Do CLCs adjust fan/pump speed based on CPU or coolant temp ?
5,602 (6.18/day)
Poland
System Name skurwiel szatan
Processor i7 5775c @4.3GHz/1.385v/EDRAM @2GHz
Motherboard Z97X Gaming 5
Cooling Noctua D15S
Memory Crucial Ballistix Tactical LP 1600 CL8 @2133 9-9-9-27 1T
Storage SU900 128 (OS)/850 PRO 256+256+ 512,860 EVO 500,XPG SX950U 480,M9Pe(Y) 512 (games)/4TB HDDs (3+1)
Display(s) Acer XB241YU+Dell S2716DG dual monitor setup
Case Full tower
Audio Device(s) W830BT headphones
Benchmark Scores A LOT
All the motherboard I use have the option to wait 10 seconds inbetween changing fans speed, this greatly reduces noticeable fan spikes.
this is very good.
are they asrock ?
still,having the cooler absorb the heat into the coolant before ramping up the fan is the best option imo.
5,602 (6.18/day)
Poland
Cooling Noctua D15S
Case Full tower
I think I wanna go with Corsair pro/plat cause of software,60 month warranty and quiet fans,but should I get the 240 or 280?
763 (1.50/day)
California
System Name His & Hers
Processor i9 9900k @5ghz/ R9 3900X Stock
Motherboard Asus Maximus XI Code/ X570 Aorus Master
Cooling Corsair h150i Pro Push/Pull. 5x Corsair ML120 + 4x Corsair LL120/ Corsair h115i Platinum
Memory 32 GB 4x8GB 3600mhz Corsair RGB Pro/ 32 GB 3200 CL14 @3800 CL16
Video Card(s) Asus ROG Strix 2080 ti/ Titan XP
Storage lots of SSD.
Display(s) Asus ROG PG278QR / MSI 27 inch VA panel.
Case Corsair 500D SE RGB/ Phanteks Evolv X
Audio Device(s) Arctis Pro + gaming Dac/ Corsair sp 2500/ Logitech Z 625
Power Supply Seasonic Ultra Prime Titanium 850w x2
Mouse Logitech G903 Lightspeed/ Logitech G Pro Hero.
Keyboard Corsair K95 RGB Platinum/ Logitech G Pro
280mm without a doubt the 240mm is annoying, at least it was on my 3900X
968 (2.84/day)
Poland
Processor Ryzen 7 3700X
Cooling BeQuiet Dark Rock 4
Memory 2x8 GB Crucial Ballistix Sport LT 3200 CL16 @ 3733 CL 16
Video Card(s) EVGA 1060 6GB SSC
Display(s) BenQ BL2411PT
Mouse SteelSeries Rival 300
Keyboard MK Typist (Kailh Box White)
Anyone running Corsair setup cares to shed some light on performance impact of iCue in the background? I remember seeing plenty of complains about it in various places.
763 (1.50/day)
California
Less than 1% on either of my systems when minimized/background.. 2-3% while it's open.
280mm SHOULD be more quiet.. you can confirm this from any review. It will have a bit more surface area and a bit better performance as well.
On a 3900X it wasn't even close 8-10c cooler and much quieter. I thought the first h100i platinum was defective and got a replacement that also didn't do very good job on a 3900X in a blender load.
newtekie1
Semi-Retired Folder
26,790 (5.17/day)
Indiana, USA
Processor Intel Core i7 9900K@5.0GHz
Motherboard AsRock Z370 Taichi
Memory 32GB Corsair DDR4-3000
Video Card(s) ASUS Strix GTX 1080Ti
Display(s) QNIX QX2710 1440p@120Hz
Case Fractal Design Define S
this is very good.
are they asrock ?
Yes, they are AsRock. And setting the delay between fan speed changes allows the coolant to absorb the heat before the fan speed ramps up.
859 (5.77/day)
Thessaloniki, Greece
System Name None
Processor Ryzen 5 3600 (PBO manual: PPT 95W, TDC 60A, EDC 63A, Scalar X2)
Motherboard Gigabyte X570 Aorus Pro
Cooling Corsair H110i 280mm (Liquid metal for TIM)
Memory CorsairVengeanceLPX DDR4 2x8GB 3466MHz CL16-18-18-36 1T, cheap B-die, @3600 CL16-16-16-32 1T (1:1:1)
Video Card(s) MSI RX 5700XT Gaming X
Storage Samsung NVMe 970Pro 512GB / SATA-III 850Pro 1TB SSD
Display(s) 24" EIZO FlexScan S2411W 1920x1200, 16:10 60Hz samsung S-PVA panel.
Case None
Audio Device(s) Sound Blaster Z <--optical link--> Logitech Z5500 5.1 500W
Power Supply Corsair HX750i 93% eff
Mouse Logitech MX Master
Keyboard Logitech G15 v2
Software Windows 10 Home 64bit (v1909)
Definitely 280mm instead of 240mm...
16,405 (4.46/day)
I wouldn't call 8-10C spread normal between 240 and 280... because, science :p. Another variable was involved in that result be it TIM applications or mount...differing ambients, etc. If you go by empircal testing, the difference is typically half that (or less) in many cases.
763 (1.50/day)
California
I agree I was pretty shocked but 2 240s behaved nearly identically my ambient is controlled and is always within 1c. The tim was also identical brand between the 3 coolers. I remounted the 240mm cooler multiple times but couldn't get it lower than 80c vs 70-72c on the 280mm cooler.
16,405 (4.46/day)
I don't know what to tell you outside of the fact that an outside variable was introduced somehow. :)
This also shows how little effect stock fans can have... with most of these seeing a couple C difference at most.
This is why I subscribe to the 'not playing games' method and just set shyte on silent. Done. No reindeer games, just set and forget along with a beefy overclock on a HCC chip.
763 (1.50/day)
California
Yeah, maybe I was just super unlucky and got 2 defective units I didnt try a 3rd. I do know that the 240mm is about 7c worse on a 5ghz 9900k with fans maxed out on both units but that's a more extreme scenario than a stock 3900X.
16,405 (4.46/day)
Perhaps. Just trying to show that empirical testing yields only a couple/few C at most between 240 and 280 mm. Obviously this depends on the rad, but never have I seen an 8C+ difference all other things remaining the same. :)
280mm FTW, regardless!!
763 (1.50/day)
California
Yeah, even had I gotten temps on the 240mm at a place I was happy with the noise would have annoyed me enough to replace it at some point anyway.
5,602 (6.18/day)
Poland
Cooling Noctua D15S
Case Full tower
115i pro/plat it is then
gonna cost me a leg but I don't mind paying premium for products that deliver
any other clcs I should be looking at ? I know x62 is really good,but I don't know about the software
763 (1.50/day)
California
I think a lot of this is going to be personal preference sorta thing but I hate NZXT/Thermaltake software. I've been using icue since it launched and only 2 updates caused me issues and corsair fixed them pretty fast otherwise I really like it for my commander pro and aio.
Tatty_One
Senior Moder@tor
22,063 (4.30/day)
Worcestershire, UK
System Name The Grey
Processor Skylake i7 6700k @ 4.6gig - 1.35V
Motherboard MSI Z170A Tomahawk
Cooling Cooler Master Seidon 240V AIO/Viper140's
Memory 16GB Corsair Vengeance LPX3000 @ 3200mhz CL15 1T
Video Card(s) Palit 8GB GTX 1070 GameRock OC Edition
Storage SkHynix SL308 120GB/CrucialM4 64GB/1TB WD Black
Display(s) LG 29inch 2560x1080 Curved Ultrawide IPS
Audio Device(s) SB Xifi Elite Pro 7.1through VideoLogic ZXR550's
Power Supply XFX Pro Black Edition 750W Gold modular
Mouse Coolermaster Storm Octane wired
Keyboard Element Gaming Carbon Mk2 Tournament Mech
Software Win 10 Home x64
Well in terms of 280's, the Enermax LiqTech II 280 is a fair bit cheaper (well it is here in UK), performs pretty well and has pump control, not suggesting it performs as well but for the price it is decent bang 4 $.
There are a couple of polish sites that have reviewed also which you can see from the links on Enermax's site.....
5,602 (6.18/day)
Poland
Cooling Noctua D15S
Case Full tower
it's even more expensive than 115i plat here
and I hate enermax fans,they're loud and they rattle at high speeds cause they're feel light and cheap.
I have a couple of ml120s and damn they feel heavy and sturdy,plus they're really quiet even at 1500rpm while pushing a lot of air.I was actuially using them as case fans and they did pretty damn well.That's why I like the idea of 115 since it has ml140s.
115 plat is the thinnest of the premium clcs too,at 27mm.it's gonna be a tight squeeze in my case cause of the vrm heatsink sticking out a little bit.
763 (1.50/day)
California
The biggest issue with enermax right now is their Threadripper coolers were terribly unreliable which would make me nervous about all their aio products.
Tatty_One
Senior Moder@tor
22,063 (4.30/day)
Worcestershire, UK
Damn, the Enermax unit is £40 cheaper over here than the Corsair. My Cousin uses it with his 9700K and keeps it cool, he is only a light gamer but he works with CAD and various 3D imaging packages and he is very happy with it but I agree, if it is the same price or more in Poland it is a def No.
5,602 (6.18/day)
Poland
Cooling Noctua D15S
Case Full tower
I just checked and it seems I do have enough clearance for 25mm fan and 27mm rad.
does the 115i have a 0rpm mode ?
