lyndonguitar
I play games
- Apr 1, 2010
- 1,878 (0.37/day)
- Philippines
System Name | X6 | Lyndon-ROG |
Processor | Intel Core i7-8700k | Intel Core i7 6700HQ |
Motherboard | Gigabyte Z370 Aorus Gaming 5 | Asus ROG-GL552VX |
Cooling | Deepcool Captain 240EX |
Memory | 16GB Corsair Vengeance LED | 8 GB |
Video Card(s) | NVIDIA GTX 1080 8 GB GDDR5X | NVIDIA GeForce GTX 950M 4GB |
Storage | SSDs: 500GB, HDDs: 2TB, 2TB, 3TB | SSD: 250GB, HDD: 1TB |
Display(s) | Samsung 49" CHG90 3840x1080@144Hz, Panasonic 32" HDTV, | 15.6"1080p |
Case | Cougar Panzer Max |
Audio Device(s) | HyperX Cloud II | Corsair Gaming H1500 7.1 | ROCCAT Kave 5.1 | Edifier M3200 |
Power Supply | EVGA 750GQ |
Mouse | Logitech G403 | Razer Deathadder Chroma | Logitech G302 | Mad Catz Cyborg R.A.T. 5 |
Keyboard | Corsair Vengeance K70 Cherry MX Red |
Software | Windows 10 |
It's been a while since I last built a PC from scratch and with a new case and I don't have experience yet with PWM fans. I tried googling but it's hard to find results..
so I have this Deepcool FAN HUB (4pins) that came with the Captain Cool 240EX
https://www.newegg.com/Product/Product.aspx?Item=1W7-001E-00001
It has a free Fan hub that will be used by the radiator fans. however the case fans that came out with my case(Panzer Cougar Max) is non-PWM and uses 3 pins only. I plan to plug one in(rear case fan) together with the 2 PWM Radiator fans, my question is will it work? (3pin +2x 4pin PWM) or should I just plug in the 3pin rear fan to the front panel controller/psu? I'm not sure if it will work when 3/4pin are combined together, or if it will work on all 4pins only or all 3pins only
