Dlss4 + 4090 = lower max oc than with dlss3
1,202 (1.77/day)
Processor Ryzen 7800x3d
Motherboard Asus B650e-F Strix
Cooling Corsair H150i Pro
Memory Gskill 32gb 6000 mhz cl30
Video Card(s) RTX 4090 Gaming OC
Storage Samsung 980 pro 2tb, Samsung 860 evo 500gb, Samsung 850 evo 1tb, Samsung 860 evo 4tb
Display(s) Acer XB321HK
Case Coolermaster Cosmos 2
Audio Device(s) Creative SB X-Fi 5.1 Pro + Logitech Z560
Power Supply Corsair AX1200i
Mouse Logitech G700s
Keyboard Logitech G710+
Software Win10 pro
I have been testing cyberpunk with the new patch and tech. I found that my gpu kept crashing the game, and wondered if it had begun to degrade.
However, switching back to dlss3 made my gpu stable with the previous max oc of +250 core. With dlss4 the most i can do is +100.
Have any other 4090 owners found the same thing to be the case ? That their max achievable oc with dlss4 is lower than with dlss3 ?
Majcric
2 (0.01/day)
I have found that using different drivers can slightly reduce an overclock or offset. 250 to 100 does seem rather large. Are you certain the 250 was always 100% stable in everything? Try Steel Nomad and see what happens.
Solaris17
Super Dainty Moderator
27,221 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
I can’t get mine to go over 110 or so core stable. It happily goes over that if I don’t mind random driver resets though. I would love +250
1,202 (1.77/day)
Software Win10 pro
As i wrote in the post, changing from dlss4 to dlss3 in cyberpunk it is still stable with +250. And it still is with the current driver.
It is purely with cyberpunk dlss4 that i've experienced it, hence why i am asking other 4090 owners if they are experiecing a reduced stable max oc with dlss4 in cyberpunk aswell.
Yours probably have higher stock clocks due to being liquid, so not apples to apples - my clock with +250 is 3ghz on core.
Durvelle27
6,813 (1.48/day)
Memphis, TN
System Name Black Prometheus
Processor |
Cooling Thermalright PA120 SE |
Mouse Logitech Trackman
Keyboard Logitech K350
Software Windows 10 EDU x64
Just because it works in a one off doesn’t mean it’s 100% stable. It very well might not be fully stable and when using DLS4 it’s more hardware bond causing the crash.
You need to do more testing to rule out a bad OC or possible bad game patch
Solaris17
27,221 (3.83/day)
Alabama
VR HMD Quest 3
Mine doesn’t reach 3ghz stable. I can push 2910 max.
1,202 (1.77/day)
Software Win10 pro
It has been my oc for 2 years - it's stable. As said (for the third time) cyberpunk with dlss4 is the only scenario where it hasn't been stable... hence me making this thread and asking other 4090 owners if you are experiencing the same.
Solaris17
27,221 (3.83/day)
Alabama
VR HMD Quest 3
Nope. Mine works fine.
1,202 (1.77/day)
Software Win10 pro
Ah too bad, didn't win the silicon lottery there. I can do 3 ghz without increasing volts, and 3070 with +50mv.
Durvelle27
6,813 (1.48/day)
Memphis, TN
Processor |
Again that tells us little to nothing
what other testing have you done outside of Cyberpunk.
1,202 (1.77/day)
Software Win10 pro
Im thinking if perhaps the tensor cores on my gpu aren't as strong as the rest of the chip, and now that they get used more heavily, it reduces how high i can push it.
Solaris17
27,221 (3.83/day)
Alabama
VR HMD Quest 3
Could try bumping voltage if you weren’t previously. Assuming you aren’t running beyond 1.1.
3,413 (2.51/day)
Processor Ryzen 5 5700x
Motherboard B550 Elite
Power Supply MSI 750w
Mouse G502
i have been doing the same but with a 3060ti and it all works fine. transformer model is great
1,202 (1.77/day)
Software Win10 pro
Bumping voltage 50mv to 1.1v does make it stable at +200, but yeah, with every other game (including cyberpunk with dlss3) it's stable with +250 @ 1.05v - it's only when using dlss4 in cyberpunk the problem pops up. It literally instant crashes when applying the oc when running dlss4.
But yeah, personally leaning between weak tensor cores and / or game bug.
423 (2.16/day)
Transformer model makes heavier use od tensor cores. The reason why it's literally only cp2077 Dlss transformer could be just that-first one to really stress tensor cores.
1,202 (1.77/day)
Software Win10 pro
Yeah - might simply be a case of my specific gpu having strong raster and rt cores, but somewhat weak tensor cores. And as you say, cyberpunk with dlss4 is the first game to really hammer tensor cores.
423 (2.16/day)
or simply tensor cores never really being "stress tested" before now. you know how it is with cpus, some overclocks seem perfectly fine, until something specific crashes them. happy to say that the undervolt on my 4070S runs cp2077 transforemer just fine, didn't crash for hours.
83 (0.06/day)
System Name desktop
Processor Ryzen 9800X3d
Motherboard Asrock Pro Rs
Memory G.Skill Flare X5 6000mhz cl30 1.35v
Video Card(s) Asus GeForce RTX 4080 TUF Gaming - OC Edition
Storage 2TB WD_BLACK SN850X NVMe
Display(s) Acer Predator 1440p
Case Fractal R6
Im guessing in theory there could be some amount of acceptable rendering errors which could be lower fps or just crashing.
173 (0.06/day)
System Name AMD System
Processor Ryzen 7900 at 180Watts 5650 MHz, vdroop from 1.37V to 1.24V
Motherboard MSI MAG x670 Tomahawk Wifi
Cooling AIO240 for CPU, Wraith Prism's Fan for RAM but suspended above it without touching anything in case.
Memory 32GB dual channel Gskill DDR6000CL30 tuned for CL28, at 1.42Volts
Video Card(s) Msi Ventus 2x Rtx 4070 and Gigabyte Gaming Oc Rtx 4060 ti
Storage Samsung Evo 970
Display(s) Old 1080p 60FPS Samsung
Case Normal atx
Audio Device(s) Dunno
Power Supply 1200Watts
Mouse wireless & quiet
Keyboard wireless & quiet
VR HMD No
Benchmark Scores 1750 points in cinebench 2024 42k 43k gpu cpu points in timespy 50+ teraflops total compute power.
This means oc was not stable (in other words, only stable for the algorithms you tested before).
The gpu has rt, tensor, video encode decode, texture sampler, float core, int core, etc. Unless you use all at the same time during stability test, it is not a stability.
Even the frequency of use affects stability. Upgrading cpu can offload more tasks to gpu and show its unstability.
Perhaps all thr rtx5080 high overclockers are not using the extra 100% integer cores. When an algorithm start using them, all of them may be forced to lower the oc. For example, gpu decompression is integer heavy. This may show unstable cases in gpus like +400 core.
1,202 (1.77/day)
Software Win10 pro
So i tested a bit further, and it appears that it is not actually dlss4 causing the extra load / need for higher voltages or lower clocks, but rather using ray reconstruction when also using dlss4. This is also the case with hogwarts legacy after it got dlss4 - enable RR, and max stable oc is reduced to +100.
I saw steve from gamersnexus talking about them experiecing instability with dlss4 aswell, so likely same issue they are running into.
7,633 (3.26/day)
California
System Name His & Hers
Storage lots of SSD.
I was going to chime in that DLSS4 as a whole is probably pushing the 4090 harder than ever, more parts of it anyways. I run mine at 330w so no help there I never did enough OC testing to know what my card can do.
1,429 (0.31/day)
Processor i7-13700k
Motherboard Asus Tuf Gaming z790-plus
Cooling Coolermaster Hyper 212 RGB
Memory Corsair Vengeance RGB 32GB DDR5 7000mhz
Video Card(s) Asus Dual Geforce RTX 4070 Super ( 2800mhz @ 1.0volt, ~60mhz overlock -.1volts)
Storage 1x Samsung 980 Pro PCIe4 NVme, 2x Samsung 1tb 850evo SSD, 3x WD drives, 2 seagate
Display(s) Acer Predator XB273u 27inch IPS G-Sync 165hz
Audio Device(s) Logitech Z906 5.1
Power Supply Corsair RMx Series RM850x (OCZ Z series PSU retired after 13 years of service)
Mouse Logitech G502 hero
My guess is its not lowering OC, just means your OC wasn't truly 100% stable. DLSS 4 is using gpu slightly different which is part of your OC that isn't stable hence the crashes.
Durvelle27
6,813 (1.48/day)
Memphis, TN
Processor |
At this point the question has been answered and you just refuse to accept the answer
the issue is your OC
not the game not DLS4
1,202 (1.77/day)
Software Win10 pro
You're free to think whatever you want, dude.
ir_cow
4,718 (0.79/day)
USA
The max frequency will change with resolution. Not commonly known.
