... just can't recall th ename. Today you can buy complete kits w/ controllers
Take a peek here:
