DIY Water Cooling Rig
Discussion in 'Overclocking & Cooling' started by JALOOS, Aug 21, 2005.
  1. JALOOS New Member
    Feb 1, 2005
    29 (0.01/day)
    0
    British Columbia
    Am setting up my own water cooling seup and am taking some ideas from your posts. They have been quite informative and I thank you for the input. I am going a little further with my project as I work in a metal fab shop and materials are really not a problem to get. My resevior ia a 20 inch long piece of 8 inch aluminum pipe with a wall thickness of quarter inch. The pipe is welded to a quarter inch piece of aluminum plate which will serve as the bottom of the resevior and the base for the pump and rad. I have made it just tall enough to fit under my desk. I will keep you posted with pics and the results as I get them. Here is a few picks of the start.
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    10 Year Member at TPU
  2. JALOOS New Member
    Feb 1, 2005
    29 (0.01/day)
    0
    British Columbia
    Well all finished. Managed to get a water block for the CPU still waiting on one for the VPU. The thing works excellent. I added a temp sensor in the tank and with the controls I can run any part of it with or without the comp running. I ended up cutting the tank down another 3 inches to acomodate the wheels I put on so I can pull it out from under the desk .The total volume of the system is now 4 gallons. My temps under full load now only hit my idle temps from before. Gotta love it. Here are some pics of the finished unit:
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    LETS ME KNOW WHAT YA THINK !!!!
  3. JALOOS New Member
    Feb 1, 2005
    29 (0.01/day)
    0
    British Columbia
    Afetr runnin this rig for a week or so I have some results. Compared to my XP-90 HS that was on my CPU this unit is far more efficient. My Idle temps run from 28 to 31 C compared to 33 to 41 C. The max load temps are sitting at around 36 to 40 C compared to 40 to 55 C. I have noticed that the ambient air temps are not nearly as influential as they were with the air cooling and that the recovery to idle temps is almost instnt and very little lag time in idle temp recovery. The large res tank keeps these temps for the day and it does take alot of running full out to raise the CPU temp by even a couple of degrees at idle. I havn't yet gotten a block for my GPU and I am sure the addition of this will change this somewhat and I will let you know.
    The galvanic reaction that I was worried about seems to have been taken care of with a 50/50 mix of distilled water and antifreeze as I drained the tank and found no signs as I did with the test runs with just plain water. I used a couple of tablespoons of liquid dish soap as a "water wetter" and within minutes of adding it the little bubbles that collect inside the lines just disapeared. I have noticed no smell so bacteria hasn't become a problem yet but in the event that it does I will be testing a few tablespoons of bleach in the mix as well (or PINESOL LOL).
  4. JALOOS New Member
    Feb 1, 2005
    29 (0.01/day)
    0
    British Columbia
    Well goter (no thanks to the suplier) LOL
    Some Picks Below :
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  5. JALOOS New Member
    Feb 1, 2005
    29 (0.01/day)
    0
    British Columbia
    Well doesn't look like my soldered bolts held out. Guess one decided to let go last night. Good thing my comp wasn't on all night. LOL Found out the next morning and yes boys and girls these cards can get 113c. Cards ok though major fast shut down. Managed to find some of the elusive 4-40 rod (made of pure unobtainium LOL) so all is better.
  6. wazzledoozle
    wazzledoozle New Member
    Aug 30, 2004
    5,358 (1.11/day)
    154
    Seattle
    Very nice :)
    Great overclock for the 6600GT also :eek:
  7. wtf8269
    wtf8269 New Member
    Apr 12, 2005
    2,489 (0.54/day)
    22
    Ohio
    Holy shit dude that thing is crazy! You could cool a frickin' motorcycle with that thing!
  8. spectre440 New Member
    Jul 18, 2005
    937 (0.21/day)
    14
    Israel
    try more along the lines of a main battle tank... lol
    very nice though.
    very very nice.
  9. DanTheBanjoman SeƱor Moderator
    May 20, 2004
    10,488 (2.12/day)
    1,395
    It's huge indeed. How much power does that monster waste? How noisy is it?
  10. JALOOS New Member
    Feb 1, 2005
    29 (0.01/day)
    0
    British Columbia
    Actually the only difference in power between this and any other watercooling setup is the fan> As this one is a 120 volt fan vs a 12 volt fan I am assuming it will draw more power. I think the fan and pump together run in the range of 40 watts or less. As far as noise, if I can still hear my casee fans then it's not too noisy for me. The fan doesn't have to be run all the time either as this volume of water and the fact that the res is made from aluminum don't require the fan to run untill the water gets warm enough. Without the fan this this is dead quiet, not a peep.
  11. zAAm
    zAAm
    Mar 27, 2005
    1,005 (0.22/day)
    94
    South Africa
    Does it cool better when you run the fan like that to suck air through the radiator? And excellent job! Not even requiring to use a fan, that's way cool... ;)
  12. JALOOS New Member
    Feb 1, 2005
    29 (0.01/day)
    0
    British Columbia
    Actually when I made the rad box I never thought of sucking the air through the rad, it is still pushing the air through rad. Maybe one day here I wil turn the fan blade over and see if it will work better sucking the air through.
  13. djbbenn
    Apr 11, 2005
    2,722 (0.59/day)
    44
    Canada
    Very nice. Its like a...reactor cooler. :D
    -Dan
  14. zAAm
    zAAm
    Mar 27, 2005
    1,005 (0.22/day)
    94
    South Africa
    For a moment there I figured the fan would spin anti-clockwise given the blade's form but guess I was mistaken... ;)
  15. intel igent
    intel igent New Member
    Jun 5, 2005
    4,640 (1.02/day)
    428
    Toronto, Canada
    man jaloos these pics are starting to pop up all over the place ;)
    once again excellent job :cool:
    shout out to all the canadians/biggie forum members in the house ;) :D
  16. DR.Death
    DR.Death New Member
    Jul 10, 2005
    1,737 (0.38/day)
    64
    Canada
    nice case i dont like the pipes runing evey wear but what can u do so good job keep it up
  17. JALOOS New Member
    Feb 1, 2005
    29 (0.01/day)
    0
    British Columbia
    Hey paid good money for the glowing cables LOL. Not going to try and hide em if they look good.
  18. DR.Death
    DR.Death New Member
    Jul 10, 2005
    1,737 (0.38/day)
    64
    Canada
    i get your point but it is not my stile
  19. djbbenn
    Apr 11, 2005
    2,722 (0.59/day)
    44
    Canada
    I would hate to have to drag that to a lan party. :p But imagine what people would say when you showed up with that lol. :D
    -Dan
  20. W1zzard
    W1zzard Administrator Staff Member
    May 14, 2004
    16,967 (3.43/day)
    17,954
    wow that looks impressive
  21. mikechinym
    mikechinym New Member
    Jun 16, 2005
    80 (0.02/day)
    0
    Malaysia
    that's cool!
